The "Week 1 Update" will come a little later today, but I'll answer the questions/comments first:
Re: EPS
Thanks for your comment. I'm still going to try EPS.
Re: Audio System
I'm probably only going to be able to build one of these, so I'm going to try an audio system.
I already have the head unit for mapping & backup camera purposes (I know it's not 'period correct', but it's my car, and I want these things).
Since I have the head unit, it's not too much more to put some speakers in. I might downgrade the Kappas to Reference (about -$200), but the sub is powered so it's pretty cost efficient, and the extra cost is really not that much.
I'm planning for a hard-top for all season driveability, and doing as much noise reduction as I can, so I expect I may actually be able to hear it.
...and if I still can't, I'm okay with that.
Re: Luxury Liner Pro
I was a bit brief on my description. But I will be using a combination of different sound dampener/absorb products in different amounts in different areas of the car. I will likely use Damplifier Pro in some areas where I need thinner material. I'm pretty sure I will have cutouts for the seat mounts. I will have at least a 1" riser on the seat, so I don't expect clearance issues, even with carpet and sound liner.
I know this will be an extreme amount of sound absorbsion for an open-top car. But I am getting the hard top, and I don't want Coupe-level noise when the top is on.
Re: Balance Bar
I was unaware of the purpose of the balance bar, the manual didn't make it clear when I previewed that section. I think I'll drop the balance knob, since all I wanted was a way to balance the brakes.
Thanks for your comments Paul and Jeff. I'm following Paul's mk5 build thread with interest, so it's nice to have your thoughts directly.
I hope you will drop by again after my week 1 update goes up. I have some "?" moments that I could use some insight from more experienced builders on.
Cheers! Update coming soon, I have the photos ready, I just need to write it up.
