Thanks Thanks:  10
Likes Likes:  25
Results 1 to 40 of 117
Thread: Dondero Father Son Mk4 build thread: Cooling System
Threaded View
  1. #11
    Jun 2025
    Bridgewater, MA
    Quote Originally Posted by JsMoose View Post
    Yeah, I'm at the same step and observing that finding the right hardware is more than half the battle! Can anyone confirm Dondero14 has the right bolt and the manual has the correct nut for the steering arm?
    Jay
    Hey Jay,
    I noticed that same thing while installing the steering arms that the bolts in the manual were different from the ones provided. I DID get confirmation from a previous post that they stopped using the button head bolt for that. In addition the manual doesn’t do a good job showing which one goes where. I’ve also read that the steering arm should be pointing up and out with the larger hole on the bottom. In the picture I have that steering arm on the wrong side of the car. Did some more building yesterday and corrected it all before anything was bolted in.
    https://thefactoryfiveforum.com/show...mounting-bolts
    Mark
