Likes Likes:  6
Thread: Ride Height and Rake
    Dec 2018
    Sherwood Park, AB
    Question Ride Height and Rake
    Hi Folks,
    I had my MKIV aligned to specs at a shop at initial build. Some ~4000 miles later, I'm curious about ride height (shocks were set identically left to right, per spec, originally). No driver, and tank about 1/2 full.
    DF = 3 9/16" PF = 3 10/16"
    DR = 4 8/16" PR = 4 9/16"
    D Rake = 15/16" P Rake = 15/16"
    Rears are 315/35/R17 and Fronts are 255/40/R17, so 0.65" of the 0.9375" rake is tire diameter, leaving just under 0.29" for suspension-related rake.
    So, the rake is identical on both rails, but the passenger side is higher than drivers by 1/16" front and rear, and that's without me sitting in it. I have the Coyote Gen 3 with Tremec TX. IRS. Battery in center of trunk. There is a little more weight on the driver's side, for the steering, footbox, pedals.
    Street car only. I'm just curious what other people have noticed. Thanks.
    32J
    Jul 2021
    Tonganoxie, KS
    It's a sixteenth of an inch. I'd say you're good, especially after 4000 miles.
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  3. Likes 32J liked this post
    O'Fallon, MO
    OMG, a 1/16 of an inch
  5. Likes 32J, Bill Elliott, cv2065, Mike.Bray liked this post
  6. #4
    Dec 2018
    Sherwood Park, AB
    Yeah, I know I know... Nothing about these cars is square to the word Just curious what other people are seeing. I knew there would be some rake with the wheels, but I didn't know with the suspension it would be nearly an inch.
  7. #5
    Scales tell the story, not a ruler.
  8. Likes Ducky2009 liked this post
  9. #6
    David aka Ducky2009
    Lilburn, GA
    As Jeff said, scales tell the story. I set mine to 4" on the front and 4.25 on the rear, then did four corner weights. I never went back to check the height.
