50
156
An issue and a question. I hard-wired the Sniper and it worked perfectly. Should I just stick to the external pump and give up on the in tank? If I do is this a good place to mount it? The instructions say it should be below the tank. This is the closest rail that is below the tank.
With the good comes the… I ran it a bit more this morning and there is an oil leak. I tried to find where it’s coming from with no luck. Any ideas? I guess I’ll be callling BP in Monday.
Build School: 5/2/2025
Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
YouTube Channel
