Hey, all. I am "oh so close" to removing the body for the last time so I can move on to the priming, final body work, and paint phase of our build. We are putting stripes on ours: the typical two wide-stripes with a 1/4" stripe outside of each wide stripe. I have the front of the car and scoop looking correct for stripes after my third attempt over these last several months. I swear that scoop used to point in different directions randomly from one week to the next, lol. I am referring to the "centerline" down the body to base the stripes off of. I have started drilling small reference holes per one of Jeff Kleiner's posts so I can find this centerline again during painting.
I found information in a few older stripe-painting posts in the past for those with two rollbars...those posts made reference to having to "make a little adjustment" or something to that effect for the stripes between the two roll bars. For me, when I pull a string from rear to front of the car and all "looks" correct (even after several days of looking), I am slightly off center between the roll bars. I am talking about having to shift the string over 1/8"-3/16" to be centered between the roll bars. When I do this the "centerline" string has a noticeable but slight shift from the front of the cockpit to the rear of the cockpit. I have one of those trunk lids that came grossly overcut from FFR, so I don't know if that is throwing the reference at the license plate bracket off, or if that is just the nature of all of the bodies.
My question is, should I put a shift in the stripes from the front-to-rear of the cockpit, so the stripe is centered between the roll bars and also the front of the car and scoop, or leave the centerline "looking" correct along the entire length of the car and have a slight "non-centering" of the stripes between the roll bars? I ask because some, like Jeff K and others, shift the stripes at the license plate bracket so the stripes are vertical and centered on the trunk latch handle for that last bit of the stripes at the very rear of the car. In that case, the shift is hidden behind the license plate bracket and is not noticeable and makes it look correct in the end. However, I do not know if shifting the stripes between the front and rear of the cockpit will have the same result OR have a very noticeable shift to anyone looking down the center of the car. Thanks for any guidance!
-Mark
