Thanks Thanks:  7
Likes Likes:  18
Results 41 to 80 of 109
Thread: Wedel456's Build Thread - Gen3 Coupe - North Carolina
    Mar 2024
    Marvin, NC
    Thought Capsule: Electrical and Main Power
    Now that all my panels are done, powder coating completed (at least for the 100 percent necessary panels at this point), the engine is on order, and I have worked out the switch and relay situation, I started thinking about how I wanted to run the wiring. After reviewing multiple builds, I decided I like the clean and hidden wiring path of @P100DHG and the Ron Francis location from @EdwardB.
    Wiring Paths:
    1. The Ron Francis wiring will be installed under the driver's side dash, with most of it being hidden by the custom panel.
    2. The Ron Francis wiring will run through the upper right-hand corner of the custom panel into the back of the dash and then down through holes drilled through the left top side Front Top Transmission Cover.
    3. All front harnesses will run down the transmission tubing, then along the driver's side bottom frame rails, splitting to go out to the engine components (tach, oil pressure, water temp, etc.), and then to a split for the headlights and fan. This is the same wiring path as P100DHG. This is the optimal path if you are looking for the wires to almost completely disappear
    4. The rear harness will go in the opposite direction, following the brake lines, then splitting to the left and right taillights and the required wiring for the sending unit and fuel pump.
    5. The main battery feed, starter wiring, etc will run along the passenger side frame rail up through the transmission tunnel to Ron Francis MS-01, documented below.
    Main Power Plan:
    For the main power setup, I have decided on the following configuration:
    1. Battery - I will be using an Odyssey PC925 battery for its compact size and reliability along with their terminal kit (could not find the PC925T with easy shipping and this ended up being cheaper). The terminals for both positive and negative will be soldered crimpless terminals and protected by covers (positive and negative)
    2. Battery to Disconnect - A #2 AWG cable will run from the battery to the Ron Francis MS-01 disconnect located on the passenger side of the cockpit, near the transmission side panel.
    3. Battery to Starter - On the same feed post of the disconnect, a #4 AWG cable will run to the starter.
    4. Under Dash Power - On the switched side, I’ll be using a #6 AWG cable to power a 150A bus bar that will be installed somewhere inside the cockpit, behind the dash.
    5. Battery Grounding - The main ground will be a #2 AWG cable running from the battery’s negative post to a grounded spot near the front corner of the engine bay on the passenger side. This will be accomplished by grinding away the powder coating and using a 3/8-16 flange head screw into a tapped hole for secure grounding.
    6. Alternator - The alternator will be directly connected back to the battery using a #4 AWG cable through a mega fuse for protection.
    7. Grounding Bus Bar - I will also install a grounding bus bar under the dash. This will be grounded to an additional location by removing powder coating and using a 3/8-16 flange head screw for a secure connection.
    8. Under Dash Grounding - All electrical components under the dash, including lights, switches, and other accessories, will connect to a grounding bus bar to ensure a centralized, organized, and easy-to-manage wiring system.
    Open Items
    I am still looking for mounting locations for the CDI box (MSD 5520). Once that location is ermined I will need to decided on all the cables are run to the engine for monting. I plan on using as much as the Ron Francis wiring harness to connect into the CDI.
  2. Likes JimStone liked this post
  3. #42
    Mar 2024
    Marvin, NC
    Thought Capsule: Relays
    Relay Boxes Setup:
    After a bit of head-scratching and some research on how to fit everything in such a compact space, I found a great deal on Amazon for True Mods Relay Boxes. Each kit comes with the box and six relays, plus a built-in fuse box. The boxes are mounted using screws and 1/4-20 rivnuts on the same support as the dash, which allows easy access and a secure fit. I was initially worried about only having support on one side of the box, so I opted for larger screws to ensure stability.
    First Relay Box (Functions):
    1. Fan Relay – This will be a ground-based relay, powered by the Ron Francis DK Blue - Cooling Fan wire, that’s ground switched via a SPST toggle switch on the Toggle Switch Panel. It will allow the fan to be controlled manually, but it can also be triggered automatically by the EFI or A/C system.
    2. Wiper Relay 1 & 2 – These will control the front wipers, with two relays handling separate functions for the system. The setup is using the P100DHG setup. These relays are powered by the Ron Francis PURP-Wiper wire and is a ground based trigger using DPDT toggle switch in the Toggle Switch Panel.
    Second Relay Box (Functions)
    1. Fuel Pump Relay – This relay will get power directly from the battery through the built-in fuse box. It will only activate when the SPST Toggle Switch Panel is in the "on" position and the Digital Guard Dawg PBS-1 is enabled (meaning I’m within range with the key). This provides added security, ensuring that the fuel pump won’t run unless I’m within range, and if I forget to turn it off, the system will handle it for me when I leave range. This relay will directly power the fuel pump and will tie into the Ron Francis Tan-Elect Fuel Pump wire.
    2. Fog Light Relay – This is a ground-based relay that requires both a SPST switch in the Toggle Switch Panel and the light switch to be in the "on" position. The relay will be powered via the IDidIt module, which is enabled when the light switch is pulled out. The fog lights will be powered via this relay and will run over new wires that need to be run to power the fog lights and will ground by connecting into the driving light grounds
    3. PBS Enablement Relay – A ground-triggered relay connected to the "Ground When Enabled" port on the Digital Guard Dawg PBS-1. This will trigger when the key is in range, enabling other relays in the car to work. The relay is powered by the battery and feeds power to other relays.
    4. E-brake Relay – This relay powers the warning light on the dash when the e-brake is engaged. It’s triggered by the Digital Guard Dawg PBS-1 and the e-brake. I’ll go into more detail about the e-brake system in a future post, but this relay ensures that the warning light will be on, regardless of whether the car is running or not. The relay receives power from the PBS Enablement Relay, again, will only power the light when the key is within range AND the e-brake is enabled.
    5. Clutch and Safety Switch Relay – This will allow the car to start (and turn off)by either having the clutch or transmission safety switch to be engaged. Yes, both are the same thing but wanted some redundancy just in case one was to fail. Did not want to get stuck. I’m still working on the wiring for this one, as I don’t want the full starter switch wire power to go through this relay (if possible) and do not want to connect this directly to the battery. This is even more difficult because the default setup for the Digital Guard Dawg PBS-1 requires the brake to be pressed BEFORE the car will crank and BEFORE the car is turned off. Suggestions are welcome! *** solution here ***
    6. Headlight Buzzer Relay – This relay triggers a buzzer to warn me if the headlights are left on after the ignition (on the Digital Guard Dawg PBS-1) turns off. It connects to the light switch through the IDidIt module and uses port 87A (Normally Closed) on the relay. Teh relay is powered via the Headlight switch (via the IDidIt module) and is triggered via the Ignition wire on the Digital Guard Dawg PBS-1. This will make it so the buzzer only buzzes then the headlight switch is on and the ingnition is off.
    *for reference, here is a chart if you are looking at copying all or some of this.
    Conclusion:
    By using these relays, I’m able to integrate modern functionality into the car while maintaining its vintage appeal. The relay boxes are compact, efficient, and allow for easy management of the car’s electrical system. This setup provides a clean, minimalist dash and ensures that I can control the car’s various systems with modern convenience and security, without the risk of simple mistakes like leaving lights on or running down the battery.
    Let me know if you have any suggestions or questions!
  4. #43
    Mar 2024
    Marvin, NC
    Panel Finishing and Off to the Upholsterer
    In past posts I discussed the plans on how I was going to upholster the panels I selected to cover with vinyl. Since making those decision, I also decided to move forward with FatMat RattleTrap as discussed in my Thought Capsule: Sound and Head Deadening post.
