Thanks Thanks:  50
Likes Likes:  156
Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 441 to 480 of 511
Thread: Rick's Mark V Roadster Build
  1. #441
    May 2022
    I bent the arms of the windshield and it went in fine. Quick question for the experts… After marking the holes, one of the sides is not parallel. Do I simply drill the holes in the center of the arm and parallel to the sides? Or do I drill where the marks are. The marks make it even on both sides, and where it wanted to lay. I figured in the center??? Or will that twist it and stress the windshield? Any advice, as always, is greatly appreciated!
    Build School: 5/2/2025
    Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
    YouTube Channel
  2. #442
    Quote Originally Posted by rickster991 View Post
    Yes, just transfer your marks over to the center. Life will be much easier for you if you drill and tap the windshield arms rather than drilling through and using nuts and bolts. On my Mk5 since space is tight and getting a tool (specifically a 3/4" swivel socket on a 1/2" bolt) in there I used 3/8" socket head bolts which can be more easily accessed with an allen socket with swivel. Just something you might want to consider. Oh, by the way, don't forget to shim as necessary to take up any space between the windshield arms and chassis!
  3. Thanks RobHartley, rickster991 thanked for this post
    Likes 2nd2none liked this post
  4. #443
    May 2022
    YouTube Channel
  5. #444
    May 2022
    So I made progress on the windshield, but I’m stuck. I couldn’t get it to line up, so I figured my bends were wrong, and it was twisted. So I installed the rails without the glass and tightened them so my measure was exact on both sides, 27.25”. I then installed the glass in one side and my angles were way off. So I bent them so they aligned. I got it so the top of the glass fit perfectly. When I went to install the lower bolts I am 1/4” off! Everything I read said to make sure to use spacers to not stress the glass! Are the spacers used so the rails are at an angle? What am I doing wrong? As usual any advice is appreciated!
    YouTube Channel
  6. #445
    May 2022
    Should I bend the mounts a bit?
    YouTube Channel
  7. #446
    Southern Ontario/Cape Coral FL
    I wouldn't bend the mounts. It looks as though you have spacers in there but need them.
    Higgy
    MK4 #11354 picked up 10/06/25
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24 SOLD
    MK4 #10616 picked up 4/10/23 SOLD
    MK4 #9759 picked up 4/3/19 SOLD
  8. #447
    No, but you can put some twist into the side posta.
  9. Likes rickster991 liked this post
  10. #448
    May 2022
    I’ll give that a shot. FFR says to simply attach glass and put spacers. I’ll keep everyone updated.
    YouTube Channel
  11. #449
    May 2022
    Quote Originally Posted by Higgybulin View Post
    Higgy
    No spacers. The rivnuts add a 1/16” combined.
    YouTube Channel
  12. #450
    Aug 2025
    Saint Augustine, FL
    Today I worked on wiring the dash. I finished all the connections according to the manual. Fingers crossed it all works.
    Attachment 216111
    A few questions.
    1. I couldn't find a corresponding ground wire for the light switch. I assume I can just tie it to the chassis or any any other available ground wire.
    2. The dimmer for the gauges requires constant power. I hooked it to the battery terminal of the starter switch, Is that acceptable?
    3. Do you use the wires provided with the Oil/water sensors or do you use the wires in the harness? I thought it would be easier to simply using the connectors/wires provided.
    Attachment 216113 Attachment 216114 Attachment 216115
    I then proceed to mock up the AC evaporator. The only way I could get the lines to not run into the frame was to mount it at a slight angle. I used some angle brackets along with the provided brackets to get 4 points of contact. I was reading some posts and some people forego using the bulkhead connectors. It seems that It would be a pretty tight fit with them in there. I mocked it with just the grommets. I would just need to figure out a place to put the connectors with the valves. Can they both be connected at the compressor?
