Fun baby steps. Finished overhauling and beautifying the rear uprights. Made aluminum inserts to replace the rubber bushings.
I mounted a wheel from my STi. That's a 18x10.5" Enkei RPF-01, (38ET) and BFG 275-35's, the equivalent of a Hoosier 285. What you can't see is a 10mm spacer. Just about absolute minimum for this setup to make things clear. Wheel has too much offset to the inside to work. Baby needs new shoes! Body needs flares.
Caveat: No alignment has been done; just eyeballing angles and axles are not in. There's some droop in this mockup.
Now I have to buy the proper length bolts and thinner Heim joint spacers or go back to the lathe. That's high-performance rattle-can enamel I baked on. All new bearings and seals. There's some Rasmus OCD engineering going on too.
10557013_999600876723691_5633665905121565547_o.jpg1606484_999600880057024_1695608015204324789_o.jpg
