12
28
Short driver
Bouncing around a bit on the build, waiting for some parts (and help for the IRS install). Pedal box is in. Masters are not as I'm waiting for some fittings on top.
For the accelerator pedal, we have a ton of freedom here. First, the bottom hole marked in the manual doesn't exist on my MKV.
As a 5'5" driver and talking to the build school guys, I'm planning on using getting the pedals as far forward as I can with the pushrods. I can clock the accelerator pedal to bring it forward, but I'll want that somewhat aligned with the pedals. I do have an adjustable seat track and I'll use that as well but with a fixed steering column, I want to take up some length in the pedals.
Any tips from any other shorter driver builds?
