Quote Originally Posted by alexmak View Post
I'm already browsing amazon looking for those monkeys to help I have the same issue, apparently, and the fluid was pretty black. Not looking forward to swapping that MC.
One thing to check if the fluid was black. Did you use the correct brake fluid compliant hoses to the reservoirs? If I recall correctly, Rebostar had a failure and found out that the wrong type of hoses were used (fuel hose) and internally disintegrated over time, causing a failure.
