Chad,
Did you cut those louver holes yet or just measure and mark? If the latter you need to be aware that the angle that FFR cuts does not match the angle of the fabricated louvers so you might want to revisit your layout before cutting.
Hey Jeff. I haven't cut anything yet. I measured the angle at roughly 13 to 13.5 degrees on both sides. Does that sound in the ballpark? The template doesn't really help much there.
