5
Hey guys. Got to box 25 tonight. I got a little confused with the names of the e-brake parts. I've included some pictures. But I think I'm missing one of the 3 nylon bushings, a 3/16" and 1/8" spacer, the handle to ratchet mount spacer and the 1/4" female rod end. I have the male rod end. I believe the large rectangular plate with a few holes in it is the "handle support". I also believe the two long L shaped brackets might be the "handle to ratchet mounts". I think the 2 smaller 90 degree angle brackets are the "e-brake mounting brackets".
Another thing I thought was odd is that my speedometer is NOT the reverse read. For the 30th Anniversary Coupe it specifically said it would have the reverse read. Has anyone else noticed this?
Any final question for tonight. James at BluePrint said for Coupes he makes sure to send the TKX with the shift mount moved forward so you can have the straight rather than angled shifter. The shifter I got from Factory Five was the angled one. Do I just need to call Factory Five for a swap? Or do they only send the angled one because that's all they have?
Thanks guys!