    The first panel that I put this material on was the Front Top Transmission Tunnel panel. I needed to do this so I could start the wiring process:
    It came out great and boy does suit deaden all the sound. HOWEVER, after talking with my upholsterer I learned that the lines that I documented in my Thought Capsule: Sound and Head Deadening post were going to be a major issue if I wanted the panel vinyl to lay flat. This would require a deep dive into my wife experience with Bondo. It took a while but I eventually got the panel very flat, or at least flat enough where it will not show through with foam on top. The upholsterer actually complimented me on how well it turned out.
    Since I did that specific panel I with the RattleTrap and the bondo work, I had to do the same with the Transmission Tunnel Top panel (the one where the shifter sticks out) as I was concerned there would be a thickness difference between the two panels if one got foam and RattleTrap and one did not. This required many more hours of Bondo and sanding work. Overall I would say I put 8 hours into learning how to do this and sanding it flat. If you have not done this before I would recommend getting some plastic putty knifes and do not cheap out on the sand paper.
    Once you get the hang of it is much easier. I ended up using the some Bondo on the dash to get it perfectly straight, too.
    For now, the dash, the two custom footwell panels, the panel under the drivers side dash, and the Front Transmission Tunnel panel are off to the upholsterer. I kept the:
    1. Top Rear Transmission Tunnel - As I have not install the engine and transmission yet. I am confident everything will fit with the mid-shift for the TKX based upon other threads but want to make sure before I cover it.
    2. Switch Panel - I am very concerned about the spacing between the dash and the bottom of the panel as it is already tight even without the foam and vinyl. Once I get the dash and Front Transmission Cover back I will test fit the switch panel to ensure everything fits correctly.
    As discussed in the Thought Capsule - Panel Finishing post, only the Front Transmission Tunnel and the Transmission Tunnel Top will get foam. Due to Thanksgiving I should have the first batch of things back the week of December 9th.
  5. #44
    Mar 2024
    Marvin, NC
    Electronic Parking Brake Rear Retrofit Brake Kit
    When I was reviewing the options for the e-brake, I really never liked the idea of the e-brake handle on the transmission tunnel. I thought it looked out of place and would interfere with the arm of any passenger. All the older cars I have owned have always had under-dash foot pedals (my 1967 Mustang had an under-dash handle, and my 1971 C10 is foot-operated). This just made more sense to me and seemed like a cleaner installation.
    Then I ran into @RSnake's video on his Wildwood electronic brake installation, and I was sold. The clean, modern feel of it just clicked, and I knew it would be the right choice for my build.
    I pulled the trigger on that purchase and had it match the FF-provided brake red (obviously). The installation was straightforward, and it went on the bracket just like the manual ones. The real issue, however, was the wiring harness:
    1. I need to find yet another place to house the brain, which is ENORMOUS for some reason (almost 5.25 X 5.25 inches). My current thought is to place this in the upper right hand corner of the Front Top Transmission Cover using some velcro. The velcro would allow for easy removal if there is a problem with the unit post installation without taking off the dash. Additionally, there is no room for everything needed under there to install this with screws.
    2. The wiring harness is EXTREMELY long since it’s a universal kit, so it will need to be trimmed dramatically. Additionally, the wiring harness is well-protected with a plastic cover and tape, which only made it harder to remove. It took me a while to deconstruct it.
    3. The head on the wiring harness that connects to the brain is HUGE. It will never fit through any of the holes that I’ve drilled. This means that once the Front Transmission cover is installed, it won’t be coming off without some work. As I diet the harness, I will look for ways to possibly install an adapter that can be disconnected at the transmission front cover. I'm not 100% sure I can make that happen, but I’ll give it a shot.
    I spent way too much time (hours) trying to decide where to place the switch to enable the e-brake. The switch looks fairly modern, which I didn’t like, and I didn’t want to put it somewhere that someone could accidentally hit it. It's a bit of a dumb device since, unlike newer cars, it can be engaged at any speed and doesn’t disengage when you put the car in gear and start moving.
    Based on those two issues, I decided to hide it on the side panel of the driver’s side of the dash. This will allow only me to turn it on or off, and it won’t be seen by anyone else.
    *it is the whole to the left
    As I mentioned in my Instrument Panel Planning and Related Items, Thought Capsule: Switches, Lighting Control, Buttons, etc., and Thought Capsule: Relays posts, I will be able to know if the e-brake is engaged by a light on the dash that is triggered when I am in range of the Digital Guard Dawg PBS with a key.
  6. #45
    Aug 2019
    Spokane, WA
    Quote Originally Posted by wedel456 View Post
    I am using the kit-provided clutch and brake reservoirs. In the last post, I mentioned where they were going to be installed—in the panel right in front of the driver's footbox.
    For those of you who have these or have installed them previously, you know the provided installation brackets have ears, and you use button head screws to install them vertically. Well, the space in this location wouldn't support that. As such, I decided I needed to make my own bracket. I cut the ears off using my band saw, sanded them smooth with the belt sander, and purchased 1/8" (I thought 1/16" would be too flimsy, but 1/8" worked well) L-channel from Lowe's.
    My initial thought was to drill through the Factory Five-provided brackets and then mount them to the L-channel using 1/4" flathead screws and lock nuts. However, I was concerned that this could result in some movement. Since this was going to be installed through the top panel, I decided to drill and tap the holes—meaning the screw would go through the provided brackets and then be held to the L-channel with a lock nut.
    After this, I used the band saw to eliminate the material required for the reservoirs to be installed on the L-channel, and cleaned that up with the belt sander (don't have a picture with it done but here is the pre completed picture to illustrate):
    You’ll notice that the spacing on the brackets isn’t consistent. This was intentional to make it obvious which is for the front and rear brakes and which is for the clutch.
    I then determined where the reservoirs and bracket would mount and drilled holes for future 3/8" rivet mounting. Make sure there’s enough room to get a drill bit and rivet tool in there. Also, ensure the bracket is installed low enough to allow for engine vibration, even when it's in place.
    Once held in with Clecos, I used a 2.5" hole drill bit to drill through a piece of 3/4" plywood. I then used the round piece of plywood as a guide by placing it into each reservoir mounting bracket and drilling a pilot hole through the top panel. Once the pilot hole was completed, I used the same hole cutting bit to drill the hole large enough for the reservoirs to poke through the panel. It came out AWESOME! - obviously they will be installed level but will work on that during the final installation process:
    My original plan was to do a round-over punch, but the holes were too close together for that to work. I’m thinking about using some sort of ring around them—possibly stainless or something similar—but have been unable to find something that works. Suggestions would be greatly appreciated! For now, check this box as done.
    You've made quite a bit of progress since the summer. Looking good!
    I'm also planning to use the F5 supplied reservoirs (three total as well). Thanks for the write-up on how you got them to fit in that space forward of the left FB. I would like to do the same. Great tips!
  7. Likes wedel456 liked this post
  8. #46
    Mar 2024
    Marvin, NC
    LED Lighting
    My LED lighting plan essentially copies @EdwardB:
    1. Headlights - I will be using the Watson Streetworks Vision Plus Lenses and H4 LED bulbs package.
    2. Fog Lights - Have not purchased them yet; however, I cannot find ones that I like more (waiting for a Black Friday deal). I will be using the KC Gravity LED G4.. As documented in the Switch Panel and Thought Capsule: Relays posts, this will be powered via the headlight switch, can only be turned on when the headlights are on, and will be controlled by a SPST switch on the Toggle Switch Panel.
    3. Front Marker Lights - Using the FF kit provided lights.
    4. Rear Brake and Parking Lights - Using the FF kit provided lights.
    5. License Plate Light - I will use the light fixture provided in the FF kit but replace the bulb with one purchased from a MAL-S-WW2 LED license plate bolt from Super Bright LEDs.
