Lisle Radiator Burp Kit
I think I added my coolant back into the radiator a little too quickly after I cleaned up and replaced the petcock, as I pulled out 3 gallons of coolant but only 2 will go back in. I’ve elevated the car and squeezed the hoses to help get some of the air out, and also opened the upper petcock while filling until fluid came out but still have lots more room for more coolant
I have a Lisle funnel. Would that be the best bet for burping in a situation where I think I need to add quite a bit more coolant or is there a better method?
cv2065
It certainly won't hurt. We have a 2005 Jeep GC with a 3.7L. They are a PITA to bleed so I use my Amazon knock off funnel.
FFR Cobra MK3 F5R100 5447 donor kit - picked up Jan 4, 2025 started build March 28, 2025
Build thread here
When I filled my engine, I removed the temp sender from the intake manifold to keep out air pockets in the engine.
runamuk
when i filled my engine, i removed the temp sender from the intake manifold to keep out air pockets in the engine.
winner, winner!
x3 on removing the temp sensor from the manifold. That's the hot ticket. Very little burping needed after that.
Greg
Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
Post Thanks / Like - 2 Thanks, 0 Likes
