Likes Likes:  21
Results 1 to 31 of 31
Thread: No sidelines just dumping out the side.
    Feb 2026
    Hello all. I was wondering on the Mark 5 if anyone just dumps out the the side of the car. If so what did you do. How loud. Did you put anything in the exhaust to quite it down. I like the look of the mark 5 sides and just want to have an option.
    Thanks all.
    Paul.
    What???
  3. Likes BEAR-AvHistory, Avalanche325 liked this post
    Sep 2022
    See AAron's build thread. He made a muffler and exhaust system just as you described, but his was for a MkIV chassis. I'm not sure the exact same design would work on a Mk V
    Craig C
    Stafford Virginia
    What are sidelines?
    Dec 2018
    Hudsonville, MI
    Quote Originally Posted by jrcuz View Post
    What are sidelines?
    Those are sidepipes on autocorrect.
    Coupe Kit Delivered 11/10/23
    Mar 2024
    Shawnee,KS
    To me side pipes are just part of the cool factor of a Cobra.
    Are they loud ? Yes. Are they hot as hell and a danger without heat shields ? Yes
    My car isn't at the running stage yet but I understand the new MK5 pipes are a little quieter than the old ones.
    I'll wear my ear plugs or noise canceling air pods.
    My hearing has been damaged I'm sure from kart racing, being around my dad's sprint cars and racing motorcycles.
    I will say that AAron's pipes that he built are the coolest thing I've seen, if I was talented as a fabricator as he is I might try that one myself.
    Not a look I would want, but to each his own.
    A larger concern would be how much exhaust you'd be getting in the car and breathing.
  9. Likes GoDadGo liked this post
  10. #8
    I ran some chambered race mufflers during testing that had a 3" inlet and outlet that were offset on both ends.
    https://youtu.be/PCngiKoopkA
    They were Flow-Master 3" single chambers, but I don't see them online you might be able to find something similar to quiet things down.
    https://www.summitracing.com/search/...ies%20Mufflers
    https://www.summitracing.com/search/...-race-mufflers
  11. #9
    Dec 2021
    Flower Mound TX
    That's what happens when it gets cold.
  12. #10
    That's what happens when it get cold.
  13. #11
    It Can Happen To Us All!
    https://youtu.be/GG2dF5PS0bI
  14. Likes Mike.Bray liked this post
  15. #12
    Jax Beach, FL
    I was at a vintage race and there was a real one with pipes like this. OMG it was loud.
    The owner brought his private 18 wheeler hauler. 4 289s, a 427 comp, GT350, and a Terlingua Mustang. And paid hot shoes for all but the 427 which he drove. You know, just a little weekend fun. 2 of the 289s took each other out with some heavy body damage.
  16. #13
    Exhaust outlet like a Pro-mod? Just one large hole in the fender..?
    Several of the original Shelby Cobra Snakes had short exhausts, basically just a header..
    https://theshelbycars.com/the-shelby...-racing-cobra/
  17. #14
    Husband/father/son
    Greenville, SC
    Quote Originally Posted by Cobra roadster View Post
    Thanks all.
    Paul.
    Are you looking more for a 289 FIA style undercar exhaust with turn outs just in front of the rear wheels?
    Instead of being part of the problem, be part of a successful solution.
    HOW TO BUY A USED COBRA
  18. #15
    Jul 2021
    Tonganoxie, KS
    "I just got out of the pool!"
  19. Likes StangRacer, Mike.Bray liked this post
  20. #16
    Think he is looking for what was called dump tubes. Look looks like Papa's photo of the white car.
    Kevin
    MKIV #8234
    NITTO NT01 275X40XZR17 - 315X35ZRX17
  21. #17
    Feb 2026
    Hi guys. More like a pro-mod. Wondering if anyone has done it. If so how did they accomplish it.
    Thanks.
  22. #18
    Spicewood, Texas
    If you're going to run the exhaust out the side like a pro mod you absolutely must add twin turbos to justify the look....
  23. Likes Railroad, Mike.Bray, Geoff H liked this post
  24. #19
    Dec 2021
    Flower Mound TX
    Turbos are mufflers, right?
  25. Likes AaronR liked this post
  26. #20
    Right sort of. The Dodge Neon SRT-4 came stock with no muffler only a turbo.
    Kevin
    MKIV #8234
  27. #21
    And a cat... Catalytic converters do a lot of muffling.
  28. Likes BEAR-AvHistory liked this post
  29. #22
    Mar 2024
    Shawnee,KS
    I had forgotten about this car but I'm guessing this is something like you are talking about.
    While it does look cool I can't imagine driving it around or the reaction from your neighbors and your local police.
    https://youtu.be/F838mLe186A?si=ii2xuGac0hmaFz1X
  30. #23
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by TrackDay17 View Post
    Nice car, I love the no quickjacks.
    Open zoomies, open car, and a sound system. Perfect.
  31. #24
    It's stupid loud
    Mar 2024
    Shawnee,KS
    It's stupid loud
    Stupid fast too it appears.
    It reminds me of my KTM Supeduke with the carbon fiber straight through mufflers on it.
    I started it with no db killers in it and it set off my neighbors car alarm immediately when I started it.
    I put the db killers in it but it was still pretty loud, sounded glorious on the racetrack though.
    Corner workers told me it was the best sounding bike on track.
  33. Likes cc2Arider liked this post
  34. #26
    Woodstock ,Illinois
    Hot Rod Brothers has a car with straight-pipe zoomies. I've driven with that car and in spite of over 900hp, it's relatively quiet at cruise. Not so much when you mash the pedal though!
  35. #27
    Kevin
    MKIV #8234
  36. #28
    Sep 2022
    Cheetah!
    I saw one in-person around 1983 or so...haven't seen one in-person since
    Craig C
  37. Likes BEAR-AvHistory liked this post
  38. #29
    Dec 2021
    Flower Mound TX
    https://www.hagerty.com/media/market...41c27dcb453682
  39. #30
    I think that was up on Bring-a-Trailer just a short while ago.
  40. #31
    Here it is -- $520K!!!
    https://bringatrailer.com/listing/1966-cheetah-coupe/
    Something is whispering Lightning McQueen in the back of my head ...