    6. Reverse Lights - I will be adding two reverse lights to below the brake and parking lights. They will be powered via the reverse switch in the TKX transmission piggy backing off the TAN-Choke feed from the Ron Francis. I am going to the Watson Streetworks 6-LED Interior and Marker Lights, L96 Series with White LED and Clear Lenses.
    7. Courtesy Lights - As docuemented in the Instrument Panel Planning and Related Items post, there will be a courtesy light installed the dash corners on both sides of the dash. I am using the Watson Streetworks L86 1″ Auto Interior LED Light with a white LED and clear Lens.
    8. Dash Lights:
      1. Fan Light - Watson Streetworks Small Chrome Low Profile LED Indicators - 240 Series in Amber
      2. E-Brake Light - Watson Streetworks Small Chrome Low Profile LED Indicators - 240 Series in Red
    I have to look at the requirements of NC; however, unless it is 100 percent required I do not plan on doing a third brake light. If it is required, I really like the finished look of the FormaCars Center Brake Light and would go that direction. Would require zero customization and has a more OE look.
  9. #47
    Mar 2024
    Marvin, NC
    Ron Francis Mounting
    I’ve spent countless hours planning the electrical setup for this build. At first, it seemed overwhelming, but now I’m confident it’s achievable. The key challenge will be making everything look as clean and organized as possible. I have a plan to achieve this, but the real test will be in the execution.
    After reviewing multiple builds, I decided early on to place the fuse panel in the same location as @EdwardB did in his build. This location provides excellent accessibility while keeping the wiring hidden and tidy. However, to make it work, additional support for the Ron Francis fuse panel bracket is necessary.
    To provide this support, I cut a piece of aluminum L-channel to the width of the bracket, plus one extra inch. The additional inch allowed me to fold the end back on itself to create a secure mounting point for attaching it to the back of the frame rail under the dash. The portion of the bracket will be connected to the frame rail using 1/8 SS rivets.
    Next, I drilled holes for 1/8" SS rivets along the edge of the Ron Francis bracket to ensure it could be securely connected to the underside of the frame rail (yes, I know 5 are way overkill). Before installing the L-channel onto the Ron Francis bracket using 1/8 SS rivets, I had to cut out a portion of the L-channel to allow the fuse panel to slide into place without interference. The L-channel is ~3/4 inch off the edge of the Ron Francis bracket to allow it to be mounted to the rail. This modification ensures a seamless and snug fit.
    With the bracket properly supported and reinforced, the fuse panel will have a solid mounting base, ensuring stability and easy access while maintaining a clean, professional look.
    The bracket was powder coated with the rest of the panels. More to come when I cover the electrical installation portion of my build.
  10. #48
    Nov 2022
    Niles, MI
    Lots of thoughtful planning with the electrical.
    That's the part that makes me the most nervous. I just get overwhelmed thinking about it. I'll need to sit down and plan it out like you did, draw some diagrams, and break it down into individual steps.
    Blueprint LS3 427, T56, IRS
    Received: 5/24/2024
    First Start: 2/7/2026
  11. #49
    Mar 2024
    Marvin, NC
    Tires - The meat has been delivered
    As I listed in "The Build" post, my kit came with the Halibrand 18" wheels, and they look great! As I prepare to get the roller phase of the build, I set out to look for tires. Obviously my first stop was the forum and "The Daytona Wheel and Tire Repository". After reviewing my options I decided to move forward with the BFGoodrich Rival series:
    1. Front - P275/35/R18
    2. Rear - P315/30/R18
    After looking around for the best pricing, I decided to order the tires from Discount Tire. The only other option that I had to decide on was to go with the newer Rival S 1.5 or stick with the last model Rival S[/URL]. Discount Tire had both on their site. After talking with them and comparing the two models, it appears that the only real difference between the two models is the side wall construction. The newer 1.5 have a stiffer sidewall. I am not going to track this car (my wife already denied that request) so I decided to save some money at go with the Rival S and pulled the trigger.
    I ended up getting a call from the Manager of the local Discount Tire who stated that even though they were available online that they would not be able to source them. However, after some back and forth he upgraded the order to the Rival S 1.5 for the same price (could not believe the deal).
    The back tires are huge. Here is a picture that gives an idea of the width:
    Discount Tires was going to charge me to install stems so I decided to get a TPMS system for essential the same charge. I decided to do this after watching the video from @RSnake when he installed them on his car. I will not mount the display unit but can pull it out when I am interested in checking the tire pressure.
    While I have yet to put them on the car, I am confident that they will fit and fill the wheel wells perfectly. They are a tried and true combo, especially with the 1" spacer in the rear, including on @EdwardB's build.
  12. #50
    Mar 2024
    Marvin, NC
    Quote Originally Posted by JimStone View Post
    @jimstone, I built my last house and did all the electrical. I think that gave me the confidence (maybe overconfidence, we will see) on this project. If want to bounce ideas, PM me.
  13. Likes JimStone liked this post
  14. #51
    Mar 2024
    Marvin, NC
    Starting a Digital Guard Dawg PBS System without Brake Requirement
    Relay Boxes Setup:[*]Clutch and Safety Switch Relay – This will allow the car to start (and turn off)by either having the clutch or transmission safety switch to be engaged. Yes, both are the same thing but wanted some redundancy just in case one was to fail. Did not want to get stuck. I’m still working on the wiring for this one, as I don’t want the full starter switch wire power to go through this relay (if possible) and do not want to connect this directly to the battery. This is even more difficult because the default setup for the Digital Guard Dawg PBS-1 requires the brake to be pressed BEFORE the car will crank and BEFORE the car is turned off. Suggestions are welcome!
    Lately, I've been dedicating some time and mental "compute power" to figuring out how to make the Digital Guard Dawg PBS work seamlessly with only the Clutch/Neutral Safety Switch through a relay. During my research, I stumbled across the Clutch Control Switch from Digital Guard Dawg. The description on their site states:
    "It allows you to start your vehicle by simply depressing the clutch and pressing the start button, eliminating the need to press the brake pedal."
    Intrigued, I thought this could be exactly what I needed. However, their website lacked detailed wiring instructions, which left me with more questions than answers.
    To clarify, I decided to contact their tech support, and I discovered some interesting details that might help others looking to install a PBS system:
    1. Accessory Functions Identically as Clutch Safety Switch - The clutch control switch accessory operates exactly like the clutch safety switch already in use. I guess this is for cars that do not already have this type of solution installed in the vehicle. Their recommended install for this accessory would be to run a relay (their preferred solution) powered by the battery or to run the battery directly though the unit connected to the Brown (brake (+)) accessory feed on the PBS thus allowing the Brown brake feed to receive power (allowing the car to crank when the start button is pushed) when the clutch is engaged.
    2. Brake Pedal Not Required (*with conditions) - Contrary to the directions, you do not need to press the brake pedal to start or stop the PBS system. This is especially important for those, like me, who are wiring the system to work through a relay connected to the clutch safety switch, rather than routing the crank signal directly through the clutch safety switch itself. See below for more information on this.
    3. Constant Brake Power Not Allowed:
      • You cannot run a constant feed to the brake input on the PBS.
      • Under normal operation, the PBS detects that the car is running when the brake pedal is pressed, and the car is started. If you feed constant power to the brake input, the system will behave unpredictably. Specifically, when you press the PBS button to stop the car, it would attempt to start the car again. This is a critical detail to ensure proper functionality.
      As such, I have decided to continue to use the relay functionality allowing the car to start (and turn off) by either having the clutch or transmission safety switch to be engaged but wire the relay in the following way:
    By wiring the relay in this fashion, the relay will only work when a key is within range of the PBS, while allowing the car to be started or stopped without requiring the brake to be pressed when the clutch is engaged OR the TKX is in neutral (via the neutral safety switch). Additionally, this would prevent anyone from accidentally starting the car by pushing the start button for 5 seconds without the clutch engaged or the TKX in neutral.
