Thanks Thanks:  25
Likes Likes:  63
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 171
Thread: Einstein's Mark V Roadster Build
  1. #121
    May 2022
    I was able to pass it through the lower opening and grab the frame without issues. I’ve winched it onto/off the trailer several times. The bar that secures the body protects it. FYI
    Build School: 5/2/2025
    Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
    YouTube Channel
  2. #122
    South Carolina
    Quote Originally Posted by Aleinsteingenius View Post
    Now that this beast is finally here. I am set to assemble it and put it in the car after I come back from hip replacement surgery. It SHOULD fit (looks at the car and back at the engine nervously) lol.
    Attachment 221882Attachment 221883Attachment 221884Attachment 221885Attachment 221886Attachment 221887
    LOL. I love the size reference between the ITB's and the Hammer. Looks like you found the right tool to make that thing fit!
    That's going to be something for sure. I can't wait to hear that one start for the first time.
    The Stig
    GTM #0081
  3. #123
    Dec 2021
    Flower Mound TX
    Does the Godzilla have a flat plane crank?
  4. #124
    Dec 2017
    The Godzilla looks to be about the same width as a Coyote (~28") valve cover to valve cover, give or take an inch. Definitely can't wait to see it. I know Backdraft has shoe horned it in but not sure of the body dimension differences. It will look awesome!! To Mike's question, no, the Godzilla does not have a flat plane crank.
  5. Likes Mike.Bray liked this post
  6. #125
    Mar 2025
    Eastern Long Island NY
    The Godzilla does not have a flat plane crank. It is a heavy-duty truck motor with 6 bolt mains. It supposedly is a couple of inches narrower than a Coyote and about the same length as a Windsor. Height is the challenge. I have estimated with the high clearance oil pan and the super short stacks, it will fit under the hood without a scoop. Nothing can go wrong lol.
    I am doing hip PT like an animal so I can get back in my shop and see. Stay tuned.
  7. Likes cv2065, Mike.Bray liked this post
  8. #126
    Mar 2025
    Rickster, I am planning to run an oil cooler in the lower opening. That may require me to invent some sort of tow hook bracket. Maybe that hooks to the sway bar?
  9. Likes rickster991 liked this post
  10. #127
    Dublin, OH
    I am on injured reserve recovering from hip replacement. In the meantime I am thinking about things I should add to my MK V. Has anybody come up with a easily attachable tow bracket for the MKV? I could see a problem winching the car into a trailer or on a flatbed when one of the screw ups I am sure to do bites me.
    Any idea if Martin Lira’s tow bar works for MKV? Roadstertowbar.com
  11. #128
    Mar 2024
    Shawnee,KS
    That engine definitely tops out the coolness factor.
  12. Thanks Aleinsteingenius thanked for this post
    Likes Aleinsteingenius liked this post
  13. #129
    Jul 2021
    Tonganoxie, KS
    The only Ford engine with a flat plane crank is the Voodoo 5.2 in the GT350.
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  14. #130
    It does not.
  15. Thanks Aleinsteingenius thanked for this post
  16. #131
    Mar 2025
    Thanks Jeff (puts on mad inventor hat)
  17. #132
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by gbranham View Post
    Greg
    That's it! I knew one of the Ford engines had a flat plane crank but couldn't remember which one. Thanks Greg
  18. #133
    Mar 2025
    Ok....after 6 weeks of lameness due to total hip replacement I am back! Did you miss me? Now I have to figure out how to get that giant Godzilla engine in the car. First I need to do the clutch, bellhousing, and transmission install. My "beautiful assistant" magically knew I needed a ball bearing engine leveler and a dial indicator for Christmas. Now I have to take her to Florida for a couple of weeks...its 23 degrees here. I hope to have to engine ready to install when we get back. I plan to put the back wheels on the four post lift (As seen on IE 427) and raise it up with the engine hoist sliding under the front. What could possibly go wrong?lol
  19. Likes Mike.Bray, rickster991 liked this post
  20. #134
    Mar 2025
    Progress (sort of)l, a helpfull tip, and the dumb questtion of the week.
    I decided I should get the Godzilla ready to go in the car so its ready when we get back from Florida. The problem with that plan is the engine in its stand was sitting very low to the ground and my newly replaced hip is not crazy about me getting down on the floor. To help with this I used my engine hoist to lift the engine up and put the engine stand on some 4x6s. In order to do this I had to remove the power steering pump and make a spreader bar so the engine leveler would not hit the injector stacks.
