Thanks Thanks:  48
Likes Likes:  178
Page 23 of 25 FirstFirst ... 132122232425 LastLast
Results 881 to 920 of 965
Thread: Making progress on my build...
  1. #881
    Feb 2019
    Houston, TX
    That is VERY cool.
    Laser welding, 3D scanning, and 3D printing are all areas I have really wanted to get into but just haven't.
    Hit me up if you want to have a conversation about 3D printing. I've been 3D printing car parts since 2009.
  2. #882
    Indiana
    A 3D scanner is the #2 item on my list of things to buy (after a new ECU for my 818) once I sell my current project. Mind sharing a little bit about why you picked that specific one?
    This is still a "consumer" grade scanner, although it's on the higher end. Not professional by any means ($15k +++). The $1k consumer scanners do ok for larger objects (6"+) but fall on their face scanning smaller parts/objects. Some of the brands rely on kickstarter purchases then the business model is to release a new model immediately. These don't perform very well at all. Anything under $1k seems to be junk unfortunately. You can probably get away with a $1k scanner. Shining 3D is a reputable company that makes $25k+ scanners and the cheaper scanners like the one I bought benefit from the software development of the "big boys". Software is a major contributing factor to a quality scan.
    I've been printing for about the same amount of time. Always something new to learn, I appreciate any help I can get!
    GTM #304 LPE 525hp LS3
  3. #883
    Feb 2019
    Houston, TX
    Quote Originally Posted by beeman View Post
    always something new to learn, I appreciate any help I can get!
    I was directing my comment towards Crash, you certainly have a lot of experience with the craft. It is crazy how far it has come, I just found my first 3d printer a few weeks ago tucked away. Sanding drums for gears and shoestrings for belts.
  4. Likes beeman liked this post
  5. #884
    Feb 2019
    Houston, TX
    I had been eyeing this one. CoachBuilt on Youtube was getting really good scans of engine pieces with it:
    https://www.einstar.com/products/pro...RoCS9oQAvD_BwE
    Looks like what you bought is the next model up.
  6. Likes beeman liked this post
  7. #885
    Indiana
    Just started playing around, very impressed with the capabilities, and very easy to use.
    Gif attached 19MB, may take a minute to load.
    https://i.postimg.cc/0j9xp4RP/GIF-20...163247-199.gif
  8. Likes VRaptor SpeedWorks, LLC liked this post
  9. #886
    Indiana
    Quick scan of the front bumper to see how it does with larger scans. It's still fairly rough with exposed body filler. Scanner didn't reliably see the edge of the fairly glossy hood, so I applied some scan spray which disappears after a few hours. Plenty of data here to mod the fascia.
    FYI these are 0.5mm resolution scans.
    Another large gif file in this post.
  10. Likes VRaptor SpeedWorks, LLC liked this post
  11. #887
    Very cool!!
    Shane Vacek
    www.vraptorspeedworks.com
  12. Thanks beeman thanked for this post
    Likes ohmygosuness liked this post
  13. #888
    Jul 2014
    That's awesome!!!
    In a prior life, we had to use a similar spray when we white light scanned parts for dimensional evaluation. These were machined F-135 engine parts for the afterburner section of the engine. Ridiculously tight tolerances and basically needed this method of inspection to prove every single point on a machined surface met the profile tolerances. Insane in that you needed basically a mini super computer to handle the amount of data it captured in about a 5 second scan.
  14. Likes beeman liked this post
  15. #889
    Indiana
    Life has been very busy with kids sports. Working with a 3D mesh, I have had to switch CAD software. I was using designspark mechanical, which I really like. But it seems like everybody is moving to Fusion 360. Little bit of a learning curve, working with forms, surfaces, t-spines etc is completely different than what I'm used to which was basically creating drawings, then extruding, then filleting, etc.
    So import the mesh into Fusion. Create a surface which matches the mesh. Create the surface shape of the part. Thicken and export as STL. Divide the part so it fits on the printer. Print and reassemble.
    I'm leaning towards this style of intake vs the previous fancy design. I think this will scoop more air with less drag.
    I'm going to redesign the front angle to point towards the corner of the rear hatch, like I marked in the attached photo, to better tie into the lines of the car.
    Three gif's attached.
    Thoughts?
    20250223_204312.jpg20250223_204040.jpg20250223_203721.jpg20250223_203803.jpg20250223_204128.jpg
  16. #890
    Feb 2019
    Houston, TX
    Thoughts?
