Tilton three-chamber MC reservoir - anyone using it?
Hey guys,
I was planning on using the Tilton three-chamber reservoir on my roadster build - it checks a number of boxes for me. Has anyone else used it for their build? Always interested in direct feedback - thanks!
Rob
https://tiltonracing.com/product/3-c...tic-reservoir/
Stangrob
Hey guys,
Rob
Yup. Great product.
https://thefactoryfiveforum.com/show...l=1#post577373
We're using one on the Coupe project that is here in our shop.
I've used it in the past and planning to use on the Challenge Car build. I like it.
But, as Mr. Kleiner would say, it's a racing part and comes with things to consider. In particular no diaphragm to block moisture into the fluid.
Jim
Jim1855
Jim
That's great info on the lack of a diaphragm - thanks! I guess a workaround would be to run DOT 5 brake fluid.
Rob
I'm about to install that Tilton piece on my Mk5 Roadster. Have one on my Gen 3 Coupe that's been driven for five seasons. All good. Many use it as is. If you're concerned about the caps, this thread talks about installing Dorman diaphragms. I've done this mod on mine but not 100% sure it's required. https://thefactoryfiveforum.com/show...iple-Reservoir
Lots of threads and discussion about DOT 5. Here's one: https://thefactoryfiveforum.com/show...75-Brake-Fluid
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
Yes, I'm using this but the less 'tall' one and AN fittings.
Gen III #17
Not a waxer
Yes, on my Mk5 with the AN4 fitting option.
Stangrob
Rob
Whatever you do DO NOT use DOT5.
Jeff Kleiner
Jeff, gotcha - I caught your comments on DOT5 on another thread. Off my list
Rob