    Attachment 216117 Attachment 216126 Attachment 216123 Attachment 216124
    Hey Rick - what did you do with #3 in your post? The wires that come with the gauges or the wires in the harness? (assuming you are using the FFR Vintage 7 gauge GPS kit)
    Josh (aka - MakoGT350)
    MK5 Complete Kit - Picked up July 2025 - Power Steering and Power Brakes, Wilwoods front and rear, SS side pipes, BluePrint 347 - fully dressed with Holley Sniper 2, Tremec TKO
  13. Likes rickster991 liked this post
  14. #451
    May 2022
    Quote Originally Posted by MakoGT350 View Post
    Wires that came with gauges.
    YouTube Channel
  15. Likes MakoGT350 liked this post
  16. #452
    Aug 2025
    Saint Augustine, FL
    Awesome - thanks!
    BTW - really enjoying your build thread and getting a lot of value from all of your detail. You and I have a very similar build and you are a little ahead of me, it has been really helpful!
  17. Likes rickster991 liked this post
  18. #453
    May 2022
    I installed my plate. Although it’s tied to an unofficial title that I have yet to resolve. I have to go through a 6-8 week process to get a copy of my COO back… Then I can start the next process…
    I was able to get the windshield installed. With the rivet-nuts I used, I decided to use longer bolts through the backside of them as “studs” and use nuts to attach. Worked like a charm. Still don’t understand how it fits with the glass pre-installed vs after. The upper mounts are tight and the lowers have a gap, so it’s in there at an angle and it did cause a small separation between the glass and the side rails.
    For those that are installing AC and wipers, make sure you can remove them, with the body on, so you can get your arm in there to install the windshield. Getting to the nuts and bolts on the driver side is a breeze. Passenger side is an exercise in contortion-ism!
    When I get the go-kart back from the painter, I am going to modify both so I can remove/move them with the body on.
    YouTube Channel
  19. Likes Whowantstoknow liked this post
  20. #454
    May 2022
    Drove it on the street for the first time. It definitely needs an alignment. It was sketchy above 40!
    https://youtube.com/shorts/e8Jt_-YQG...a6XV1iE2wRnHEk
    I put it in the lift to see if anything was loose or leaking. All good! But noticed my tire patch was a bit narrow! Forgot to lower the pressure. It was at 32, but it weighs 2440 lbs, so I set it to 24 psi. Hopefully that helps a bit. It has crazy power/acceleration!
    YouTube Channel
  21. Likes rickshank liked this post
  22. #455
    22-23 psi and get it aligned. If toe is off the car will be all over the place!!!
    7-8 degrees positive caster
    .5-.75 degree negative camber
    3/32" total toe in (in, not out)
  23. Likes rickster991 liked this post
  24. #456
    May 2022
    YouTube Channel
  25. #457
    May 2022
    Jeff, how about the rear camber? I have IRS.
    YouTube Channel
  26. #458
    May 2022
    Today I did a string alignment and got the rear dialed in. Was able to set toe and camber.i used a level from Amazon for the camber. In the front I set camber but not caster. I could not get toe set correctly. I’m pretty sure the tie rod ends need to be removed to do it. When I got one wheel set the other was way off. I’ll leave that to the pros. BUT it’s good enough to drive around the neighborhood. I was able to go 60 without feeling like I was going to die! I figured out some of the play in the steering was the shaft from the steering wheel going into the receiving shaft. I drilled and tapped a set screw to remove the play. Worked like a charm. I assume the rest will be gone once the caster/ toe is correct. As per the instructions, you are supposed to add a washer, but I never could figure out how to get it in there.
    I also got my AC working! My son asked me to turn it off because it was freezing! I have not hooked up the vents so it was dumping on his lap.
    Lastly I finished the carbon fiber wrap on the center console. I don’t like it. It’s too monotone. I got a rendering of it with wood. I like it and I’m going to give it a shot. That’s what good about vinyl wrap. It’s cheap to experiment and figure it out.
    YouTube Channel
  27. #459
    May 2022
    Should I be worried about this rust? I noticed a lot of the black socket head bolts are rusting as well. Sand it and paint?
