47
48
Actually, I have another question. How do you determine the height of the master cylinders: tops of the lids w.r.t. where the fiberglass body will be? I haven't had the body on since original delivery, and it isn't convenient now to do that. It seems there should be a dimension above or below the 3/4" square tubing that can be used as a "keep out" point. Thanks!
