I have made some progress over the last few days. I have been testing, trimming, drilling and mounting panels. I found most of them fit fairly well but if you are concerned about the edges being parallel with the frame bars, etc. it takes a bit of fitting to get just right.
Going to remove all the panels for prep to go to the powder coater and also free up some Clecos so I can do the radiator surround and fan/fan shroud. Once those are complete I will send the lot. I haven't quite figured out if there are other panels I should be including but these should encompass all the engine bay panels. I am going with a different color than the remainder of my panels so I'm trying to make sure I include them all in my first batch. I know there are some wings or outriggers that may be visible with the hood up so I will need to double check on those.
