Thanks Thanks:  35
Likes Likes:  50
Page 3 of 3 FirstFirst 123
Results 81 to 109 of 109
Thread: The Baroness: MkIV Roadster Build Thread
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Pmieras View Post
    Not in San Diego but San Tan Valley, AZ. Definitely won't need it in the summer time.
    But some drives during the fall or early spring would be nice to have heat.
    I debated a heater for a long time and even ordered it with the kit. In the end I didn't want all of the headache of installing it and everything that goes with it so I just did the heated seats. The seats are surprisingly effective and so far they're all we've needed.
  2. Thanks Pmieras thanked for this post
    Likes Pmieras liked this post
  3. #82
    Mar 2024
    Kansas City, MO
    Great videos, really enjoying them and appreciate the amount of work it takes to shoot, edit, and upload them. Maybe it's easier than the paragraphs of text and pics that I did in my build thread, but either way I appreciate being able to see the story of the build.
    Love the 'valve covers' over the coil packs. Nice touch for the engine bay. Keep it up!
    Build thread: https://thefactoryfiveforum.com/show...809#post556809
    MKIV received 5/15/24
    Blueprint 302, TKX midshift, IRS, PS, Wilwoods, 15" Halibrands
  4. Thanks Pmieras thanked for this post
  5. #83
    Apr 2023
    San Tan Valley, Arizona
    Quote Originally Posted by JMD View Post
    Thanks. I'm having fun with the build. Really enjoying the process and working out the problems. The video process does take some time. I've gotten quicker at editing. Funny thing is that one of the videos showed me a bolt I didn't tighten on the power steering pump. As soon as I saw it I ran out there and took care of it quick.
    Kit delivery (3/17/2024)
    FFR Mark IV Roadster (Ordered 11/9/2023)
    408 LS Stroker Powerplant Ready To Rock (link below of the first start)
    https://youtube.com/shorts/dH36tij3HK0?feature=share
  6. #84
    Apr 2023
    While I'm sorting out the other issues, figured I would work on the fuel lines.
  7. #85
    Apr 2023
    My solution to my heater core problem...
  8. #86
    Ottawa, Canada
    Great videos, watching them all and following the build. With the last cut for the heater you could consider adding the dash support tubes like the originals.
    Mark IV FFR 7993 picked up March 30, 2013
    Pin drive IRS, 390FE, Smiths gauges. going to be a long slow build.
  9. #87
    Oct 2020
    Albany, NY
    Honestly that dash supported solves a few potential problems. I like it better than the stock setup.
    Nice work.
  10. Thanks Pmieras thanked for this post
  11. #88
    Apr 2023
    Quote Originally Posted by achi View Post
    Are those the tubes that run from the dash to the transmission tunnel? I might be doing something like that when I get further along with the dash install.
  12. #89
    Ottawa, Canada
    Yes,exactly. I know F5 was selling a faux set of supports that I belive attached to the bottom of the aluminum dash, and since you are there and you definitely have great fabricating skills thought you might consider that as well. Great work!!!
  13. #90
    Apr 2023
    I'll probably come up with something once I get to the dash going in. Have several things in mind that I'm sure I'll end up overthinking... LOL
  14. #91
    May 2023
    If the heater core leaks or something in the future... You can un-solder the fittings. Just fire up the fitting wit a good MAP gas torch. MAP is hot so you can heat the fitting quickly to remove the joint. Then hit the copper with a wet rag so the heat doesn't melt anything down the line. I've done it many times when I worked HVAC back in the day. Just in case you have to take it apart down the road for some reason.
  15. Thanks Pmieras thanked for this post
  16. #92
    Apr 2023
    Forte Throttle linkage goes in.
  17. Likes cv2065 liked this post
  18. #93
    Much of what you are doing hasn't been documented on video before for future builders and in certain ones, I can feel your pain. Great job!
  19. Thanks Pmieras thanked for this post
  20. #94
    Apr 2023
    It's been fun working out the problems. Trying to make it work and look nice.
  21. #95
    Mar 2024
    Kansas City, MO
    It's a nice linkage, but takes a lot of brain power to get all the geometry right, in my experience. I also used a self tapping sheet metal screw instead of the roll pin. I wasn't convinced the roll pin would stay. Love the end result, but it's a hell of a lot more work than a throttle cable! Good video.
  22. Thanks Pmieras thanked for this post
  23. #96
    Apr 2023
    Lot more figuring out than I thought it was going to be. But I still like the look. Still happy with it.
    Good idea with the screws. I undersized the hole for the role pins so they're in there pretty good. I'll probably check the tension on the roll pins once I'm able to put some heat in the engine bay to see if they're still tight but will definitely keep the screws in the back of my mind.
  24. #97
    Apr 2023
    All the radiator lines go in
  25. #98
    Mar 2022
    You're Mk4 is coming along! Can't wait to see more. This is such a great build thread with the videos!
  26. #99
    Dec 2021
    Flower Mound TX
    I like the mesh sleeving over the hoses, looks nice. You might look at the Powergrip clamps that shrink on to make a clamp. https://www.summitracing.com/parts/aaf-all30257
    I'm running them and they work great.
  27. #100
    Apr 2023
    I've heard about those. I thought about it and might make a switch to them. With all the on and off trying to get this aligned I guess I forgot about them.
  28. #101
    Apr 2023
    Install an E-Stopp parking brake
  29. Likes cv2065 liked this post
  30. #102
    Apr 2023
    Trying to wrap up a couple of small things in preparation for the daunting task coming up...
  31. #103
    Apr 2023
    Got talked into it. Change out the header bolts for studs.
  32. #104
    Dec 2021
    Flower Mound TX
    Nice! I love studs, probably because I am one I use studs in both my day job designing equipment and my hobby stuff, so many advantages to them. Especially when going into a soft material like aluminum heads. And studs makes assembly soooo much easier as you saw.
    Are those Remflex gaskets?
    I do want to know how you applied that anti-seize without ending up looking like this.
    Tip of the day for you, get rid of those nuts you're using on the ball socket flanges and use brass nuts like these. https://www.amazon.com/dp/B000IZ49HC...fed_asin_title they won't loosen up on you but you can still get them off if you need to.
    I paired them with these bolts https://www.amazon.com/dp/B000CFS6NG...fed_asin_title
  33. #105
    Apr 2023
    Yes. Remflex gaskets. I'll see how they hold up.
    The anti-seize does get everywhere. Lol. I do a lot of wiping the brush against the inner edge of the can before application and constantly clean the lid. Not sure if it helps much, but that's my process.
    The bolts I have on the ball flanges are not the one's I'm going to use. Using them for now just cause they go together really well by hand since it will probably come on and off multiple times.
    I have given thought to the brass and will probably use them. Thanks for the tip.
  34. #106
    Apr 2023
    Seat and steering wheel go in so I can start mocking up other stuff... and make car noises as I pretend to drive it.
  35. #107
    Apr 2023
    Shifter goes in.
    Seems to fit me nice. I like where it ended up landing.
    Very short throw which I like so far.
  36. #108
    Apr 2023
    The start of the electrical work is in full swing. Starting with the easy stuff for the engine management side of things.
  37. #109
    Apr 2023
    More wiring stuff. ECU finds it's home.
  38. Likes Justin liked this post