    Next it was time to mount the Ram flywheel, but I realized I didn't have the bolts. I also realized I didn't have the bolts for bolting the Centerforce pressure plate to the flywheel or the bolts to attach the Tremec TKX to the Quicktime bellhousing. What bolts should I use? Here is the helpful tip. I went on X and asked Super Grok. That is Elon Musk's AI. It costs $150 a year but is so worth it. In about a minute, it searched all the manuals, instructions, forums, and catalogues in the world. It told me the exact size and rating of the bolts I needed. It even gave the exact part numbers for the Ram, Centerforce, Quicktime,and Tremec bolts I needed!1 (29).jpg
    Once the proper bolts arrived I had no problem bolting up the flywheel and getting it torqued down. Next i needed to check the run out on the Quicktime bellhousing. I watched so many Youtube videos about how to do this that my "beautiful assistant" said "I think you are starting to have a THING about bellhousings". I took the plugs out of the engine so I could turn it over with a breaker bar on the front pulley. Then I had to get down on my knees, attach the magnetic dial indicator to the flywheel then get up, go to the front of the engine, turn it over a quater turn, then go back to the rear of the engine, get on my knees again and check the reading. Then get up move it a little more and get back down on my knees. I did this over and over and over. Every time the dial indicator would come loose from the flywheel and move so I would have to start over (after I put some money in the swear jar each time). I finally gave up
  21. Likes Mike.Bray liked this post
  22. #135
    Mar 2025
    When I was home for lunch, I asked Grok the best way to attach the dial indicator. It said to take out four of the eight bolts, thereby leaving a flat area for the magnetic base to attach. I did that, and it worked the first time. After all of that and after checking numerous times my Quicktime bellhousing was just .00325 out. Well within the allowed .005 limit.1 (30).jpg1 (31).jpg1 (32).jpg
    Now for the "Dumb Question of the Week". What are these things? I found two triangular things and one round spacer of some kind in a box marked Godzilla install kit. I suspect the round thing is for use with a stock style air intake but ?
  23. #136
    Dec 2021
    Flower Mound TX
    Be sure and check the flange on that Quicktime bellhousing that it doesn't hang below the frame rails, you may need to trim some off. You don't want that to be your skidplate!
  24. #137
    Mar 2025
    Good tip Mike. It looks like it sticks down the same amount as the Holly oil pan on the Godzilla, which would be an even worse skidplate.
  25. #138
    Nov 2022
    Niles, MI
    Wild guess here (I know nothing about the Godzilla) but those big powder coated triangle things have similar size/look to the LS motor mount adaptors FFR sent me.
    The things my son is installing
    Again, just guessing
    Gen 3 Coupe #576 - "Project Deimos"
    Blueprint LS3 427, T56, IRS
    Received: 5/24/2024
    First Start: 2/7/2026
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
  26. #139
    Mar 2025
    Thanks Jim. I was leaning that way. i will check on that tomorrow and report back.
  27. #140
    Mar 2025
    Jim, you are right! They are spacers for the engine mounts. There are no installation instructions for the Godzilla so I get to figure this stuff out as I go.
  28. Likes JimStone liked this post
  29. #141
    Mar 2025
    Ok update time. I managed to get the TKX transmission mounted to the engine using my super handy motorcycle lift and the engine hoist. It would be better if you have friends help with this part. Next I will install the Forte slave cyliinder and when we get back from Florida the engine goes in....hopefully. What could possibly go wrong?
  30. Likes Mike.Bray, PNWTim, danmas liked this post
  31. #142
    Mar 2025
    Ok, we are back from Florida and done with all that blizzard nonsense. I am now getting serious about getting the Godzilla into the car. But first...
    When I started this build thread, I said I would not try to show people how to build one of these cars. There are many threads like Edwardb's that do that better than I ever could. Instead, I said I would document my screw-ups so others could avoid them.
    Here is one. I decided to install the pedals, MCs, brake lines, etc., while waiting for my engine to be delivered. I assumed, for some reason, that I would need a throttle cable for my stack system. I spent a week modifying the FFR gas pedal to accommodate my giant feet. When the engine came in, I realized it required a drive-by-wire throttle pedal like a Coyote. Ugh. I ordered one of those pedals, and now I am installing it. I also had to pull the MCs out because I had not properly adjusted them for side-to-side clearance. Since I was going to have to re-bleed the system anyway, I pulled out the reservoirs I had installed to give me more room for installing the Godzilla.
