11-26-2025, 03:28 PM
#321
Originally Posted by
Skuzzy
Just to be fair. "Old School guys" is not really accurate. I consider myself to be an "old school" guy, yet look at the electronics I am designing and building for my car.
I think the people who would have mixed feelings about putting the LS in a Coupe are the guys who really want to honor the original Daytona. That covers a pretty wide age group. Then again, the only thing shared between the original 289 and the Coyote is the manufacturer.
I think you have done a nice job.
You're right Skuzzy, I should have said "Traditionalists" won't like it. This is far from a faithful reproduction of the original Daytona in many ways
I suspect half the Forum won't click the link to my build thread because the title says "An LS 65' Coupe Build".
But Shelby originally wanted a Chevy engine in his Cobras, yada yada...
11-29-2025, 07:20 AM
#322
So I’m trying to figure out where to mount my Ron Francis fuse box and the general consensus is to mount it in the drivers foot box like you have done … however I’ve got to say it’s super tight in there and I’m not sure I can fit my big ole hands in there with everything that is supposed to occupy that space …especially with the body on the car …. Any advice or fitment tricks …. Btw I have kinda been sidetracked on build progress since I read about you building your own powder coating oven …. My wife bought me a small Eastwood powder coating kit and man it’s pretty cool being able to powder coating at home ! I would like to powder coat all my floor boards and interior panels but the supplied over is way to small … I been looking into building a propane or electric element powder coating oven any advice on that front as well?
11-29-2025, 03:10 PM
#323
Lugnut Mark
Hey Mark,
I also was not thrilled about putting the fuse box on that angled frame rail in the driver's footbox. My problem with it was that that location is visible and I thought it was ugly. After thinking a long time about alternative locations, I gave up and mounted it there and instead built an aluminum cover I powder coated to blend in. I'm also going to make a panel for that triangular area in the footbox to hide all those ugly wires.
I could not think of a better location. And the RF harness is made for the fuse box to be there, so moving it elsewhere would mean lengthening almost all the wires.
It is a PITA to get in there to work, but you do have access from above (if you haven't mounted the footbox top panels) and below.
I love my Eastwood powder coat gun. I bought a "better", expensive gun that I learned quickly was garbage and a complete waste of money. The Eastwood has done all my panels (I'm mostly done) and smaller parts.
Regarding the oven, if you are serious about doing your panels then yes you'll need to make a big oven. I followed this guide pretty closely: https://www.powdercoatguide.com/2014...-oven.html?m=1
My recommendation would be to keep it simple. Forget the fan/convection ducting, lights, window,. Don't need those. I built a fan/convection duct and the fan burnt out after a few hours.
Some things to consider.
I probably spent $700 on the oven. And I used cheap aluminum panels from the RV industry to skin it (not recommended. Use steel). I suspect with metal prices now, it will cost at least $1k.
It was a fun project for me, but took me away from the build for a month and a half. Then it takes a lot of time to prep the panels and do the coating.
The sandblasting part is not fun. I do that in a tent to contain all the sandblasting media. It's cramped, uncomfortable, dirty.
Then some of my panels have some imperfections in the powder coat because I'm not a professional.
So, with all that being said. Unless you REALLY REALLY want to coat your panels yourself (or you want the oven for other projects) just have the big panels done professionally.
Get yourself an old kitchen oven on Marketplace for $50. With that size oven, you can coat almost all the other parts yourself (door frames excluded).
11-29-2025, 03:43 PM
#324
My two cents on this subject. I spent about $1300 on powder coating for my coupe. I believe my powder coater used a DA on the flat panels and low pressure sandblasting on the smaller bits.
Twenty years ago I built a '67 Mustang and was a powder coating fool. I bought the Eastwood kit and picked up a free oven on the side of the road. Homeowners were remodeling and getting rid of the range. With all that said, I am not sure it's worth it, aside from the convenience. You have to have a sanding and sandblasting area, an oven, and of course, the powder coater. All these items take up precious floor space for me and I made the decision while building my Camaro to sell all of it. Of those components, I only really miss my highly modified sandblasting booth.
12-02-2025, 02:48 AM
#325
Update on the leaking brake master cylinder:
Replaced the MC and it STILL leaked at the outlet. Turns out that it wasn't the MC at all. The damn 1/8 NPT to 3AN fitting/adapter was faulty.
I got a new one and compared it. The faulty one has slightly smaller diameter NPT threads. That's why it was bottoming out.
So, that means I now have an extra (apparently perfectly fine) Wilwood MC, just in case
I'd like to say Wilwood is faultless in this situation, but the fitting/adaptor was actually a Wilwood product
Anyway, brakes are bled. No leaks, firm pedal. Yay
Post Thanks / Like - 0 Thanks, 3 Likes
12-02-2025, 07:26 PM
#326
Glad to here it, nice to have that checked off the list. This activity is still on my to do list.
12-05-2025, 10:31 AM
#327
That's a win, Jim! Who woulda figured the adapter as the culprit? Not me. Leak free brakes! Wahoo!
