Likes Likes:  2
Results 1 to 15 of 15
Thread: Speedometer and speed sensor question
    Nov 2023
    I've got another loose end to tie up.
    I have driven my car a couple of times, and so far all is well...except the speedometer. I get no indication of speed on the speedometer. I thought it might need a calibration, but I did that today and still the same thing. I checked my wiring on the speedo and it all checks out according to the wiring schematic. I have the TKX 5 speed, so whatever sensor those come with, which plugged straight into the harness. I also have the standard Autometer gauges. All other gauges work, including the tach.
    Now I'm wondering if the sensor could be bad. When I did the calibration, the odometer is supposed to show a number that is the number of pulses seen. That number was at 0 the whole time. So, obviously, I'm getting no signal to the speedo. I'm thinking bad sensor or bad wiring.
    Anyone have a way to test the sensor? I also noticed that the 2 wires on the sensor are green and gray. At the speedo, the green wire is used and the gray is for speedo EFI return, which is not used. Do I have something wired up wrong? I was thinking I could hook up my O-scope and check for signal coming out of the sensor, but not sure if that will work. Appreciate any help.
    Nov 2021
    Toronto Ontario Canada
    You don't t have a GPS signal from the sensor. Is it located in a spot open; not covered by metal?
    Mar 2024
    Shawnee,KS
    Quote Originally Posted by Sharris2 View Post
    The standard Autometer gauges aren't gps I believe.
    Nov 2020
    Damascus OR USA
    If you are using VSS there is no signal unless the car is moving. The transmission must be turning to generate the signal.
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
    San Jose, CA
    I could be way out in right field on this. I haven’t work with a TKX before, so I’m not sure how they are setup internally, but have you taken out the speed sensor to see if it even came with a gear attached? Some speed sensors that I have bought and seen don’t come with one, because the gear needed depends on your setup.
    Nov 2023
    No GPS on this unit.
    Quote Originally Posted by TrackDay17 View Post
    This is correct.
    Quote Originally Posted by PNWTim View Post
    During calibration, the car is moving. I drove it for over 2 miles.
    Quote Originally Posted by Steve1979 View Post
    Interesting thought. I'm not sure how I'm going to check this, because the sensor is very difficult to get to. I may end up calling tremec and ask them.
    Oct 2022
    There are two wires from the sensor, green and grey. Up in the dash harness the green wire attached to the speed input of the speedo. They grey wire is grounded. Do you have the grey wire grounded?
    I assume you're using the internal VSS on the RH side of the TKX. Very unlikely it's bad. The two wires from the TKX VSS are high signal and low signal. Typical for non-GPS speedos is green wire to the "IN" connection on the speedo and grey to ground. Hopefully that's the case for yours. Although I've often heard from others it doesn't matter. Just so one side is grounded. This has come up before and it usually solves the problem you're describing.
    The mechanical VSS location on the LH side is typically not used unless you need a mechanical speedo cable - who does that any more - or some other unique reason. The transmission comes with that location covered and should stay that way in your case.
    O'Fallon, MO
    There are NO gears on the speed sensors on new transmissions.
    Apr 2025
    I too have some confusion on this, I have the dash harness speed sensor wires green hooked to gauge, grey grounded. Speed sensor plug on rear harness plugged into tkx trans supplied sensor as described. However there are two additional wires green and grey on the engine side bundle that I have no idea what to do with? I have the same setup as post author. I have no tested mine yet so who knows. I assume the additional wires are just capped not for use.
    Quote Originally Posted by JohnnyDeere View Post
    There are two sets of speed sensor wires. Both from the same source. One in the dash harness and one in the sender harness. Just cap the sender ones if you don't need them.
  12. Likes PNWTim liked this post
  13. #12
    Apr 2025
    Thanks man!!
  14. #13
    Sep 2024
    Spencerport, NY - near Rochester
    I believe your speedo is electronic. If so, Rf harness plug plugs into PS of transmission. Wires then go to dash harness, and the green/grey wire stubs in the dash harness are green to speedo and grey to ground.
    Pat
    MK4 complete kit Nov 2024, Blueprint 347, TKX, Hyd clutch, IRS, 3.55, touring shocks, 17" wheels, 11.65 brakes, Build Thread
  15. #14
    Oct 2020
    Albany, NY
    Quote Originally Posted by Dgc333 View Post
    This was my issue on my first build. I don't remember if the manual tells you to ground it or not. The other is the TKX uses a different connector than the RF harness. The RF harness comes with a connector for the foxbody T5.
    You need one of these
    https://www.amazon.com/dp/B01EEO84BY...d_asin_title_1
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  16. #15
    Nov 2023
    Mystery solved!
    To all those that called out the gray wire to be grounded, you win a stuffed toy.
    I came here to post my solution and lo and behold several of you have the answer. I went to a car show this morning and got a lot of compliments, but I kept thinking about this speedometer. I got home and looked at the RF schematic and then the Autometer speedo manual. From that a figured out that the gray wire, which is labeled "EFI Speedo Signal Return" needed to be grounded. Initially I ignored this wire, 1) because I don't have EFI and 2) because the manual did not mention connecting anywhere (at least that I remember). I put a temp alligator clip on it and it started moving as soon as I drove the car. That made me happy. I just got back from calibrating the speedo and all seem well. Thanks for the help everyone.
  17. Likes BornWestUSA liked this post
