0
17
Originally Posted by
JTG
A little more progress, we assembled the front rotors and started adding safety wires. I will probably have to finish that later on my own since my son had zero interest in helping. He liked the spinning twisting part, but feeding the wire through the head of the bolts was too fiddly for him.
We also pressed the studs out of the rear hubs using the bench vise with a notched piece of pipe method. Thanks to whoever came up with that idea!! It worked great.
We still need to grind flats into the new studs before installing, and we'll probably get around to that this weekend.
I know I have seen some builders grinding those flats you refer to but I did not need to that on my build. I'm not sure what the difference is be my studs cleared the hub of the hub easily.
