11-24-2025, 03:16 PM
#241
I went ahead and pulled the trigger on my Dakota Digital gauges! I bought the gauge set, the GPS module, the dimmer for the gauges, and an external GPS antenna. I decided to skip the TPMS as it isn't 100% compatible with the gauges and would require Dakota Digital to make some modifications to get partial compatibility.
I also ordered four Billet Specialties A/C vents. I'm leaning toward doing the dash in real Charcoal Black Alcantara over 1/8" landau pad and then using a carbon fiber panel to mount the gauges in.
11-24-2025, 09:16 PM
#242
Sounds good Dave. I just received my Anthracite black Alcantara for my dash. I think the sheen of it will look nice and it's pretty easy to work with so we'll see. I am going to try my hand at upholstery on this build, possibly including seats. Good on you to go big with the vents. They should really pop.
11-24-2025, 09:28 PM
#243
PNWTim
Are you planning to do any pad under the Alcantara on the dash? What adhesive do you plan to use?
My better half is going to bring her sewing skills in and do some contrasting stitching in red for me.
11-25-2025, 10:25 AM
#244
Papa
I ordered the Alcantara with foam pre-applied. It's the equivalent of 1/8" Landau (2 mm) which is what I was originally going to use. Specifically for hard panels and headliners:
https://www.upholsterysupplyusa.com/...ft-foam-backed
I am not clear on whether the foam is applied in Italy or by the guys in California but the ease of use appealed to me. I am going to spray Weldwood Landau adhesive out of cheap HF gun.
https://www.amazon.com/Dap-Weldwood-...4083990&sr=8-1
https://www.harborfreight.com/32-oz-...zle-56981.html
I ordered a gallon so I can do my dash and door panels and anything else I can think of. I've been watching a lot of videos on the subject matter and although you can use the aerosol cans most of the YouTube upholsterers use the Weldwood (or something similar).
I am by no means an expert but I am going to give it a go. I have leather, fabric and carpet coming from Relicate for the remainder of the car so I am on a steep learning curve!
11-25-2025, 10:52 AM
#245
PNWTim
Thanks, Tim. The Alcantara I ordered doesn't have a backing on it, so I thought the foam would be a good add. I found the foam relatively inexpensively and figured I'd be able to apply it to the dash and hope to feather it out on the top so that the front edge is padded, but as you get closer to the edge where it meets the windshield, it will be virtually gone with just the metal dash surface left where the defrosters mount. I also plan to use the Weldwood glue, but ordered it in their spray cans.
https://www.amazon.com/dp/B092NJH6XL...fed_asin_title
We'll see how that works. For the stitching, I'm still debating if I want to do actual French seams or just do a double stitch on a single piece of Alcantara. I think I know the answer but will experiment a bit to see how it looks.
I may also do the transmission tunnel cover and shift boot in the same material.
11-25-2025, 11:02 AM
#246
I have found the same preference for the Landau glue and have been using it. The cans do not go far. You can get a gallon and a spray gun in a kit for pretty cheap. You also do not need to clean it out of the gun when done, only wipe the tip off with some acetone.
11-25-2025, 11:50 AM
#247
Well, okay then. I just ordered a gallon and a sprayer.
11-25-2025, 12:08 PM
#248
It is very rewarding to spend other people's money on tools and supplies! Just remember, we're here to help
Papa liked this post
11-25-2025, 02:41 PM
#249
pnwtim
it is very rewarding to spend other people's money on tools and supplies! Just remember, we're here to help
lol !
Type 65 Daytona G3 Coupe #635 - Dart 363" SBF
1970 Plymouth Road Runner 440 6-BBL Super Track Pack
11-29-2025, 04:29 PM
#250
Hi Papa, I also got my D65 mid August this year (delivery to Norway) and I also spent some 1-2 hours looking for the hardcopy manual (since YouTube "Oak hollow Garage, Thomas referred to that one allot), just to learn that I now had to download the manual.. Agree with you, they should have sent it for us tactile persons still like the papers
11-29-2025, 04:54 PM
#251
FNLode
Thankfully, a fellow builder @460.465USMC was kind enough to send me his hard copy manual that he wasn't using. I love having that manual open on my workbench as I'm working through each part of the build.
11-30-2025, 04:28 PM
#252
My gauges arrived! I was expecting an eight to ten week lead time, but they came in two days. They look even better in person than the pictures make them look.
12-01-2025, 11:35 AM
#253
I just got back from dropping my panels off at the powder coater! The engine bay panels are going to be done in a nickel metallic and the rest in the Silk Satin Black. As I showed above, the gauges are here. I plan to bench test them and will show what they look like lit up. They are supposed to have indicators for turn signals, high beam, check engine, and e-brake, but those are not obvious to me looking at the gauges. Once I get them powered up, I can put them into a demo mode and it should show those indicators. If they don't actually display, plan B is to use small LEDs from Watson Street Works.
I received my Alcantara material, but I'm still waiting for the padding, thread, and needles for the sewing machine that will work for the heavier #92 thread.
I also ordered some VViViD Super Gloss Black Carbon Fiber Tek Art vinyl wrap to try on the gauge panel. If I don't like it, I will order a real carbon fiber panel and make a gauge panel from that.
I also published my latest update on my YouTube channel:
12-01-2025, 06:35 PM
#254
Noticed in your video wheel spacers on the back? What rims offset and tires are you using? Following your build as I'm not far behind you?
Scott
12-01-2025, 06:37 PM
#255
Sharris2
Scott
Scott,
Those are just there for the rollers I bought that had way too much backpacking.
12-01-2025, 07:11 PM
#256
Thanks, have you picked tires and rims yet?
12-01-2025, 07:16 PM
#257
Sharris2
Leaning heavy toward Forgestars that many others have used. Not locked in, so we shall see!