  15. #52
    Mar 2024
    Marvin, NC
    First Round of Upholstery is Back
    I’m excited to share that I’ve picked up the first batch of upholstery for the build! This included:
    • The Dash
    • The Transmission Tunnel Top Front
    • The three custom panels under the dash:
      • Drivers side kick panel
      • Passengers side kick panel
      • The panel directly under the driver's side dash)
    As I discussed in the Panel Finishing and Off to the Upholsterer post, I added foam to the transmission tunnel top front cover to match the transmission tunnel top rear cover (the arm rest panel). With that in mind, I knew I’d need to double-check the fitment of the custom switch panel. It’s a good thing I held off on getting that piece upholstered because I had to trim a significant amount off—around 1/4 to 3/8 of an inch.
    To make the adjustment, I used my belt sander, carefully removing a little material at a time and checking the fit on the car after each pass. I also had a sample piece of the vinyl on hand, which I used to ensure that once the switch panel was wrapped, it would still fit correctly.
    It will be a little tight, but that’s probably a good thing. The snug fit will prevent the panel from creating an indentation in the foam on the transmission tunnel top front, while also providing some extra support for the middle of the dash.
    Once the engine and transmission arrive, I’ll be able to confirm that no further adjustments to the transmission tunnel top rear cover (the arm rest panel) will be necessary (as I currently expect). Once that’s verified, I’ll send both the switch panel and transmission tunnel top rear cover (the arm rest panel) off to the upholsterer to finish the process.
    Of course, I couldn’t resist getting the newly upholstered pieces on the car to see how they look—and boy, do they look sweet! Seeing it all come together like this is incredibly rewarding. You have these visions in your head about how things are going to turn out but nothing matches seeing it come to fruition:
    With the transmission tunnel top front cover in place (this is the key piece where the wiring harness exits the cockpit to the front and rear of the car), I can officially start the real process of wiring the car.
    I already have a solid plan in mind and have started laying out the wiring paths, but now I can dive into the details—dieting the harness and terminating connections where needed. This is where the plan transitions into execution, and I’m excited to see it come together.
  16. Likes PNWTim liked this post
  17. #53
    Aug 2019
    Spokane, WA
    Appreciate all the time you're putting into documentation of your build. There are a number of helpful ideas I noted. Keep up the good work!
    I had the exact same experience with the Rival S 1.5 tires at Discount Tires this past Spring. (Quite surprised they still haven't removed the earlier version from their online inventory).
  18. Likes wedel456 liked this post
  19. #54
    Nov 2020
    Damascus OR USA
    I just read through your thread this morning. You have a lot of innovative ideas and great documentation. Please keep it up and looking forward to following along.
  20. Thanks wedel456 thanked for this post
  21. #55
    Mar 2024
    Marvin, NC
    Driveshaft Safety Loop
    When it came to the driveshaft safety loop for the build, I explored several options before settling on one from Summit Racing. Originally, I planned to use the version from Jegs, but it was out of stock when I placed my order, so Summit's option won out.
    One challenge I faced during the installation was the length of the mounting ears on the unit—they were quite long. To make it fit properly with my chassis, I needed to trim them down. I positioned the loop approximately 4.75 inches from the final back bar on the lower part of the transmission tunnel. This placement aligns closely with the back of the inside seatbelt tabs on both the driver and passenger sides. Once I had it lined up, I trimmed the ears to match the "X" of the chassis, ensuring a snug and secure fit. Please note: the driveshaft safety loop is *not* perfectly centered. I needed to temp install the driveshaft to ensure there was enough space for it to fit and spin. The driveshaft is *much* closer on the passenger side.
    I couldn’t see myself having bolts poking through the bottom of the chassis, so I decided to use heavy-duty 5/16-inch rivnuts instead. These were paired with yellow zinc 5/16-inch bolts, washers, and split ring washers to ensure everything stays tight and secure. This approach not only kept the bottom of the chassis clean but also made for a robust and professional installation.
    To finish things off, I added a coat of Rust-Oleum Appliance Epoxy from Home Depot that matches the Factory Five black chassis powder coating. This gave it a clean and durable finish. Project completed!
    *just noticed somehow I did not install a washer on the first bolt..... Will need to fix that.
  22. #56
    Mar 2024
    Marvin, NC
    Rivet Preparation and Polishing
    As part of the preparation for final panel installation, I’ve been focusing on polishing the stainless steel rivets to achieve the clean, polished look I want for the build. The process not only enhances their aesthetic but also aligns with the attention to detail I’m aiming for in every component of this car.
    For the rivets, I will be using stainless steel rivets from Albany County Fasteners:
    • 1/8 x 1/8 (0.063-0.125): These are used for panel-to-panel connections, ensuring a tight, seamless fit.
    • 1/8 x 3/8 (0.313-0.375): These are reserved for panel-to-chassis connections, providing the extra strength needed to secure the panels to the frame.
    The Polishing Process
    To polish the rivets, I’m using a bench grinder with a polishing pad installed. The polishing process involves two steps using the following products:
    1. Meguiar’s M110 Heavy Cut Compound:
      • This first step removes any surface imperfections and creates a smooth base for further polishing.
    2. White Diamond Metal Polish:
      • The second step refines the surface, leaving a mirror-like finish that brings out the shine in the stainless steel.
    Each rivet goes through two passes in each compound/polish, ensuring a consistent and high-quality finish. While I initially thought I might only need one of these products, the difference after both phases is significant, making the extra effort well worth it.
    The rivet to the left is the as shipped, the middle is after two passes with Meguiars (the picture does not do the rivet at this point justice as to my eye it looked really good at that time before seeing the next step), the one to the right is the finished product after to polish runs with the White Diamond. At this point, all the rivets sparkle.
    The Results
    The polished rivets not only stand out visually but also complement the black powder-coated panels perfectly. The contrast between the polished stainless steel and the black coating will create a striking and refined look, emphasizing the craftsmanship in the build.
    With the rivets polished and ready, the next step will be finalizing the panel installations. These steps mark steady progress toward the exciting milestone of the engine delivery early next year.
    Stay tuned for more updates on the build as it all starts to come together!
  23. #57
    Mar 2024
    Marvin, NC
    Installing the First Panels
    After months of preparation and countless hours of work, I’ve officially started installing the first panels on the car! This milestone is a major step forward, and it’s amazing to see the build truly start to take shape. The polished rivets really pop with the black powder coating.
    I know I am not following the manual at this point; however, the plan is to install the panels that are only required for the engine installation. This will allow me to have all the access needed to get to brake and fuel lines while providing the hand space to get the transmission into place. Once the engine is in and tested I will move forward with the rest of the paneling.
    On the passenger side, I installed the following panels:
    1. RIGHT FOOTBOX FRONT
    2. FOOTBOX INSIDE UPPER WALL, RIGHT
    3. FOOTBOX INSIDE LOWER WALL, RIGHT
    On the drivers side, I installed the following panels:
    1. LEFT FOOTBOX FRONT
    2. LEFT FOOTBOX INSIDE LOWER WALL
    3. FOOTBOX INSIDE UPPER WALL, LEFT
    As I noted in my last post, for visible rivits am using 1/8 X 3/8 rivets for the panel-to-frame mounting and 1/8 X 1/8 rivets for the panel-to-panel. For non-visible rivets, I am using the 1/8 rivets included in the kit. While attaching the panels, I used GE Advanced Silicone 2 caulk in black. I did end up ordering the pneumatic air riveter; however, I ended up doing these by using my Arrow swivel hand rivet tool as it really is not too hard to get them done and you do not have the air line to deal with - it is really only the 3/16 stainless rivets that I cannot do by hand.
