Thanks Thanks:  50
Likes Likes:  156
Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 401 to 440 of 511
Thread: Rick's Mark V Roadster Build
  1. #401
    May 2022
    Thanks! Now I have to fill that hole I made!
    Build School: 5/2/2025
    Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
    YouTube Channel
  2. Likes danmas liked this post
  3. #402
    May 2022
    Today I continued to knock off TODO items. First I installed the trunk struts. I’m not sure if I’m supposed to have two? But I received two with the kit. I used one on the hood and the other in the trunk.
    I then proceeded to attach the roll bar. It was quite the challenge. First step was to dry fit it. Early on I was able to get it on the mounts, but I could no longer do it. So I used a jack to spread the hoop. I took my time and did it over several passes. Eventually it fit.
    Next I installed the bolt-less roll bar kit from 520 SpeedWorks.
    https://520speedworks.com/shop/ols/p...ar-kit-15-inch
    It went pretty smoothly, but it took some grinding to get the parts to fit. My recommendation is to dry fit it and make sure it’s aligned before trying to install it in the car. The pieces need to be perfectly centered on each tube for it to work when it’s in the car. Hopefully it all lines up again once the body is on!
    YouTube Channel
  4. #403
    Quote Originally Posted by rickster991 View Post
    …First I installed the trunk struts. I’m not sure if I’m supposed to have two? But I received two with the kit. I used one on the hood and the other in the trunk.
    You should have two 20” struts for the hood and two 16” for the trunk .
    May 2022
    Today I tried to change the boots on the ball joints. One already failed. I bought a ball joint removal tool. I was able to remove the uppers, but the lowers were not budging. Is there a different tool I need for these?
    YouTube Channel
  6. #405
    May 2022
    Update: I used a bigger hammer and it popped free. I had to jack up the hub to give the fork clearance to work. All boots replaced with Energy Suspension : https://a.co/d/eztbItO
    YouTube Channel
  7. #406
    Mar 2025
    Eastern Long Island NY
    I am behind where you are on my MK V build but I thought I would post here as a possible help to other builders with Sasquatch feet. I moved the throttle pedal up about 2" and moved it as far to the right as possible. Otherwise when I went for the brake in a hurry I might also be on the gas. Powerbraking can be fun but not in that instance. I had to bend the upper are of the pedal assembly so it would not hit the steering column.
  8. #407
    May 2022
    Nice. I assume you tried with that inside panel on? It comes in a little bit. I had to bend mine out a little bit to give myself a little room.
    YouTube Channel
  9. #408
    Quote Originally Posted by Aleinsteingenius View Post
    Can't tell from your photo but when I build and set up pedals I always place the throttle pedal so that when it and the brake are relaxed it's about 2" forward of the brake pedal. I've had more that a few come in to me in which the builder has set them up so that the brake and throttle are in the same plane and that situation is absolutely dangerous!
  10. Likes wheelindex liked this post
  11. #409
    Mar 2025
    I am thinking the same way. I plan to adjust the brake so it is proud of the gas pedal but even so I want as much room as I can get for my size 15 feet. I may have to be careful to wear my most narrow shoes.
  12. #410
    May 2022
    Today I installed the radio. Hopefully I can hear it at cruising speeds. It was pretty straightforward. I wired a 50 amp circuit in line with my alternator circuit. It was the easiest spot to tap in. I wired the ground in the trunk. The dimensions are in the pictures. I need to finish wrapping it in fabric, but it sounds good. Tomorrow I’m taking it to an AC guy to have it checked/charged.
    Here is a video of the installation.
    https://youtube.com/shorts/rh9otDB1s...j8xiN53swiYnWN
    YouTube Channel
  13. #411
    May 2022
    So lots of progress the last few days…. I took the car to the shop to have the AC charged/checked. There were no leaks so it looks like I have a bad compressor or bad gauges. Had to run a bunch of errands and everywhere I stopped people took pictures and ask questions. I really enjoyed it.