    I'm not qualified to talk about how this will collect air versus the lambo design, but I agree it fits much better with the curves of the car. it's not too dissimilar to what I arrived at for my 818:
  17. Likes beeman liked this post
  18. #891
    San Diego
    I like that you filled in behind the door frame. Cleans that up nicely. Not so sure about the angled scoop. I think a bigger picture view would maybe give a better idea of how it fits and flows with the rest of the body.
    Roof scoops are along these same lines. What fits and works is one thing, and what actually looks good is another. I have seen plenty of functional roof scoops on prototype cars that I am sure work perfectly well, but IMHO, ruin the side view of the car's lines.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  19. Thanks beeman thanked for this post
  20. #892
    Indiana
    Mike-
    I angled the scoop because every airflow/CFD analysis I've seen on a moving car shows air crashing down off the roof to the side of the car. I think that an angled scoop will more efficiently capture that air. Perhaps I should parallel the b-pillar angle for better aesthetics? What do you think?
  21. #893
    San Diego
    Obviously if you run with your roof off it won't matter much, but I think you should at least mock it up with the same angle as the B pillar. I would just put some cardboard in there and paint it black and see how it looks from different angles while you move around. I believe in prioritizing function, but form is also super important in cars like ours.
    www.myraceshop.com
    GTM solution kits
  22. Likes beeman liked this post
  23. #894
    Sep 2015
    Hamersville, Ohio
    I made a similar pair of scoops for my 818 but after I put them into place, I didn’t like the look. Mine parallel the B-pillar and bow outward to form a scoop. Mine are acrylic and allow a view of the candy store.
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
  24. Likes beeman liked this post
  25. #895
    Indiana
    I've come to realize that there is a HUGE learning curve with surface modeling, much more so than general/mechanical CAD. It's very difficult to create precise surfaces in 3 dimensions that end up looking the way you want them to look and ending up exactly where you want them to be in space.
    The initial plan was to incorporate my existing bumper (aftermarket MR2 Spyder) and modify the bumper to fit my needs, ie the radiator intakes and tying into the rest of the bodywork. After quite a bit of modeling and some thought, I decided to scrap all of the work I had done and start again from scratch. Looking around for OEM front bumpers that had dual radiator setups, I chose the Lamborghini Gallardo as the starting point. It was easy to find a 3D model. Unfortunately, it is not as simple as importing an STL file and modifying it, you cannot directly model an STL file in Autodesk fusion. So quite a bit of Hands-On modeling to create a t spline model which can be modified to fit the hood, headlight, fender flare, radiator, etc. I changed quite a bit of the shape of the fascia, leaving me with a pseudo-Gallardo front end, but it was a great shape to start with. At this point it just needs a couple areas of small touch ups followed by 3D printing.
    I'll probably print a miniature to see it in the flesh. For the full-size, will have to break the model down into pieces that fit on the printer and then reassemble them. Options beyond that would be skinning with fiberglass or carbon fiber versus creating a mold and a new fiberglass bumper like I did previously with the hood and spoiler.
    Three GIF files attached, fairly large, may take a minute to load.
  26. #896
    Feb 2019
    Houston, TX
    For my 818 I used a program called gravity sketch on the oculus. That allowed me to trace components of the car in 3D dimension, then literally use my hands to push and pull the panels to get the exact look I wanted. With the 3D scanner you could skip the tracing part (which was very clumsy) and just go straight into creating your shapes in 3D with your hands.
  27. Thanks beeman thanked for this post
  28. #897
    Indiana
    v2.0
    Gallardo based, modified rad intakes to match my layout. Added dive plane for splitter.
  29. Likes VRaptor SpeedWorks, LLC liked this post
  30. #898
    Indiana
    High speed prints at low layer resolution to see it in the flesh. Fits basically perfectly. Air forced into the radiators (will have full ducting). Going to make a couple of small changes.
    Suggestions?
    Attachment 212928Attachment 212929Attachment 212930Attachment 212931Attachment 212932
  31. #899
    Apr 2021
    v2.0
    Very interesting. Is your radiator going to be scoot to the side as well? I believe that's what these vents are for on the Gallardo. It also has one fan on each side behind these vents.
  32. #900
    Indiana
    Radiators are vented to the wheel arches
  33. #901
    Jul 2014
    Suggestions?
    For some reason these are not loading for me
  34. #902
    Jan 2025
    Chicago IL.