    I did not put any rivets or caulk on the outside edges of the footbox covers nor on the cockpit side of the panels that attach to the frame inside the cockpit. This will allow me to install the engine while still allowing me to install the overlapping panels in the future.
    Once I had all the required rivets in place I then filled all the gaps on both the passenger and drivers side panels with caulk. I also spent time caulking the internal frame rails to the inside of each panel. While I will be ensuring that everything is enclosed with sound and heat deadening it is important that all the open areas are filled to keep water, air, and heat out of the cockpit area. It also provides a real finished look.
    I am trilled with how everything turnout out. Very happy I went with the black powder coating, too.
  24. #58
    Mar 2024
    Marvin, NC
    Finalized Dash Wiring
    Today’s task was to finalize the wiring of the dash. And it looks awesome!
    As discussed in my earlier "Instrument Panel Planning and Related Items" post, the dash is a single piece with no separate instrument panel. Therefore, it was essential to ensure everything on the dash—gauges, courtesy lights, clock, etc.—can be easily connected and disconnected from beneath.
    To achieve this, I ensured that every connection utilized the harnesses provided in the Ron Francis, a Deutsch connector, or via heat shrink spade connectors. Additionally, to make things serviceable, I ensured there was a with a cable loop long enough to remove the gauge or light without having to take the dash apart and/or off.
    When planning the dash layout, and before upholstery, I strategically placed plastic cable tie mounts throughout the back of the dash and behind the gauge locations. These mounts were secured with 6-32 flat screws and nylon lock nuts, countersunk into the dash's front face. Afterward, I sanded them smooth using a belt sander and filled any remaining gaps with JB Weld, followed by hand sanding. This process ensured the dash's surface remained seamless, as there is no padding.
    Wiring Notes:
    1. Clock Wiring - The clock’s red (12+) wire is connected to one of the two Red-Speedo/Clock Memory feeds from the Ron Francis harness using heat shrink butt connectors.
    2. Gauge Feed Line - For the two BRN-Guage Feeds from the Ron Francis harness, I divided the six gauges (the clock is connected differently) into two groups and connected them using two separate five-port lever nut connectors.
    3. Gauge Light Feed- I connected the lights for all six gauges and the clock to the gauge light feed from the Ron Francis harness using an eight-port lever nut connector.
    4. Horn Wiring - The horn is connected to the Ron Francis horn and horn ground feed via 90-degree spade connectors and sealed with heat shrink.
    5. Speedhut Gauge Connections:
      • Water Temperature - A 12” section of the Speedhut Temperature Wiring Harness was cut. The white signal wire was connected via head shrink butt connectors to the DK-Blue-Water Temp feed from the Ron Francis harness with the ground sharing a ground with the gauges.
      • Fuel Gauge - A 12” section of the Speedhut Fuel Level Wiring Harness was cut. The white signal wire was connected via a heat shrink butt connector to the LT Green-Fuel Sender feed from the Ron Francis harness with the ground sharing a ground with the gauges
      • Oil Pressure - A 12” section of the Speedhut Pressure Wiring Harness was cut. The white signal wire was connected to the GRY-Oil Press feed from the Ron Francis harness via a heat shrink butt connector. The Lt Blue-Oil Temp feed from the Ron Francis harness was used for the Red +5 Volt Reference feed from the Speedhut harness (as outlined in another forum post) connected via a heat shrink butt connector. The ground shares a ground with the gauges.
      • Additional Notes for Speedhut Connections:
        • Speedhut sensors and connectors were used on the opposite ends of each connection via a heat shrink butt connector.
        • To ensure accuracy, all Speedhut wiring harness grounds were connected to a common ground, per their instructions.
    6. Grounding Configuration:
      • Grounds from the Ron Francis harness were distributed across all dash grounding connections as there are numerous ground lines provided in the Dash Harness.
      • Reminder - For courtesy lights, the ground comes from the light switch, not the dash harness.
    7. Additional Four-Port Deutsch Connector:
      • Courtesy Lights - Spade connectors were used for future serviceability. The two lights (one on each end of the dash) were connected using a heat shrink butt connector to the other Red-Speedo/Clock Memory feed for power. The grounds were connected together via a heat shrink butt connector with a feed line routed to a port on the Deutsch connector which will run to the GRY-Courtesy Light feed from the headlight switch.
      • High Beam Indicator - Since I am using the IDidIt Module to control the headlights, the standard high/low beam harness was not run to the dash. Instead, a line was run from the blue wire on the back of the Speedo to a port on the Deutsch connector which will then connecting to the green wire on the IDidIt module.
      • Fan Light Indicator - A Small Chrome Low Profile LED Indicator (amber) from Watson Streetworks was installed to indicate when the fan is running. The ground is shared with the gauge grounds. The power wire is connected to the fan wire running from the fan relay to the fan.
      • E-Brake Indicator - A Small Chrome Low Profile LED Indicator (red) from Watson Streetworks was installed to indicate when the Wilwood electronic parking brake (EPB) is engaged. The ground is connected to a Ron Francis ground, and the red (hot) wire is routed to a port on the Deutsch connector. The other end connects to the yellow feed on the Wilwood EPB.
    8. Russ Thompson Turn Signal Wiring - Since the turn signal is right below the dash, I decided to utilize the dash harness feeds that typically go to the hazard switch and the turn signal switch. I installed spade connectors on the GRY - Turn Flasher FD, the combined front/rear left turn (Dk Grn - Left FRT Turn and Yel-Left Rear Turn), and the combined front/rear right turn (Lt Blu-Riught FRT Turn and Whut-Right Rear Turn). These will connect to the respective connections on the Russ Thompson allowing for easy serviceability and disconnection to remove the switch and/or dash.
    Overall, the wiring behind the dash looks great, IMO; however, the service loop does make it look a little messy:
  25. #59
    Dec 2018
    Hudsonville, MI
    Maybe you are already planning on adjusting the panels in this area but wanted to show the line where the aluminum sits. The end of your driveshaft loop base will interfere. The line here is the edge of the installed floor.
    Coupe Kit Delivered 11/10/23
  26. #60
    Mar 2024
    Marvin, NC
    Driveshaft Safety Loop - Panel Fitment Fix
    Thanks @MSumners! I did have an issue that required me to trim at the edges of the loop a little. A little more paint and things fit perfectly now:
  27. #61
    Just catching up with your build thread. Lots of nice work and detailed explanations. I like what you're doing. Two comments: First, not quite sure I'm following the "no brake pedal required" for the DGD pushbutton start. Aside from the technical aspects, from a practical standpoint (at least for me) having to push the brake pedal is exactly how our DD pushbutton start works. So it's normal and instinctive for me. Will be interesting to see how that works out. Second, that FormaCars top brake light looks interesting. But I'd be careful. The Coupe is already hard to see out of to the back and rear quarters. Even with a good center rear view mirror (I have an oversize one in my Coupe) you can only see a pretty narrow portion out the top of the rear window. Personally, I wouldn't want to see any of that blocked and that assembly looks like it might. IMO, something to look at before going that way. Continued good luck with your build. Our Coupe just finished its fourth season. Over the next couple days, will be finishing the oil change and annual maintenance getting it ready to come out of hibernation for next year's cruising season. Can't wait.
  28. Likes wedel456 liked this post
  29. #62
    Mar 2024
    Marvin, NC
    Coming from you this has put a smile on my face!
    I know you know this; however, for those who do not have experience with the product.... The PBS requires a 12+v going to the Brown wire coming from Accessory Harness. The power is typically run (in the Factory Five setup) by running a wire after the brake switch on the Pedal Box.