    YouTube Channel
  28. #460
    Many, like myself, paint the differential and trans coupling while it's out of the car. That stuff will rust if you look at it the wrong way. Same with the IRS spindles. POR15 works great. I haven't seen an FFR driveshaft rust like that though during a build, especially up the slip yoke. Was it left outside or something?
  29. #461
    May 2022
    No in my garage. It is really humid here. Same thing happened to some of my tools. I’ll look at POR15.
    YouTube Channel
  30. #462
    May 2022
    I used PB Blaster and a wire brush. Worked great. Need to clean it well and paint it…
    YouTube Channel
  31. #463
    Oct 2024
    Congrats on your build. I read in one of the threads about a driveshaft safety loop for the MK5. Can you share where you purchased this from??
  32. #464
    May 2022
    Thanks! I got it here, but it took serious massaging(ie grinding and a big hammer) to get it to fit. FYI
    https://www.speedwaymotors.com/Speed...Loop,2188.html
    YouTube Channel
  33. Thanks RobHartley thanked for this post
  34. #465
    May 2022
    100 mile walk around. Brakes are dialed in. Steering is solid with a bit of play. Hopefully goes away with pro alignment. But overall drives amazing. Only been up to 65 mph, but that feels like 100!
    https://youtube.com/shorts/55zZ4jpfP...1-d_plbKokodCb
    YouTube Channel
  35. #466
    Jun 2025
    Vancouver BC
    Looking at post https://thefactoryfiveforum.com/show...l=1#post589229, I see you changed this out in post https://thefactoryfiveforum.com/show...l=1#post593672 to a ACDELCO 14110S, looks like you cut this into to 2 pieces with a connector to get the right orientation, is that the correct assumption or is it 2 separate types of hoses you used?
    NVM I see you added more in post #429 - all Good
    Thanks for this Rick, I am going to need this heater hose solution with my BP347
    I answered my own question. This may work. https://a.co/d/2pHqFmK
  36. #467
    May 2022
    Yep the AC Delco hose worked. You can trim it to fit after it clears the alternator.
    YouTube Channel
  37. Thanks RobHartley thanked for this post
  38. #468
    May 2022
    I finished the interior. I really like the contrast. I ended up buying the panel from Snakebite Motorworks as I did not like the one that came with the kit. The multiple panels did not look right when covered with wrap. I did make the shifter hole as small as possible so that the shifter trim and e-brake trim rings would fit. The shifter ring is almost completely offset to the left. That was another reason for the blank panel. With the stock panel I could not get four screws on the e-brake trim.
    YouTube Channel
  39. Likes RobHartley liked this post
  40. #469
    Jul 2025
    Pittsburgh, PA
    Great job! I like the look.
    Rick
    MKV with Blueprint 347 / TKX / IRS / Edelbrock Pro Flow 4
    Ordered 7/15/2025, Picked up 8/26/2025
    YouTube Channel
  41. Likes rickster991 liked this post
  42. #470
    May 2022
    After some advice from the forum, I decided to re-route my heater hoses away from the EFI fuel lines. I’m not sure this is the final solution, but it will do for now.
    YouTube Channel
  43. #471
    May 2022
    Update: I have been driving it and have 400 miles on it. I had gone over speed bumps without an issue, but this morning it bottomed out on a speed bump I had gone over before??? It’s basically bent 90 degrees. I’ll see if I can salvage it when I’m back in NC with the lift.
    When I looked at it I noticed the rear was pretty low. It had changed from 4.5” to 3”! I re-set the coilovers back to 4.5” and used the set screws. The roads here are pretty bumpy so I guess they worked themselves loose. I’ll definitely keep an eye on that in the future. The fronts did not change very much, but I reset them.
    I had an issue with the AC making a squealing noise, and after advice from the forum I tightened the belt little by little until it stopped. Easy fix! Can’t wait to see how it drives once it’s properly aligned and corner balanced!
    YouTube Channel
  44. Likes rickshank liked this post
  45. #472
    May 2025
    Fuse box location
    Quote Originally Posted by RKRacing View Post
    Thanks, this inspired me to add a post to help hold the fuse panel...
