Thanks Thanks:  4
Likes Likes:  2
Results 1 to 5 of 5
Thread: Lisle Radiator Burp Kit
    Dec 2017
    I think I added my coolant back into the radiator a little too quickly after I cleaned up and replaced the petcock, as I pulled out 3 gallons of coolant but only 2 will go back in. I’ve elevated the car and squeezed the hoses to help get some of the air out, and also opened the upper petcock while filling until fluid came out but still have lots more room for more coolant
    I have a Lisle funnel. Would that be the best bet for burping in a situation where I think I need to add quite a bit more coolant or is there a better method?
    Jun 2018
    Bettendorf, Iowa
    It certainly won't hurt. We have a 2005 Jeep GC with a 3.7L. They are a PITA to bleed so I use my Amazon knock off funnel.
    FFR Cobra MK3 F5R100 5447 donor kit - picked up Jan 4, 2025 started build March 28, 2025
    Build thread here
  3. Likes cv2065 liked this post
    Jan 2021
    Fort Lauderdale, FL
    When I filled my engine, I removed the temp sender from the intake manifold to keep out air pockets in the engine.
  5. Thanks cv2065 thanked for this post
    Likes BEAR-AvHistory liked this post
  6. #4
    Quote Originally Posted by runamuk View Post
    when i filled my engine, i removed the temp sender from the intake manifold to keep out air pockets in the engine.
    winner, winner!
  7. Thanks cv2065 thanked for this post
  8. #5
    Jul 2021
    Tonganoxie, KS
    x3 on removing the temp sensor from the manifold. That's the hot ticket. Very little burping needed after that.
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  9. Thanks cv2065, BEAR-AvHistory thanked for this post
