So I took probably 3/8 off of that bolt (Didn't take anything off of the clevis or the pedal) Works perfectly. I have it installed in the car, with the pedal setup as far forward as possible (basically 1/16 off of the cross member). When I bottom out the pedal, I can get 2 fingers between the pedal and the firewall. When I say "bottom out" I mean the threaded/welded component will no go ANY further (I'm betting that the Wilwood MC is bottomed out at this position).
This appears to be the full range of motion of the hydro-boost. I have to assume that the hydro-boost/pedal side of this setup isn't moving anywhere near the 1.1".
Of course this is all with NO hydraulic fluid/power installed yet! Hard to get to test the whole thing yet with no motor in the car yet!
Let me know if you want pics of anything in my setup or a video of how mine is functioning to compare it to
RR