    Lets us know if we can be of any support! Exciting build, good luck.
    www.infinitybox.com
  35. Thanks beeman thanked for this post
  36. #903
    Indiana
  37. #904
    Jul 2014
    Nice!!!!
  38. Thanks beeman thanked for this post
  39. #905
    Very cool!!
    Shane Vacek
  40. Thanks beeman thanked for this post
  41. #906
    San Diego
    I can't wait to see the complete front end.
    It looks like you considered a higher profile headlight lens by looking at the finger drawing in the dust? I think the higher lens would be my choice.
    www.myraceshop.com
    GTM solution kits
  42. Likes beeman liked this post
  43. #907
    Indiana
    No plan to change the headlights at the moment. I want minimalist and lightweight, single projector on each side are plenty bright. The finger drawings are courtesy of my 9 year old
  44. #908
    Indiana
    I think this is about version 6.0. Switched to Blender for the 3D design, it seems to do much better with organic shapes (vs Fusion, still will use Fusion for more mechanical parts). I really like it, printing passenger side now, then will finalize in fiberglass.
  45. #909
    Feb 2019
    Houston, TX
    I find gravity sketch on an Oculus perfect for organic designs. You can literally push and pull curves, edges, and planes with your hands and can look at them in 3 dimensions just by tilting your head.
  46. #910
    Indiana
    Have you tried modeling and printing a part with gravity sketch? Would be cool to see in 3D. In Blender, you can 'paint' and give different finishes , ie matte to gloss, and see it rendered in 3D but it's still on a flat monitor screen.
  47. #911
    San Diego
    Wow beeman.
    Super cool looking stuff.
    www.myraceshop.com
    GTM solution kits
  48. Thanks beeman thanked for this post
  49. #912
    Feb 2019
    Houston, TX
    You can texture and paint in Gravity Sketch. It's been about 3 years since I used it, so probably been some improvements, but at the time I could only export a mesh, which I then imported into Fusion and converted to a solid so I could cut it up (slicers only offered planar cuts back then) and 3D print it.
  50. Likes beeman, VRaptor SpeedWorks, LLC liked this post
  51. #913
    Jul 2014
    I did all my GTM 3d printed modeling in Blender, mainly because it was free and wasn't terribly difficult to find YouTube videos on it.
    Been a while since I used it, but very capable software to do what I needed it to do.
  52. Thanks jbs72697 thanked for this post
  53. #914
    Indiana
    Just need to modify a couple of edges/gaps then some filler and make a mould. May sandwich the plastic in fiberglass instead. This plastic weighs about 6 lbs, 15% infill.
    20251016_162159.jpg20251016_162152.jpg20251016_162146.jpg20251016_162135.jpg20251016_162123.jpg
  54. #915
    That's looking nice!!
    Shane Vacek
  55. Thanks beeman thanked for this post
  56. #916
    San Diego
    My thought is that the sandwiching will not work very well. The plastic likely will not bond well to the resin in the FG, and the 1/4" or so of extra "dimension" will not match the other panels.
    My vote is for doing the extra work of making a mould and coming out with a proper finished product.
    www.myraceshop.com
    GTM solution kits
  57. Likes beeman liked this post
  58. #917
    Indiana
    With this door design, with the power window structure as it is in the door, I don't have a great place to put a robust pull handle to slam the door (it would be an awkward angle, in line with the seatback) . Instead of stressing the door components with a pull handle in an ergonomic location, I installed BMW soft close latches. Pretty simple + and - installation, no external control module. Haven't adjusted anything yet but I really like this!
  59. Likes VRaptor SpeedWorks, LLC liked this post
  60. #918
    Feb 2019
    Houston, TX
    Very Nice. How would those work with a popper?
  61. #919
    Indiana
    I am not sure, I've never used a solenoid popper. These function like a normal latch, with the soft close as kind of an add-on accessory. Meaning you can still slam the door and bypass the solenoid. The latch will still work if the solenoid fails. The release to open the door is identical to any typical door latch. The soft close motor does nothing functional when you release the latch to open the door, although you hear a brief motor 'reset' after the door opens.
  62. Likes VRaptor SpeedWorks, LLC liked this post
  63. #920
    Indiana
    Modernized the headlights with a pair of projector LEDs. Cardboard Aided Design, followed by CAD.
  64. Likes VRaptor SpeedWorks, LLC liked this post