    This is very helpful to see. I do wonder… I mean, eventually MCs leak. Odd to have your panel just under it.
    I don’t really see anywhere else on the driver side it could be mounted. I could see space on the passenger side, but the bundles are (I suspect) the wrong length.
  46. #473
    May 2022
    You are definitely limited to areas. If you are worried about leaking you can build a cover for it. I hope to do this once the body of off to paint. Update: I got to 500 miles and so far so good. I tried 0-60 times, although not past 4500 rpm and it was a respectable 4.6s. Man what a blast to drive!
    Stereo update. I can hear it really well cruising at 70 on the highway, ~2000 rpm.
    Registration update. Still have not gotten copy of MCO from FL! I have asked FFR for a new copy. I spoke to someone at the DMV and asked if they could use the one they had on file. Their answer was “we can’t register FFR in Florida”. I about had a heart attack and told them they have to be mistaken! They are asking a supervisor and getting back to me. Holy smokes this is so frustrating!!! Fingers crossed…
    YouTube Channel
  47. #474
    ...Registration update. Still have not gotten copy of MCO from FL! I have asked FFR for a new copy. I spoke to someone at the DMV and asked if they could use the one they had on file. Their answer was “we can’t register FFR in Florida”. …
    You most certainly can register a Factory Five in Florida. Reach out to Henry ("65 Cobra Dude") for info on how to do it legally (not some questionable out of state LLC method).
  48. Likes rickster991, Mike.Bray, MakoGT350 liked this post
  49. #475
    First mistake is going to the DMV. Absolute nightmare in FL. You'll want to take it to OATA if you are going to be in the Orlando or Melbourne areas any time soon. You'll be in and out inside of 30 minutes with appointment. Just bring your DL, COO, proof of insurance, receipts and your filled out TL-48. You'll walk out with a plate unless you want something custom. They are even open on weekends and their website is very appointment friendly.
  50. #476
    May 2022
    I did that and got my tag, title, insurance and registration.(Went to OATA in Orlando) That's why I am ok driving it.. BUT, FL contacted me several days later and stated that the TL-48 process is not valid for FFR and asked me to return my title and start the TL-41 process. They have my MCO from the TL-48 process, I am trying to get it back/copy for the TL-41 process. That was in the beginning of October and I have been trying to fix it since. Quite the nightmare...
    YouTube Channel
  51. #477
    Oh that's right. I remember reading that when you updated. Hopefully you'll get your certificate back!!
  52. Likes rickster991 liked this post
  53. #478
    Loveland, CO
    Quote Originally Posted by dr-sicel View Post
    I just put a piece of visqueen over the fuse box area. It will divert any leakage around fuse box but not stop leaks. It also comes in handy if you have a water leak through the windshield post hole. Instructions now say to seal this area with silicone sealer.
    Ralph
  54. Likes rickster991 liked this post
  55. #479
    Dec 2021
    Flower Mound TX
    I was going to say this depends on which ones you have but decided not to
  56. #480
    May 2022
    Ok I finally have my car registered. I filled out the TL-41 as a kit car. After lots of “discussion” at the DMV I could not do replica or kit car. According to the supervisor FFR is not registered with Florida as a Kit Manufacturer. My only option was ASPT. So they helped me fill out the paperwork, get a waiver for the airbags and we scheduled an inspection. The inspection was pretty basic, but I almost failed! My brake lights would not come on. It turns out that they only come on when the brake is all the way to the floor. I passed inspection and got my sealed package and headed to the tag office. After lots of “discussions” there , they put it through as ASPT. They wanted to do replica or kit and I begged them to leave it alone and they did. So I have an ASPT rebuilt title.
    I had asked FFR for help and they put me in touch with their expert in FL. He said that he has done many cars and always does ASPT. I asked the supervisor why my title was flagged and he mentioned they are auditing titles going back to 1980! So who knows… hopefully others that have gone through the TL-48 process won’t go through my nightmare.
    YouTube Channel
  57. Likes 65 Cobra Dude liked this post