    I finished the stereo install and installed the seat heaters. I’m not sure how effective they’ll be without removing a bunch of foam from the seats. I’ll see how it goes and if I have to remove foam, I will in the future.
    I installed Rivet nuts to make the windshield install easier. I plan on doing that tomorrow. We’ll see how it goes. It looks like the windshield wiper motor will be in the way, so I’ll have to remove that.
    I then created brackets to reinforce the dash. I put one by the steering wheel and one in the middle of the dash. The grab handle is reinforcing the passenger side. I used the brackets to install a hide away hinge for the sniper handheld. It’s pretty slick as I can pull it down when I need it but hide it when it’s not in use to keep the analog look of the dash. I picked it up from Etsy. https://www.etsy.com/listing/1467467488/ref=share_ios_native_control
    Here is a video of it in action: https://youtube.com/shorts/5yNPVlOoL...XTSJH32I7Xe9Cd
    Finally after lots of trimming of the trunk aluminum and some fiberglass around the dash I got the body on.
    YouTube Channel
  14. Likes F500guy, Aleinsteingenius liked this post
  15. #412
    May 2022
    I adjusted mine so when it fully depressed it is even with the accelerator. Thats how my M3 is and it’s perfect for heel-toe shifting.
    YouTube Channel
  16. #413
    Jun 2025
    Vancouver BC
    I like the idea of the rivnuts for the windshield! Will add that to my build.
  17. Likes rickster991 liked this post
  18. #414
    Interesting, that'll work too...it's opposite of what I did (and what I do for Mk4s) which is to drill & tap the windshield post and keep the oversized chassis holes to allow some adjustment wiggle room. I also switched to socket head screws and used an allen hex socket, extension and ratchet which allowed more room for the tool.
    As they say; more than one way to skin the cat
  19. Thanks RobHartley thanked for this post
  20. #415
    Jul 2021
    Tonganoxie, KS
    I am a wide 12, and there's no hope of driving with normal shoes. I also know that if I bought narrow driving shoes, I'd never go put them on to have a spur of the moment drive. So my solution? I simply take off my right shoe and tuck it under the driver's seat while driving, and put it back on before I get out.
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  21. #416
    May 2022
    Quote Originally Posted by gbranham View Post
    That works!
    YouTube Channel
  22. #417
    May 2022
    Cross posting from another thread on MV batteries….
    I uploaded a video of my battery placement for those that are wondering about access. I don’t see a way of getting it out without a bunch of work. Looks like the newer frames do not have those cross bars so you can remove it from below. BTW all that coolant splash you see was the result of a loose hose clamp after my heater hose re-route. Tighten those clamps!!!
    https://youtube.com/shorts/aWu9vFMqh...vun70zLhOldBWP
    YouTube Channel
  23. Likes rickshank liked this post
  24. #418
    Feb 2025
    So today I attached the hood, doors, trunk, and windshield. First was the hood. The hinges went together easily after filing the holes. I had some miniature files that did the job. The instructions call for installing the bolts with the hood closed. I could not get to the bolts so I was able to do it by propping the hood and doing it from the top. Once the hood is attached the adjustment bolts can be accessed from the wheel wells.
    Attachment 218201 Attachment 218202
    The first thing I checked was the clearance to the reservoirs once the strut is attached. I’m happy to report that there was no issue with my placement. In fact I was able to raise them to the maximum height with no issue.
    Attachment 218203 Attachment 218204 Attachment 218205
    I made a quick video showing the reservoirs and strut placement.
    https://youtube.com/shorts/0qqXirY-h...AIc6QAD_YWASJ-
    The doors and trunk went on without issue. I did just enough to hand it over to my body/paint guy. I then tried to install the windshield. The driver side is fine, but the AC evaporator is interfering with the bolt placement on the passenger side. I am going to have to move the box. I need to remove the body to add the bulb seal. So I’ll move it then. I took some pictures for the insurance quote. Here she is…
    Attachment 218206 Attachment 218207 Attachment 218208
    Wow as always for everything you post thanks Rick. Im about to do resevoirs and have been putting it off, you have helped a lot. Do you have any pictures from the other side of engine bay or above at an angle to see how far down the frame you went with the attachments. Looks like they may be center or at the very top, hard to tell and i want to recreate what you did. No bracket right? just straight on to the chassis.
