We tried to put the body on Tuesday, but it was a no-go. I had to trim a bit off of the lower rear fiberglass and adjust the radiator to make is not extend past the quick jack mounts. I thought the latter was going to be an issue and it was. I hope those two changes and some better coaxing of the body will allow this body to go on to see if I still need to trim the cockpit opening, front and rear. I will also check my expected gas cap location with the body on.
