54
81
Working through testing everything including the lights and the heat / AC.
I have the connections to the heat / AC switches connected and the heat and fan settings are working. I can hear the valve open when i turn the heat knob and all 3 fan speeds work. I verified the wires on the AC toggle are correct but I notice with the accessory on / engine off the toggle doesn't light up. Is this normal or something mis wired?