  25. Thanks rickster991 thanked for this post
  26. #419
    Mar 2025
    This is how I did reservoirs. The bracket i made is attached with Rivnuts so I can swing it out of the way for engine install. Too soon to tell if this plan is going to work.1 (1).jpg1 (2).jpg
  27. #420
    May 2022
    Quote Originally Posted by UKSNAKE View Post
    Straight to the chassis. I’ll be starting the final push on Monday when I get back. I can take closer pictures and post. If I recall that bar is not very tall. You can see from Al’s, not his real name , that the bar is tilting down. So if you want the brackets in the bar and level start low from the firewall to the nose.
    YouTube Channel
  28. #421
    Mar 2025
    You may be able to see from this pic that my bracket is pretty level with the car sitting on it's wheels.
  29. #422
    May 2022
    Right. The bar is not level. So when I went to attach the second bracket in line and parallel to the first I couldn’t because I did not notice or account for the slope. Your picture shows how out of level the bar is. So if you want to attach without a separate bracket and all at the same level you need to account for the slope.
    YouTube Channel
  30. #423
    Mar 2025
    Correct. The reservoirs themselves are not even in that pic because I didn't bother to adjust them for height yet.
  31. Likes rickster991 liked this post
  32. #424
    Aug 2025
    Saint Augustine, FL
    Can you tell me more about the OATA on Lee Road? I am in St Augustine and want to get my plan together for when that step comes.
  33. #425
    May 2022
    It’s a long story. It worked initially but a week later the State said TL-48 was invalid for FFR and that I have to do TL-41. I am still in the process of getting through it. Unfortunately they have my MCO and I have to go through a process to get it back before I can proceed. It has been a nightmare. Once I finally get it fixed I’ll post an update. It has worked for some people, and it worked for me for as week…
    YouTube Channel
  34. Thanks MakoGT350 thanked for this post
  35. #426
    May 2022
    Here is a closer picture of the slant in the bar and the brackets going diagonally.
    YouTube Channel
  36. #427
    May 2022
    So I’m back at it. Trying to get the final position of the body. I removed the headers as they were not allowing the body to sit right. I may need to enlarge the cutout on the passenger side. My latest issue is with the door hinges. When tightened they hit the body so they will not open. I had to add washers between them and the frame to clear the body. Is this normal? The body is on with the quickjacks and the body clears the rear bulk head by an 1/8 of an inch. The only way to move it more forward would be to possibly cut the spacers on the rear quickjacks. Should I just use washers?
    YouTube Channel
  37. #428
    Liberty Hill, TX
    Following your build with some interest as I've recently started on my own MK5 build. I'm particularly interested if you received a response back from BP on your heater hose issue mentioned in post #290 and #293. I have the same issue on my BP 347. Did the 90 degree heater hose from Amazon work out? When I received my engine from BP I was shocked to see that the AC unit I ordered was not installed. BP was very apologetic and they sent me the complete new front drive (the front drive without AC is different than with AC) unit with all components that included the absent AC compressor that I had to install. I did have to return the replaced components for which they provided the call tags. Not happy with their sloppy oversight, but they did compensate me for the inconvenience. Very much appreciate your work and highlighting some of the issues and solutions that await. Enjoy.
  38. #429
    May 2022
    Quote Originally Posted by Papa_Jack View Post
    Sorry to hear, but I’m glad they made it right. Check out this post for the hose I used for the water pump. I had to cut it, but it snaked through the tight space that was available.
    https://thefactoryfiveforum.com/show...l=1#post593672
    YouTube Channel
  39. Likes rickshank liked this post
  40. #430
    May 2022
    So I decided to remove the body mounts and see if I could get the body to fit better and have the hinges clear the body. Once I removed them the body came forward and the hinges cleared. I was then able to align the wheel openings with the frame. I secured the body to the frame using screws to make sure it did not move.