    Now, while talking with Support at Digital Guard Dawg they stated that the PBS uses this for two purposes:
    1. As an indication that the car is prepared to start (and the driver wants it to start).
    2. As a way to track the state of the status of the car - as in it knows that the next press after start will be to turn off the car *after* the brake has been released (thus removing the +12v on the Brown brake wire on the Accessory Harness:
      • My guess is that this is why they have the 5 second override on the start button to turn off the car if there is a loss of state tracking of the status of the car.
    In my setup, since I wanted to be able to start the car without the brake as long as the car is in neutral, I used a ground based relay using the clutch and neutral safety switch for redundancy that provides the +12v to the Brown wire on the Accessory Harness. While I do not have the engine (should hopefully ship in a week or so) I have fully tested the electrical system in my car (a post to follow shortly) and everything works perfectly and I am getting the ignition crank signal through the PBS (the Purple Start/Crank wire) with either the neutral switch and/or the clutch engaged.
    As I put in the post, Digital Guard Dawg does sell their own Clutch Control Switch that does the same thing. Only their solution is just uses a pedal box mounted clutch safety switch but requires a +12V signal to run though it.
    I did not want to have to push the brake every time the car is started while still ensuring it is safe to start the car (meaning the car is in neutral or the clutch is engaged). I have a safety light on the dash that shows the e-brake is on which will prevent the car from moving.
    Yeah, I have heard that a lot. I *highly* doubt I am going to do a third light *and* I plan on using a camera based mirror.
    Our Coupe just finished its fourth season. Over the next couple days, will be finishing the oil change and annual maintenance getting it ready to come out of hibernation of next year's cruising season. Can't wait.
    Very jealous. Will be there soon, hopefully!
  30. #63
    Mar 2024
    Marvin, NC
    Brake and Clutch Reservoirs - Mounted
    Now that the drivers side footbox front is installed, I was able to get to the brake and clutch reseviours to mount them permamently. In a past post I documented where I decided to place them and how the bracket was developed.
    Polishing:
    To start, I polished the brackets for the resivours. I utilized the same process for the panel rivets:
    Unlike the rivets, there is a huge difference between the Meguiar’s and the White Diamond Metal Polish:
    1. The left bracket and screws are before any work was done.
    2. The middle bracket and screws are after the Meguiar’s.
    3. The right bracket and screws are after Meguiar’s and White Diamond Metal Polish.
    While approx 0% of people will ever see them, I just could not install them as they were with my anal retentive brain.
    I then progressed to the reservoirs themselves and boy did they polish to a mirror finish using the same process:
    Bracket and Reservoir Installation:
    For the bracket that mounts to the frame, I could not for the life of me get my rivet gun to correctly complete a 3/16 stainless rivet. It says that it can but not sure if I am doing something wrong. Ergo, I decided just to use 3/16 aluminum rivets provided as part of the kit. I did polish them using the same process as the stainless and they turned out fairly good (not as good but good).
    Once the bracket was connected to the frame I mounted the reservoirs using the 1/4 flathead polished screws, a washer, and a locknut. Came out awesome, especially when I placed the engine bay covers on the car. The contrast between the black and the polished reservoirs makes things pop:
    Resevoirs Mounted Under.jpg Resevoirs Mounted Top.jpg Resevoirs Mounted Covered.jpg
  31. #64
    Mar 2024
    Marvin, NC
    Steering Shaft Installation
    Steering Shaft Installation:
    With the front footbox cover in place, I moved on to what I hope will be the final installation of the full steering column. This step brought some unexpected challenges but also a satisfying sense of progress as everything came together and as I am getting closer to go carting my hand built car.
    Before installation, I noticed that some of the pieces were a bit dull and showing early signs of rust. To address this, I gave them a polish using the same process I described in my previous posts about rivets. While the results weren’t mirror-shiny, they definitely looked much better and will hold up better over time.
    Additionally, I polished the outer cover of the flange bearing along with the button-head screws. These small details might seem trivial, but they really elevate the overall look of the build.
    I did not install the upper column as I am worried that it will get stuck as it happened to me before and it took some effort to get out even though I did not install the spring washers. I inserted the upper column into the shaft, stopping just before the spring washers' location. Once that was done I was able to test the steering to make sure it turned without binding. Everything tested perfectly so I ensure all the 5/16 recesses were perfect and locked everything down.
    Reversing the Footbox Bearing
    One hiccup I encountered was accidentally installing the bearing in the front of the footbox backward. After securing the front footbox cover with 1/8-inch stainless rivets, I realized the mistake and initially panicked, thinking I’d have to drill out the rivets. Fortunately, I discovered that the bearing can be reversed even after installation—a huge relief!
  32. #65
    Mar 2024
    Marvin, NC
    Final Pedal Box Installation
    Pedal Box Installation:
    With all the panels required to install the engine now in place and covered with sound and heat deadening material, and as I anxiously await the delivery of my engine, I decided it was time to install the pedal box for the last time.
    I won’t go into too much detail about the installation since it’s been thoroughly documented in other threads and, for the most part, was straightforward. That said, it would have been vastly easier to install before the panels were in place, as the lack of space made this process far more challenging.
    However, I anticipated some issues with pedal height and the clutch and brake switches, which I’ll address in this post.
    Here is the project completed with a few items to note:
    1. As I documented in my thread during the mockup, I could not use the kit provided top mount bracket. I had to make my own, IMO. See this post for more information on the issue.
    2. I do not have the Wilwood master cylinder for the clutch as of yet as it comes with my engine package.
    Issues:
    1. The pedal height was way off in its initial position—far too close to the driver seat. At 6' to 6'1", I wouldn’t have been able to drive the car comfortably in this configuration. To fix this, I spent a significant amount of time adjusting the set screw to bring the pedals to a reasonable height. Unfortunately, the limited space made this task frustrating, as getting a wrench into the right position to turn the screw is nearly impossible. As seen in the below, I ended up threading the set screw all the way in. While this adjustment improved the pedal position, I’m concerned it might cause issues with hitting the custom footwell panel I made and covered in vinyl and may interfere with the pedal’s range of motion and with #2 below.
    2. The manual shows drilling the 3/16" hole for the brake and clutch switches from the master cylinder side of the pedal box. This makes sense because there’s no room to drill from the other side. However, when you install the switches, the brackets go on the opposite side of the pedal box mounting location. I can only assume this is due to the length of the switches, as it’s not explicitly addressed in the instructions. Regardless, the tight space made removing and reinstalling the unit a challenge. I had to enlarge the hole in the mounting bracket to align the screw hole with the pre-drilled hole in the pedal box. Even after repositioning the brackets to the other side, the switches still didn’t seem long enough to activate properly.
    Next Steps:
    At this stage, I can’t verify if the switches will function correctly. I’ll need to wait until the brakes are bled and the clutch master cylinder is installed to test them fully.
    Advise Anyone?
    If any taller Coupe owners can speak to the pedal height issue it would be great!
  33. #66
    Advise Anyone?
    You won't have any issues with the travel required for the brake pedal. It's only several inches and will stop well short of your back wall. If you don't get full clutch release with the pedal pushed all the way to the back wall, you can adjust the clutch master cylinder size to require less pedal. At the expense of slightly more effort.
  34. Thanks wedel456 thanked for this post
  35. #67
    Mar 2024
    Marvin, NC
    A/C and Heater Equipment Final Mounting
    Progressed with checking things off the list before the engine arrives. As such, today I finished the mounting of all A/C and heater equipment. I have already tested the electrical portion of this (more on this in another forthcoming post); however, I had to mounted everything, until today.
