Thanks Thanks:  25
Likes Likes:  63
Page 5 of 5 FirstFirst ... 345
Results 161 to 171 of 171
Thread: Einstein's Mark V Roadster Build
  1. #161
    Mar 2025
    Eastern Long Island NY
    More fun in the unexplored territory of jamming a Godzilla in a roadster. In an attempt to line up the driveshaft, I made a spacer from a piece of 3/4"aluminum I had in the scrap metal bin. By luck, it seems to be very close to perfect. Now to get everything torqued down and on to the next thing.
    Getting the driveshaft in was one of those things where you try it 50 times and then, for some unexplained reason, suddenly it drops right in lol.
  2. #162
    Mar 2025
    Way to Go Einstein
    Well....I wanted a challenging project because "it will be fun". I am really having "fun" now. Getting the giant Godzilla engine in was not that big a deal. Fabricating spacers to align the driveshaft was ok. Now I am on to installing the headers. The stainless steel headers from FFR are beautiful. What bolts to use? Stage 8 and ARP don't make header bolts for the Godzilla. Nobody makes the aftermarket header gaskets people like so much on the forum for the Godzilla. I ended up getting high-quality SS M10 1.25 bolts from McMaster Carr and SS Nord-Lok lock washers (we have used these before on aircraft). I ordered OEM gaskets from Ford Performance, which came with OEM studs. There was no way to use studs because you could never get the headers on.
    Getting the driver's side header on was one of the hardest projects I have ever had. I bruised the bone in my wrist trying to get the bolts started. I finally got it installed with lots of zinc high-temp anti-seize on the SS bolts going into the aluminum heads. In my football days, I used to put black on my face under my eyes to cut glare. By the end of the game, despite wearing a full facemask helmet the whole time, I always had it spread everywhere. I do the same thing with anti-seize. It gets on stuff I didn't even touch!
    Now on to the passenger side header. The driver's side was super difficult, but the passenger side is impossible! There was no way to even get the header in there without removing the dipstick tube. The dipstick tube was trapped between the block and the engine mount. I managed to get it out and put the header in place, but there would be absolutely no way to get it back in. As for putting in the header bolts ...NFW!
    So what now? I called FFR and got them to send me a new inner passenger footbox panel. I plan to cut a big hatch in that panel, which will allow me access to the header bolts, dip stick tube, and will make accessing the starter easier. I will cut the hatch cover from the new panel with an overlap and use sheet metal screws with star washers. Then I will put the hoist back on the engine and raise it as I loosen the engine mount bolts from the block. That should allow me to get the dipstick tube back in. Then I can torque down the header and engine mounts. I will leave the hatch off until after the go-kart stage.
    My great plan of mounting the brake reservoirs before I even had the engine did not go well. There is no way they will fit where i had them. i ordered a Tilton reservoir and will mount it just where Edward B did. I know...I should have listened to him.
    I am writing this now, before I do all of this, in case any of you have a better idea. I can't think of anything unless you have a mechanically inclined spider monkey.
    I will post pics when I figure out why they won't post
  3. #163
    I had the same issue with my Roush engine. The oil dipstick was interfering with the headers, but it was on the driver's side. Total PITA. I had to replace with a flexible dipstick then put it around the back of the header with a fabricated bracket as it wouldn't fit in-between. I was able to reinsert from underneath. You have even less space so I feel your pain but it will be worth it.
    If you can't navigate the headers and dipstick from underneath, I'd say the footbox hole sounds interesting.
  4. #164
    Nov 2022
    Niles, MI
    I have a 5 year-old you could borrow. Small hands...
    Blueprint LS3 427, T56, IRS
    Received: 5/24/2024
    First Start: 2/7/2026
  5. Thanks Aleinsteingenius thanked for this post
    Likes Aleinsteingenius liked this post
  6. #165
    Nov 2020
    Damascus OR USA
    Quote Originally Posted by Aleinsteingenius View Post
    "Build a car", "it will be fun" said no one ever...
    I worked in a wooden boat restoration shop when I was in college. We used a lot of Sikaflex 241 which must be chemically related to anti-sieze in another universe. We nicknamed it "dogetaround". If you weren't careful you'd have it in your hair, under your shoe and somehow between two ones in your wallet.
  7. #166
    Dec 2021
    Flower Mound TX
    Like this?
  8. Thanks Aleinsteingenius thanked for this post
    Likes Aleinsteingenius, CW_MI, JimStone liked this post
  9. #167
    Mar 2025
    I have done a lot of yacht restoration. I know Sikaflex well. It's even harder to clean up than anti-seize
  10. #168
    Nov 2022
    Niles, MI
    FWIW, there is a MkIII with a Godzilla currently on BAT bid up to $110,000 with 4 days left! Good investment, me thinks
    Received: 5/24/2024
  11. #169
    Quote Originally Posted by JimStone View Post
    You realize that's not a FFR, right?
    Nov 2022
    Niles, MI
    My bad!!!
    Received: 5/24/2024
  13. #171
    Mar 2025
    I am finding that while a Godzilla will technically fit in a MkV, there are a lot of issues. You have to do a lot of engineering to get everything hooked up properly. i will update this thread with pictures when I can.
  14. Likes Mike.Bray, cv2065 liked this post
