Thanks Thanks:  4
Likes Likes:  9
Results 1 to 23 of 23
Thread: How to set ride height
    Mar 2018
    Saint Johns, Florida
    Question How to set ride height
    Hi all,
    I am ready for go-cart now. The manual says to set ride height but does not say HOW to do it. So, I am hoping there are some posts to help me.
    Thanks in advance for any help.
    Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
    vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
    Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
    Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
    On a roll
    Wheaton, IL
    I'll get the ball rolling for you: you set the ride height by adjusting the collars on the coil over dampers. The key is to ensure that you adjust them all the same so your car is at the same height at each corner. Jack it up a bit and then you can rotate the collar either up or down to set the height. Screwing them down, obviously, makes the car sit higher. I'm pretty sure that others will add more here...
    Method I use, learned via this forum quite some time ago:
    1. With suspension hanging, turn all four adjusting collars until they just touch and hold the springs in place.
    2. Lower the car. Bounce up and down a couple times. Even roll it back and forth a little. Idea is to make sure the suspension is settled.
    3. Measure ride height front and back.
    4. Jack car back up, and turn each front and rear pair side-to-side exactly the same amount, e.g. both fronts two turns, or both rears three turns, or whatever. Doesn't have to be the same front to back, but always the same side-to-side. Typically after step 1, the ride height will be too high and you have to loosen them.
    5. Repeat 2, 3 and 4 until desired ride height is achieved. You'll want it to be 1/2-inch or so high at first on a new build because it will settle.
    6. You may find when done that side-to-side isn't 100% exact. Within reason, it's OK. Don't adjust just one side or the other based on ride height measurement alone.
    The other method for setting ride height is via corner weights. A scale is put under each tire and adjusted accordingly. Most important for a track car. Not so critical for a street car. Note on my #8674 build, I used the method above to set ride height. Later had occasion to borrow a corner weight system. It was so close no further adjustments were necessary.
  4. Thanks Drezx6r, Geoff H, 2nd2none, RobHartley thanked for this post
    Likes Drezx6r, JimStone, 2nd2none, Oshkosh Rob liked this post
    Mar 2018
    Cool Thank you for info
    Thank you so much,
    It is an iterative process as I suspected. Your info helps me a lot.
    Thanks again,
    mburger's Avatar
    Punta Gorda FL
    Excellent info. Just to add, while it may be obvious to most, you measure from the bottom of the tubular frame to floor.
    Mark
    Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
    I would ad just one step. When you do the initial setting like EdwardB says just touching the springs I also like to count the # of threads visible beyond the collar. Since not many have the ability to check corner weights I trust FFR welded the frame correctly. So you want the same # of threads on the left as the right. Front and rear will usually be different but left should = right.
    Oct 2017
    You mean compressing the spring makes the car set higher. some shocks, such as the double adjustable Koni's, the adjusting collar is below the spring, not on top of the spring.
    MK4 #9191, Gen 3 Coyote, T56, 2015+ IRS, ABS, 12.88 Wilwood's, FFR Tubular Front LCA's, FFR Spindles
    On a roll
    Wheaton, IL
    Quote Originally Posted by dhuff View Post
    Yes. I wrote my comments based on my setup. Here's an old photo that shows it, more or less:
    My dampers have a single collar, above the spring. Effectively, you are compressing it, but in actuality, you're raising the damper body relative to the spring.
  10. #9
    Seguin, Texas
    I saw in your car description that you have sway bars. Be sure they are disconnected on one end when you do any adjusting on your shocks.
    Texas Cobra Club-Austin
    July 2009 FFCars Picture of the Month
    FFR3542K, 347 C.I., EFI, T-5, 3-Link, Miata Front Sway Bar, Red with White Stripes
  11. #10
    Folsom, CA
    Quote Originally Posted by seagull81 View Post
    oh didn't realize this!
    Todd
  12. #11
    Nov 2016
    "The i.e." SoCal
    I use 2X4 blocks that I cut at increasing length. So I have blocks that are 4", 4.25", 4.5", 4.75" and 5". They act as a go/no-go, rather than trying to get a measuring rule of some kind in-between the frame and the ground. The other thing to remember is to do your measuring on a flat level surface.