12-02-2025, 02:26 AM
#258
Papa
FYI, Forgestar is running a 20% off sale right now, even for custom wheels.
I waited and watched for about a year for custom Forgestar wheels to go on sale and it didn't happen so I bought them full price....
Papa thanked for this post
12-03-2025, 07:19 PM
#259
12-03-2025, 09:31 PM
#260
Hey Dave,
You may want to go with these Hubcentric Spacers instead of pair you are running.
https://www.americanmuscle.com/musta...50-5450-e.html
They really do a good job keeping the wheels centered.
12-03-2025, 09:44 PM
#261
GoDadGo
Steve,
Thanks for looking after me! The spacers are just for the roller wheels that I won't be using on the road at all ... rear tires are 100% slick.
12-04-2025, 02:13 PM
#262
Papa
Steve,
I'm glad you won't be using spacers.
Those things scare me even though they are widely used.
12-04-2025, 07:32 PM
#263
I really like the way you ran your brake lines … super clean and simple … pretty sure I’m going to copy that setup when I’m ready.
12-04-2025, 08:07 PM
#264
Lugnut Mark
Thanks, Mark. I mostly followed Paul's (edwardb) example.
12-05-2025, 05:34 PM
#265
Post Thanks / Like - 0 Thanks, 3 Likes
12-06-2025, 05:10 PM
#266
12-06-2025, 06:41 PM
#267
Looks nice Dave. I think the toughest part about applying those wraps is keeping the "weave" lines straight. I don't see anyone do it here but another option for items like this is to have them hydro-dipped. I had pieces for my 69 dash dipped and they came out great but they are also complex shapes which is where the HD shines.
12-06-2025, 07:39 PM
#268
Here is a capture from the video showing the available indicators on the gauge.
Turn signals left/right
Check engine
Parking brake
Cruise control
High beam
12-09-2025, 04:12 PM
#269
12-09-2025, 04:53 PM
#270
Fuel lines look nice all finished up. I am surprised you decided to run the return line to the front. I just couldn't bring myself to do it. I have that same deburring tool and it works just as well on stainless. Makes for really clean flares.
I've not seen flat comm cables like that used for gauges but it's kind of cool. I suppose you trade off the neatness of having the individual wires corralled to trying to corral flat cable but it looks tidy.
12-09-2025, 05:02 PM
#271
Thanks, Tim. I want to try my best to keep the wiring clean on this build. I'm documenting all my custom wiring as diagrams in my build folder as I go.
On the return line, I like the regulator in the engine bay and running a few feet of hard line isn't that difficult.
12-09-2025, 05:47 PM
#272
On another note, I've been playing with ideas for the dash and other interior features to go along with my modern take on the Coupe. I came across this head unit that I think would look fantastic in the dash.
It is the size of a double-DIN but mounts in a shallow single-DIN cage. I don't really want a stereo but would love to have the GPS navigation via Android Auto and the backup camera display would be another big plus.
I also found a carbon fiber steering wheel that I'm very interested in using.
I'm going to get another hub for my I.E.427 turn signal setup from Frank. He does a hub with the NRG quick release, and I've asked him to do one for me. With that, I can mount the NRG slim carbon fiber quick release and this steering wheel.
12-10-2025, 07:02 AM
#273
Love the steering wheel choice … the d shape will definitely be a plus for a taller gentleman like myself
12-10-2025, 04:39 PM
#274
I bought my seats today! I decided, after following a lot of rabbit holes, to go with the Sparco R100 seats since I know they will fit and they seem to get solid reviews for build quality. I saw a post in @PNWTim's posts on the seats that mentioned flat bar mounts. That gave me an idea how I might mount these.
Going off an idea using a piece of bar stock on each side that has a couple of bolts counter sunk and welded into the bar with the bolts going through the seat pan in the car and held with nuts. The bars would first be attached to the seat bottom in a similar way using counter sunk bolts into the mounting holes for the seat tracks. I'll mount the bars to the seats and then drop the seats with the welded bolts though holes in the seat pan and attach with nuts from the underside of the car.
12-10-2025, 05:12 PM
#275
Wilwood brakes and a Coyote engine is a killer combo. Taking it slow is smart, you catch way more mistakes that way. Good luck with the build, following along.
12-10-2025, 05:29 PM
#276
Papa
Or if you didn't want bolts sticking down under the car, you could run the bolts up from underneath through the seat pan into your mounting bars that have been drilled/tapped. Button heads would be the most shallow and look nice. That's what I'm doing.
Just a thought
12-10-2025, 05:35 PM
#277
JimStone
Just a thought
I like that idea! Thanks Jim.
12-10-2025, 09:19 PM
#278
Dave - I have spent the last couple of weeks fooling around with my seats and mounting them. I am very motivated to use sliders but that has introduced a myriad of issues. To stay within the confines of the floor pan they need to be mounted as far aft as possible to catch the floor pan steel. One of the bolts ends up in a frame member but I'm OK with that. I welded nuts to the inside of the tracks to be able to bolt from the exterior upwards. Needless to say, this is pretty fiddly.
Just today I was contemplating welding a 3/16" steel strap "box" with countersunk bolts tacked in place to mount the sliders to. That way I can drill through that bracket anywhere I want. Lots of ways to do it but some are definitely easier than others.
12-10-2025, 09:55 PM
#279
PNWTim
These challenges are a fun part of the build. I like thinking of ways to solve these sorts of things. Probably a hundred ways to make it work. In my MK4, my seats are mounted as far back as I could get them. I've never needed to adjust them, so I'm not doing sliders in the Coupe. We'll see if I stick with that once I have the seats in the car and can sit in them.
12-17-2025, 08:14 PM
#280
