Thanks Thanks:  40
Likes Likes:  124
Results 1 to 40 of 471
Thread: Tim's Type 65 Build - Cockpit Wiring Finished?
Threaded View
  1. #11
    Nov 2020
    Damascus OR USA
    Fuel System
    We have been on vacation for a bit but managed to make some headway on the fuel system. I put the tank together, widened the holes on the straps since the 3/8" bolts wouldn't go through and prepped everything for the tank install. I opted for a fuel pump and hanger from Quantum Fuel Systems. I was leaning this direction after a conversation with Blitzboy54 (Jesse) and then had an issue with Pro M which somewhat sealed the deal. It really seems like a quality part and pretty happy with the price. Everything you see in the picture came with the unit. Tested it, received a satisfying hum and popped it in.
    I also went to my local dealer and picked up this little gem based on recommendations from, well, everyone:
    I also picked up the Breeze oversize vent setup and popped it in as well. Tested the fuel level sender and all is good to go. Just waiting to be lifted into position:
    I do have a question though. I did not see anything in the manual about adding any kind of rub strip/anti-squeak around the perimeter of the tank lip. Perhaps I missed it or this isn't a concern? Any feedback would be appreciated.
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
