27
274
cv2065
I've not seen one of these skid plates in person but a couple of observations/questions.
It looks like those are flat head screws but the plate isn't countersunk deep enough. I think if you ever test it on a speed bump you're going to leave the heads of those screws behind. They need to be countersunk so they are below the surface of the plate which they don't look like they are.
There's a tab on the leading edge that is bent up which makes sense. I don't understand the tab on the rear that is bent down. Again, dragging on a speed bump how is this going to work?
Maybe I'm missing something here.