    I found I have a couple of extra Willwood pedal pads, so my current plan is to use one for a dead pedal and one on the cut-off throttle. This will allow me to offset them and make more room for my Frankenstein feet. 1 (41).jpeg
    Next up I will try to organize some friends to help and we will get then engine in. Stay tuned
  32. #143
    Dec 2021
    Flower Mound TX
    I've never seen stacks with DBW, interesting. Any idea what is being used on the stacks for the actuator or whatever it's called?
  33. #144
    Might just be the photo but it looks like that throttle pedal is in the same plane as the brake, or maybe even a little closer to the driver.
    Neither is a good idea. You always want the throttle lower than the brake so that when applying the brakes you don't inadvertently also depress the throttle.
  34. Thanks Aleinsteingenius thanked for this post
  35. #145
    Mar 2025
    Mike,
    Here is a picture of the actuator on the InnoV8 Stacks. I have no idea how it works but I guess we will find out. lol
    Jeff,
    The gas pedal is almost 3" further away than the brake pedal. I have not even tried to do any adjusting yet. I could put it lower but ...the giant size 15 feet thing again. I think I can move the brake pedal over some.
  36. Likes Mike.Bray liked this post
  37. #146
    Dec 2017
    I’m ready for that engine install!!
  38. Likes Aleinsteingenius liked this post
  39. #147
    Mar 2025
    Today I did a dress rehearsal for the engine install. I plan to use the lift to raise the back end of the car, an idea I stole from i.e. 427. I will also use a power socket on the leveler. This is a very heavy engine so I will wait for next weekend when I can gather up some friends. With enough beer and a couple of crowbars we should get it done.
  40. #148
    Mar 2025
    So....is the Godzilla a heavy motor? Yep.
    I used that hoist to install a lot of airplane motors. This is a whole different thing. I am glad the shipping frame was still bolted to the motor. Extending hoist legs waay out.
  41. Likes Mike.Bray liked this post
  42. #149
    Dec 2017
    LOL...Shouldn't be that much different than a 427 SBF. Both should be in the neighborhood of 535-540lbs. A 2 ton crane will easily handle both.
  43. Thanks Aleinsteingenius thanked for this post
  44. #150
    Mar 2025
    It should be fine now. I just had to extend the legs. I didnt even know they could go out that far. I have friends coming Sat to help me put it in. I need one fat guy to stand on the back of the hoist lol.
    Today I test-fit the SS Godzilla headers from FFR. They are beautiful and fit perfectly. This may be the first and only set they have sold. Well done FFR.
  45. Likes RobHartley, Railroad liked this post
  46. #151
    May 2022
    A bag of organic soil goes a long way!
    YouTube Channel
  47. #152
    Dec 2021
    Flower Mound TX
  48. Likes Aleinsteingenius, rickster991 liked this post
  49. #153
    Mar 2025
    GODZILLA!!!!!
    How many guys does it take to install a Godzilla engine in a Cobra? Apparently, 6 and a half.
    Thanks to my son Kyle, son-in-law Steve, friends Craig, Anthony, Shane, and my 8-year-old grandson James, we got it in! I ended up removing the reservoirs and fuel regulator, whose location I had guessed at before I had the motor. I think I can put them back.
    1 (46).jpg1 (47).jpg1 (48).jpg1 (50).jpg1 (51).jpg1 (52).jpg1 (52).jpg1 (53).jpg
    Now on to hooking everything up.
    Some people were concerned that the bellhousing or oil pan might hang down below the frame. I was very concerned about this too. I am happy to report that with that they are nicely above the frame. Phwew!
  50. Likes RobHartley liked this post
  51. #154
    Dec 2021
    Flower Mound TX
    Very nice! Congratulations.
  52. Thanks Aleinsteingenius thanked for this post
  53. #155
    Oct 2020
    Albany, NY
    That is a big son of a ....
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  54. #156
    Dec 2017
    Perfect fit! Looks great!
  55. Thanks Aleinsteingenius thanked for this post
  56. #157
    Jan 2019
    Mead Colorado
    Fabulous!
    Mk4 complete kit arrived 10 May 23
    Current BOM and Build Thread
  57. Thanks Aleinsteingenius thanked for this post
  58. #158
    I never had any doubt that you'd get it in there...somehow!
  59. Thanks Aleinsteingenius thanked for this post
  60. #159
    Mar 2024
    Shawnee,KS
    I can't wait to hear that monster come to life !
  61. Likes Aleinsteingenius liked this post
  62. #160
    Jun 2025
    Vancouver BC
    Looking forward to hearing the monster roar to life!
