Quote Originally Posted by FFinisher View Post
You will want to remove the spacer on the steering Column and pull the column to the Frame tab, You will need clearance for the brake pedal.
Are you ure you don't have the lower Firewall? It is normally packed with the "packaged aluminum" not with the large top piece
Thank you for the comment. I’ll ditch the spacer. Unfortunately the packaged aluminum is on the back order list. Thanks for confirming. I only have like 20 items but every one of them seems to create a road block. I sent a note to FFR for an update. This whole project might be on hold until I get some of these parts.
In the meantime I am painting the steering column. I should have the rear end this week so I can get that hung.