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
12-08-2025, 01:51 AM
#328
burchfieldb
460.465USMC
Thanks for the encouragement guys!
Don't have anything new to report, at least not anything finished. I've been bouncing around several different projects, including another Rabbit Hole that I'll post about later
Current projects:
- Trying to tidy up the wiring enough that I can try to get a first start in sometime in the next few months
- Courtesy and ambient lighting, including making custom cage-mounted dome light fixtures
- Heat shields for footbox panels directly next to headers (almost done - will show more soon and explain why I made them)
- Upholstering the outer footbox panels so I can finally seal up the foot boxes for the last time
Some pics:
All my dash lights work. Courtesy lights in the footboxes. My turn signals work (Microflex Labs turn signal controller and switch), and flashers. All push buttons work (Billet Automotive buttons). Heater/AC fan works. Windshield wiper motor. Brake and reverse lights. ECU fires up. Don't really know about the T56 reverse lockout module, but it lets me shift into reverse without resistance.
Same Hurst shifter used by several others. I did have to move the hole in the trans cover rearward 1 inch to center the shifter. Not bad though.
FYI, for those who don't know, you can choose a free shift ball if you buy a new Tremec transmission. They don't exactly advertise this. I knew about it thanks to one of Paul's build threads. I had to search online for the form to order the ball. It came a few weeks later.
Can we make it into a 3 seater?
Post Thanks / Like - 0 Thanks, 4 Likes
12-08-2025, 06:58 PM
#329
Jim - going to go a little off topic here but I too am going down the rabbit hole of upholstery. I have looked at the Sailrite machines as well as others like Juki and Consew. Have you developed any opinions, good bad or otherwise, regarding the machine you picked up?
12-08-2025, 07:20 PM
#330
PNWTim
Hey Tim,
Its been a year since I researched the other machines, so I can't really speak to the Juki/Consew's, but I absolutely love the Sailrite. I have the Sailrite Ultrafeed LS. Everything about the machine and Sailrite is top notch. From the packaging, to the excellent instructions and their YouTube tutorials, to the quality and feel of the machine.
I got the Monster Balance wheel, which is supposed to make it even smoother and easier to sew. I'm not sure it's necessary, but it I guess it makes it so you can sew even slower which is good for a newb like me.
I like that the Ultrafeed is compact. It's not exactly light, but comes with a really nice carrying case.
I haven't sewed since Spring. I've kind of planned to do it as I go, doing panels as I need them instead of all at once. Keeps it from becoming a chore
12-08-2025, 08:04 PM
#331
PNWTim
I have a Juki Lu 565 that I purchased off of Facebook. It is an older machine and works really well. We also have a lot of Juki's at our office that are used for development work. I can't speak to the others, but I think the Consew's are similar to the Juki's.
12-19-2025, 01:06 AM
#332
12-19-2025, 06:12 AM
#333
Overkill? Probably. But also amazing? Definitely!! Keep your distractions coming, I love it!!
12-19-2025, 07:07 AM
#334
Type 65 Daytona G3 Coupe #635 - Dart 363" SBF
1970 Plymouth Road Runner 440 6-BBL Super Track Pack
12-19-2025, 09:01 AM
#335
This is what makes our builds unique! No two are the same.
Scott
12-19-2025, 10:16 AM
#336
I can absolutely appreciate the details you are doing. Nice work.
12-19-2025, 10:27 AM
#337
Those are some sweet, custom touches Jim. Wow! Nice work!
MK4 Complete kit.
Build Thread.
12-19-2025, 12:49 PM
#338
Jim
Get that engine started
mark
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering.
Album Here
12-19-2025, 03:09 PM
#339
Thanks guys, glad you like it. Honestly , I was expecting a few cringe responses
On it Mark! Just need to finish my heat shields, fill the fluids, and I'll be ready to fire it up
12-19-2025, 10:29 PM
#340
Really nice work Jim. Custom is custom. That's why they call it custom. Keep it up. And get that engine started,
12-20-2025, 08:38 AM
#341
Holy moly talk about setting the bar …. Your coupe looks amazing btw it’s all those little details that make it an award winning vehicle …. I love everything that you have created so far ….one question what’s a brother have to do to get a set of those reservoir caps LOL super nice touches
12-20-2025, 09:07 AM
#342
JimStone
No cringe from me, I completely respect that you're making this your own. Some of it kind of feels like Easter eggs that the big manufacturers hide on their cars. The T-Rex eating the Raptor comes to mind.
Can't wait to see the finished product!
12-21-2025, 01:20 PM
#343
Lugnut Mark
Here's a link to the DXF files that you can upload to Send Cut Send. If you need different size, you'll have to use a program like Inkscape to change it.
https://drive.google.com/drive/folde...2su6lHIZ1szqXS
PM me if you have trouble
12-21-2025, 02:14 PM
#344
JimStone
I think I can speak on behalf of many on this forum, we love what you do Jim. Thanks for sharing your creativity.
