29
106
The Delco pins for the Caddy Bremboes have a split spring sleeve on the inboard end that's supposed to hold in the cavity. It isn't effective. If it's not too much trouble, I would like to have dimensions on the STI pins and lock pins and maybe a part number. One of these days it's probably going to bite me if I don't do something about it. Drilling for a cotter pin or equivalent might work.
These are the RockAuto Carlson version:
https://www.rockauto.com/en/moreinfo...8C%2FQyw%3D%3D
I'm just using the Delco brake pads, front and rear, and it stops. Anybody using more aggressive pads on the Caddy Bremboes?
Sorry to hijack the thread.
Ed