    With this alignment the hinges cleared the body on both sides. This also provided better fit for the headers. I had to relocate my header mounts, which was aggravating, but they look much better now.
    I was then able to attach the front mounts without issue. The rear bolt holes align, but the spacers do not fit. I used a scrap piece of wood I had laying around to measure what the spacers need to be. The gap is 3”. The spacers are 3 3/4”.
    I spoke to FFR and they said I may have received the wrong spacers??? They are going to get back to me. Can someone measure theirs if you have them handy? I don’t think I have a choice, but to cut mine to size.
    YouTube Channel
  41. #431
    Liberty Hill, TX
    Awesome. I did miss that entry reading through your posts. Many thanks.
  42. Likes rickster991 liked this post
  43. #432
    May 2022
    I am really struggling with the body. After all the adjustments and reinstalling the passenger headers, now the hood is way off and there is not enough adjustment space in the hinges to even get it close. I’m taking it to my painter tomorrow and he has done many FFR roadsters. Hopefully he can help.
    YouTube Channel
  44. #433
    Dec 2017
    Southern Ontario/Cape Coral FL
    Post up what he says about the hood!
    Higgy
    MK4 #11354 picked up 10/06/25
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24 SOLD
  45. #434
    What sort of problems are you having with the hood Rick?
    May 2022
    It all started with door hinges not clearing the body. So I tried to move the body forward to clear the hinges. I was able to get it all looking good(side pipe, doors, trunk. When I went to re-install the rear mounts the spacers were off by 3/4”. The rear bolts lined up so I figured the body was aligned. When I went to re-adjust the hood, it was off by that 3/4” of an inch after full adjustment of the hinge. So that told me that the rear spacers were correct and something else was wrong. So I slept on it…
    This morning I decided to remove the screws holding the body to the frame that I used to move it forward the 3/4”. I forced the spacers back in, all of them fit with a washer, but one. I tightened them, and installed the hood. It fit perfectly. The hinge on the passenger side cleared by 1/16”! The hinge on the driver side will clear if I screw the body down with a little force! I’m calling that a win! The side pipes on the driver side fit perfectly. The passenger side needed a significant amount of cutting on the opening that FFR cut. Probably an inch. But everything is fitting enough, I assume, for my painter. I’m going to see him today to get his opinion. Fingers crossed. After that will be the windshield. I hope that goes well. Thanks for offering help Jeff!
    YouTube Channel
  47. #436
    Sounds like you got it! FWIW, I throw those rear internal spacers into the trash on Mk2,3 and 4s. I didn't use them when I did the initial mockup on my Mk5 either (in the end I made hidden mounts for the rear as well as the front). A better indicator of body fore and aft positioning is the roll bar(s) and the near vertical chassis member at the rear of the door opening.
    May 2022
    Can you explain your process? What should door opening look like? Thanks!
    YouTube Channel
  49. #438
    You want the flange at the rear of the door to be just ahead of the plate where the door striker bolts on. My Mk4 beta chassis is different with a bolt on plate rather than welded on like the production chassis but here's a look anyway:
    This is a picture of a Mk4 but you are shooting for similar spacing:
    Hope that helps you to visualize it.
  50. Thanks RobHartley thanked for this post
  51. #439
    May 2022
    Thanks, I’ll verify! I got the thumbs up from the painter. Looks like I’m slotted for mid January! 🤞🏼I test fit the windshield and it is not square. Looks like I’ll have to bend it like in this video.
    YouTube Channel
  52. #440
    May 2022
    Here is a video of the body fit…
    https://youtube.com/shorts/_jivFZ7gG...g6GpmKbmotvEtG
    And another of the first drive and loading it up to take to the painter.
    https://youtube.com/shorts/6BXUDqeIM...goVURUY4r-cDqf
    YouTube Channel