    Heater Control Valve:
    As I documented in my A/C – Heater – Defroster Installation and Mockup of Lines post, I never liked where the manual says it should be placed. I wanted a clean engine bay. As such, I decided not go with the little patch lines running from the back of the evaporator to the bulk head connector and just connected it directly to the evaporator. It is a tight fit but it does fit and I confirmed that the grommets will work (with a little red grease) and that hose will connect to the control valve:
    I have not cut the top hose yet because I am not sure about the length. Once I have the engine installed I will cut the hose to length and connect the bottom return port.
    I also installed the Thermotion controller box that controls the heater control valve on the outer frame rail above the evaporator. This is mounted using 10-32 stainless flange head screws and 10-32 rivnuts:
    Trinary Switch and Dryer:
    I installed the A/C Trinary Switch and Dryer on the inside passenger side engine bay frame rail about half way between the footbox and the top of the radiator with just enough room to clear the front wheel rear inside splash guard. I had previously powder coated the brackets and utilized a black stainless steel clamp. It is attached to the rail using 3/16 stainless steel rivets.
    For those of you that have the same question: my kit came with a different dryer than what is in the instructions - a Vintage Air 07321-VUC. I had to ask the question about which way the flow of the A/C system worked just to confirm as the dryer is directional. As confirmed by @BornWestUSA, the direction flows from the bottom of the condenser, through the dryer, then to the bottom of the bulkhead bracket.
    A/C Bulkhead and Inside Hose:
    Last item I checked off the list was placing the A/C bulkhead fitting and ensured the hoses and fittings I prepped previously still fit. I cut and polished the bulkhead fitting just like I did all the other polishing - has a great finish on it. The hoses I mocked up previously did have to be trimmed a little but are now in place.
    Bulkhead fitting.jpg A:C Hoses .jpg
  36. #68
    Mar 2024
    Marvin, NC
    Front and Rear Wiring
    While I will post another update on everything under the dash, as it has been done for a few weeks now, I spent some time this weekend cleaning up the main power runs along with the front and rear harnesses.
    Products Used:
    1. Convoluted Tubing:
      • 3/4 Inch
      • 1 Inch
      • I also used other tubing provided as part of the kit and/or Ron Francis wiring harness.
    2. Clamps:
      These are mounted using 10-32 stainless steel button head screws and rivnuts.
      • 1 Inch clampsfor the 3/4 inch tubing
      • 1 1/4 Inch clamps for the 1 inch tubing
      • I also used the clamps provided as part of the kit for the smaller tubing; however, I will be getting matching clamps when I have a total count and sizing.
    3. Tape:
      • As you can see in some of the locations where I was positive I would not need any additional wires, I have used non-adhesive wiring harness tape to get an OEM look. Looking around this is the most expensive tape known to man; however, I was able to find it relatively inexpensive on eBay. Based upon what I have used so far, I am assuming I will use 300 feet. Once I am sure that all the wiring is in the right place (I do not have my CDI box nor my rear view camera as of yet so there are a few more wires that will be required) I will wrap all the visible areas in this same tape.
      • For locations where tubing combines I want to provide some strength. Since I did not want to use sticky electrical tape in the harness, I purchased cloth friction wire harness tape. It will be used in a very limited fashion.
    Main Power:
    1. Power (+) Cable:
      • Runs along the passenger side frame rail and terminates on the master shutoff on the Right (passenger) Cockpit Trans Side panel at the master shutoff.
    2. Grounding:
    Front Harness and Sending Units Harnesses
    Overall, the two harnesses are split down the passenger and drivers frame rail depending on the location on where they are needed.
    1. Passenger side frame rail:
      • Starter Battery and Solenoid Wiring:
        1. For main starter power, I have a 4 AWG cable running from the switch side of the master disconnect.
      • The solenoid cable is coiled with the main power for the starter.
      • A separate ground will be installed for the starter when I install the engine.
    • Drivers side frame rail:
      1. All sending unit wiring is coiled at the drivers side motor mount. I need the engine before I can determine where things are placed.
      2. Drivers/Passenger Lighting and Radiator Fan:
        • The drivers lighting package wiring (including the addition of the fog light wiring) splits at the front corner of the driver side and continues out to the outside corner of the radiator tunnel. Will determine where to mount once the body is back on the car.
        • The passenger lighting package and radiator fan wiring (including the addition of the fog light wiring) splits at the front corner of the driver side and continues towards the passenger side of the car. It then splits at the front passenger corner and continues out the passage outside radiator tunnel. Again, Will determine where to mount once the body is back on the car.
    • A/C and Dryer Wiring:
      • The wiring for the clutch it coiled around the location (at the front passenger side of the engine bay) I believe it will be when the engine is installed.
      • The Dryer wiring comes down the passenger side frame rail, goes out the same tubing towards the passenger lighting and radiator wiring, then goes up the radiator support frame rail, and following the underside until it gets to the trinary/dryer.
    Rear Harness (including the Wilwood EPB wiring)
    1. TKO Transmission Setup:
      • Since I am installing a TKO transmission, I ran two grounding wires for the reverse (going to the rear) and one wire for the neutral safety switch (running to the relay).
      • These are inserted into the tubing towards the rear of where I believe the transmission will land.
      • I have the wires coiled towards the back where I believe the transmission will land.
    2. Routing:
      • The rear harness runs through the transmission tunnel, wire-tied to the rear brake line, and comes out around the same location as the brake and then splits for the drivers side Wilwood EPB and the rest of the rear wiring:
    3. Wilwood EPB Wiring:
      • Here is a picture of the driver side Wilwood EPB; however, the passenger looks the same. Will need to figure out a mounting system to attach the tubing to the upper control arm.
      • All other wiring (the ground wire for the reverse switch from the TKO, the passenger Wilwood EPB, sending unit, and fuel pump) split the other direction.
    4. Passenger Side Rear Corner:
      • After splitting for the passenger side Wilwood EPB, all other wiring (rear lights, reverse switch ground, and the sending unit/Fuel Pump) continues to the passenger rear corner.
      • Here splits out wiring for:
        1. Fuel Pump
        2. Passenger lighting package and license plate light
        3. Rear Ground
        4. Drivers lighting package and the sending unit
    5. Rear Ground:
      As @EdwardB suggested, I added a rear grounding location. I chose to place it just to the aft of the gas filler. Off of this ground is the grounding wire from the Ron Francis, the ground for the TKO reverse and neutral safety switch, and the continuation of the grounding wire from the Ron Francis for everything that services the back electrical.
      It is connected to the chassis using a 1/4 Stainless button head and a washer.
  37. Thanks PNWTim thanked for this post
  38. #69
    Mar 2024
    Marvin, NC
    Fuel Lines and Gas Tank
    While I had previously mounted the gas tank when I created my drop trunk just to ensure that everything fit correctly, I took everything off so I could continue with the build. Now that I am close to receiving my engine I thought it would be a good time to connect everything again so I can be prepared for when the engine arrives. As such, I have reconnected by gas tank and finished my fuel lines. I will be taking the gas tank out once again, once the engine has been installed and tested, so I can attach the panels and drop trunk.
    Equipment Used:
    1. Hard Fuel Lines:
      • While complete overkill as no one will ever really know it is there, I decided to utilize 3/8 stainless steel tubing. Once cut to size and confirmed that it fit, I then polished it using the same method described previously with the rivets.
      • For the fittings, I used compression fittings, 90 degree bulkheads, and miscellaneous adapters from Racetronix.
    2. PTFE Fuel Lines:
      • For the soft hoses, I decided to use 6AN stainless steel PTFE fuel line and fittings. I know I will need to get more fittings but I am not 100 percent sure what I will require until I have the engine. in place. I may also utilize black stainless under the hood. Will be a game time call.