    Aug 2022
    Portland, Oregon
    great idea, I have a wedge I use for my formula car, that way I can slide it under my measurement point. Always make sure you measure at the same spot, and as was noted in another post, level flat surface and is great if you can always put your car in the same place every time. I have to put plywood sheets under my tires due to the garage slope to get a level surface, and this can affect the measurements as well. My garage floor has a center crown that I have to be aware of as well so there can be some environmental things to consider when doing this.
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
  14. #13
    Dec 2021
    Flower Mound TX
    I never go anywhere without my trusty ride height gauge https://www.summitracing.com/parts/qcr-56-108
  15. #14
    Jun 2020
    Danville CA
    I cut a painter's wooded stir stick to my desired ride height. If there's a gap between the car and floor, the car is too high. If the stick don't fit, it's too low. I made the adjustments with 200 pounds of bricks in the drivers seat and half a tank of gas.
    Then I borrowed some corner weight scales. I found someone willing to lend them to me by putting out a post on a local Face Book track car group.
    Then I got a final alignment with me sitting in the seat.
  16. #15
    Dec 2023
    I set my initial ride height with (3) 2x4 pieces of wood. Works out to be 4.5 inches.
    For the corner weighting at the end I plan to get 4 scales from Amazon (rated to 550lb or 600 lbs). Should be about $100.
  17. #16
    Jul 2024
    6. You may find when done that side-to-side isn't 100% exact. Within reason, it's OK. Don't adjust just one side or the other based on ride height measurement.
    I’m just getting around to adjusting these collars on my MK4 go-cart. Is there a special tool that grabs these and was it included in the kit? Don’t wanna dig thru a bunch of boxes for no reason. I don’t remember seeing such a tool? Recommendations to purchase? Thx
  18. #17
    Dublin, OH
    Quote Originally Posted by Windsorpower View Post
    The tool you need is called a spanner wrench, and no, it is not included in the kit.
    Most of use just will unload the suspension and turn the collar by hand to adjust the height. remove the set screws as well in the collar as they can mess up the threads on the shock making it difficult to spin the collar.
  19. #18
    Houston, TX
    My kit, ordered Jan 2024, came with a F5 made spanner wrench. It’s a combo tool, also used for setting the rivnuts for the door latch. Could be worth checking through your boxes. But as mentioned earlier, it’s easy enough to spin by hand when unloaded.
    Build 2: Mk5 Complete kit | Coyote Gen 4X | TKX | IRS | Brake Booster | Traction Control | Ordered: 3/18/2026 | Build Thread
    Build 1: Mk4 Roadster | Coyote Gen 4X | Ordered: 1/31/2024 | Delivered: 4/11/2024 | First Start: 8/9/2025 | Legal: 11/5/2025 | Crashed: 2/16/2026 Build Thread
  20. #19
    What he said. I've never received any tools with kits from FF. Including the most recently received Mk5. As noted, with the car jacked up and the suspension unloaded, you can turn the adjusters by hand. If you really insist on having a tool, there are many available. I have a Joes Racing 33500 Short Coil-over Spanner Wrench. Nice tool. About $40 on Amazon. I haven't used it much.
  21. #20
    Jun 2015
    Fairfax Station VA
    As Chewy says, a wrench is generally not needed. But one time I had a shock sag enough that I needed the wrench to get back to ride height.
    A Williams 0-472 works perfectly. I got mine from Mark Reynolds at Breeze.
    MK IV Roadster #8631
  22. #21
    Houston, TX
    Interesting. This is what came in my kit. Basic, but works.
  23. #22
    Nov 2023
    I got a spanner wrench with my kit. Actually, I think it came with the Wilwood brakes that I ordered from Gordon Levy. I might have a spare that I could be talked out of.
  24. #23
    My feeling is that you are better off letting the suspension hang and turning the collars by hand. It is really hard to turn an aluminum collar on aluminum threads and any lube one uses will just attract dust.
  25. Likes ProfessorB liked this post