Nige
Gen1 Coyote / TKO600 / IRS
01-06-2026, 12:41 AM
#345
01-06-2026, 12:59 AM
#346
That's a pretty big Yikes! Lots of labor to fix but glad to see it was a "no cost" remedy. If you feel like being a good samaritan, it never hurts to let outfits know their QA/QC might need a little attention.
01-07-2026, 12:30 PM
#347
Got some packages in the mail yesterday (is there any better feeling than having boxes or crates of parts waiting for you when arriving home from work?)
My wife convinced me to get the Formacars electric window kit (that's my story and I'm sticking to it).
I'm working hard to reduce the cabin noise and make this car comfortable to drive, and I think real glass windows will help a lot.
It came impeccably packaged. The parts look top notch.
I am more than slightly intimidated by all the parts and the installation process. And I bought them uncoated so I could powder coat them to match the rest of the car, but man, there are a lot of things to take apart to coat. But that's a project for summer! I got them now so I can get the electrics sorted so I can finish my behind the dash stuff
01-07-2026, 04:05 PM
#348
I had no idea you were headed in this direction, but I'm excited to see how you make out with their window kit!!
01-07-2026, 04:13 PM
#349
I'm 99% ready to place an order for a set myself. They are out of stock right now, but taking back orders.
01-07-2026, 07:58 PM
#350
I am surprised you were able to get them. I inquired about 3 months ago and they were out of stock then as well. I bounce back and forth on whether to spend my money on bags and an airpod or power windows. It's a tough decision.
01-07-2026, 08:53 PM
#351
PNWTim
I first contacted them early November and place an order. It took about two months to get them, but I wasn't in a hurry. I got $200 off because I requested them un-upholstered so I can upholster myself to match the rest of the cabin.
Regarding your decision: money grows on trees, so do them both!
01-08-2026, 07:05 AM
#352
Papa
Same here.
01-08-2026, 10:02 AM
#353
Those will be sweet, Jim! I watched their videos. A very nice upgrade indeed. For some reason I'm not tempted on this one. What's wrong with me? Will enjoy watching them come together.
P.S. I need to have your wife talk to mine!
MK4 Complete kit.
Build Thread.
01-09-2026, 12:10 AM
#354
460.465USMC
I may be overselling the wife approval thing. The conversation went something like this:
ME: I've been thinking a lot about the Formacars glass electric windows for the Coupe.
WIFE: You mean your car doesn't have windows?
ME: Well, it does, but they're plastic with a little rectangle cutout that slides back and forth
WIFE: [stares at me blankly]. You should get the glass ones
Conversation over
01-09-2026, 06:23 AM
#355
That kind of conversation means the light has never been greener!!! Especially since it was her idea and she told you to do it!!
Higgy
MK4 #11354 picked up 10/06/25
MK4 #11173 picked up 01/20/25
MK4 #11012 picked up 04/16/24 SOLD
MK4 #10616 picked up 4/10/23 SOLD
MK4 #9759 picked up 4/3/19 SOLD
01-09-2026, 08:35 AM
#356
Happy wife, happy life. Way to take one for the team.
01-09-2026, 11:30 AM
#357
JimStone
Conversation over
Less is more my friend, less is more.
01-13-2026, 03:23 PM
#358
JimStone
Conversation over
Very funny, this actually prompted a conversation with my wife about the same topic. I was initially planning to figure out how to build the windows from scratch, but just got off the phone with Chris at Forma about deleting a few of the parts from the kit and attempting to reengineer a manual version of their windows. We'll see how that works out, but the nice thing about buying the kit is the geometry is already figured out. Now it's a matter of coming up with a mechanism to raise and lower the glass.
My wife values my time and realized how much would be involved in figuring out this part of the build. "Buy the window kit, it's worth it"
01-13-2026, 08:24 PM
#359
JimStone
Conversation over
Nice!
Here's my secret when buying something that's a bit on the pricy side. Now this has worked for me for 25 years so feel free to use it at your discretion.
ME: I'm thinking about buying some upgraded windows for the coupe!
WIFE: What's wrong with the stock windows? Are the upgrades expensive?
ME: They're plastic and they don't roll down, only a small vent window. Not sure on the price, I'll check.
ME: I decided to buy the window upgrade. They only cost $1,200. (I'm guessing, I don't actually know the price)
Now, here's the secret; I didn't actually buy them,,, I'm waiting to gauge my wife's reaction!
WIFE: Reaction A. That's not bad, sounds reasonable. ME: Order immediately!
WIFE: Reaction B. Wow, that sounds expensive. ME: Just kidding, I didn't order them. They did seem a bit high priced.
Remember guys, keep this to yourselves. We are in this together.....
01-14-2026, 12:04 AM
#360
JTG
Just don't mention the price, am I right? The sticker shock on those things took awhile to wear off. But now that I see the parts in person, I understand why it costs so much.
Jim Frahm
Nice!
Nice! I'll have to try that one next time
