With all the panels back off of the chassis, I started plumbing the brakes today. I kept all my tools from the Cobra build, so this one will cost a bit less!
I ran the front cross-over similarly to what most others have done.
Next was the front primary line. Getting the bends I wanted to do made it quite the puzzle to fish the line into the footbox. I laid in the fuse panel to ensure I had plenty of clearance.
I used a 90 degree fitting that came in the kit for the MC connection to keep the line as far away from the electrical as I could. I'll be using a straight fitting for the rear and clutch MC connections and will run those lines under the dash and into the tunnel.
I just used cushion clamps under the inside engine bay rail to secure the line.
Finally, a quick check that I could still attach the front foot box and splash panels. Everything fits well.
Next up will be the rear lines. I need to study a few build threads to see how others have done theirs first.