    3. Fuel Hanger, Pump, and filter
      • Since my engine will have almost 600 HP, I wanted to make sure that it was getting enough flow and GPM; ergo, I decided to upgrade to a Pro-M Hanger and Walbro Gss340 Fuel Pump
      • I am using, like many others on this forum, the Trick Flow TFS-23006 fuel filter.
    4. Gas Neck Filler Gasket - Based upon the recommendation of many others on this forum, I decided to take the opportunity to get the OE version for the filter neck. It is part number F4ZZ-9072-DA.
    Hard Fuel Fuel Lines:
    1. The fuel lines run along the passenger side top rail of the transmission tunnel, though the e-brake mounts (I am not using the kit provided ebrake), out past the first 1" rail in the hatch area. I did wrap the area though goes through the ebrake mounts with shrink wrap to ensure that if there is rubbing it will not affect the line.
      On that same 1" rail I minted the Trick Flow fuel filter. I did have to trim the top of the bracket (a little PRO-15 Top Coat Spray is a great match to the chassis powder coat).
      To hold the hard lines in place I am using 3/8 rubber stainless steer cable clamps. These will be attached using the 3/16 aluminum rivets from the kit (I just cannot get my gun to pull the 3/16 stainless with any type of constancy.....)
    2. At the front of the car, the fuel lines terminate on the center custom panel I created and utilize bulkhead fittings.
      *older picture but gives you an idea of what it will look like,
    PTFE Lines:
    This was my first time creating these hoses, but they are really easy to do. I used my large wire cutters to snip them to length, a little red grease on the fittings themselves, and then installed them in the car. That simple:
    I got 6an wire separators; however, for some reason they are too big. Will need to look at that and get something else.
    Pro-M Hanger and Pump:
    Also another simple install, I used Molex 19164-0077 crimp connectors made for gas connections and then installed the pump as per the instructions. I followed the tip in the @Rsnake video and did not have to modify the tank to get the unit installed:
    Gas Tank
    For the gas tank, I did upgrade the valve to the Breeze Automotive big bore vent check valve kit. I am looking at doing a custom solution for the charcoal filter; however that will be done in another post as I am still working on the solution.
    As for the filler neck, I followed the directions in the manual (and online as they are not completely clear) and cut out the two inch center section. Once completed I could not leave the filler neck as is so I decided to give it a polish (yes, I know it will never be seen but I could not let it go). As you can see below (left polished, right not), it makes a big difference:
  39. #70
    Mar 2024
    Marvin, NC
    CDI Box Mounting
    I have been told that my engine should be shipping here in the next week or so. As such, I need to perform the final preparation so I can drop it in when it comes. My engine builder sent my CDI box - an MSD 5520 in black.
    My goal for mounting this unit was to have it out of the way to the greatest extent possible and have it near a power and grounding source. I had originally thought that I could place it near the evaporator unit; however, it is clear there is way too much happening in that area to make that reality. So I spent a few hours reviewing other builds trying to figure out where to mount the box and a few more hours just looking at the car to think through all the options.
    One area I did not see anyone place it, but one that I think works best to meet my requirements above, is right behind the radiator mounted to the top radiator frame rail (the one that is at an angle. To do so I am using 1/8 6061 aluminum plate in which the CDI box is connected using 10-32 flange head screws and lock nuts. To connect the plate to the frame rail I am using 10-32 rivnuts and SS washers and flange head screws (three of them).
    I had thought that there would be a vibration issue with only one side supported but once I connected it to the frame rail it is very firm with the 1/8 plate.
    I have to paint the bracket (and the side of the unit that is grey) but I think that it is a perfect location to make it disappear and makes for easy wiring. I routed the wring in 3/4 convoluted tubing and routed it behind the power steering rack down to the bottom rail to connect to power, ground, and other necessary wiring.
  40. #71
    Mar 2024
    Marvin, NC
    Accelerator Pedal and Cable Installation
    Have to be honest - other than the center section I hated installing the pedal and accelerator cable. Most likely this was due to me waiting until I had the panels on to do this but I also had two consecutive bolts / lock nuts cross thread on me...... But it is done.
    I followed the path set forth by @P100DHG and installed the pedal to the right side of the mounting location. I could not for the life of me find the mounting hardware so another trip to Lowes (and then another after the second cross thread).
    I also replaced the stock pedal with the machine one from Breeze. Looks so much better, especially after I polished it along with the wildwood pedals (for some reason the Wilwood did not polish as nicely....).
    The cable installation was just as hard. There is literally ZERO space behind the mounting bracket. I wanted it to remain hidden to the greatest extent until it cannot be. Ergo, I drilled a 5/16 hole right in the middle of the bracket about 1" down. Due to where I drilled the hole there was not enough space for the treaded portion of the cable to fit. I had to grind down the length on the belt sander.
    After a couple of trips to the belt sander, I got it to just wrap around and slide in. Lines up perfectly with the pedal stud. I then ran the cable from behind with the cable pointing towards the pedal. I could not get a great picture of mine due to everything in the way but it is very much like @P100DHG (his picture below):
    The cable wraps fairly tightly (but still moves smoothly) to the back side of the support rail and then follows the rear brake line out to the transmission tunnel. Once I have the engine in place I will punch a whole through the transmission tunnel custom panel and bring it out to the Sniper TBI:
  41. #72
    Mar 2024
    Marvin, NC
    Engine Build
    After an unexpected delay, my engine builder was able to put everything together. As previously mentioned, I went with a 427 stroker with 575 HP, Dart block, and a Holley Sniper 2 EFI system. engine from Proformance Unlimited out of Florida. Getting very excited to see this in the car:
    Connecting Rods.jpg Short Block.jpg Block.jpg CVF.jpgHeads Installed.jpg Finished Engine 1.jpg
  42. Likes PNWTim liked this post
  43. #73
    Nov 2022
    Niles, MI
    That engine looks awesome! 575 hp will be a monster
    Received: 5/24/2024
  44. #74
    Mar 2024
    Marvin, NC
    Engine Dyno
    I agree. This thing is going to be nuts!
    Listen to how it sounds!
    The builder got it on the ---> dyno. It pulled 602 HP and almost 630 torque. My wife is actually a little concerned.
  45. Likes CW_MI liked this post
  46. #75
    Nov 2022
    Niles, MI
    Haha, gotta love getting 27 extra horsepower than advertised!
    The LS 427 from Blueprint I'm planning will have similar specs. Go big or go home!
    Received: 5/24/2024
  47. Likes wedel456 liked this post
  48. #76
    Great looking engine. Have you checked the under hood clearance with that intake setup? Unless you're planning to through the hood on the Coupe, you may not have room. Others have reported issues with the 351 block and tall intakes like that one. Also there's options with solid or lowered motor mounts should it be necessary. No experience with that myself, or what effect that has on pinion angle.
  49. #77
    Mar 2024
    Marvin, NC
    I have the same concern, too. The builder says it will fit; however, I will not know until I get it here. I have looked at other builds that have used drop bases for the air cleaners or even maybe a March Air Cleaner (they are not cheap) which would really lower clearance.
    I will post when I get the thing it about the actual fitment. Keeping my fingers crossed.
  50. #78
    Mar 2021
    Ohio
    I am in the same boat with my 351 Cleveland. I am going to have to figure out a solution. The solid mounts put the oil pan below the frame, which I am not a fan of. I think I am going to try the drop base mounts or make a custom one for the oval air cleaner that I have.
  51. #79
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I have a Ford Performance 460. Also based on the 351W block. It has the height issue. I was unable to use the oval air cleaner. I had to use a drop base round air cleaner with a tappered spacer under the Sniper 1 unit. I also had to remove some of the cross brace on the hood to get everything to clear. I used the FF supplied engine mounts and my pan is above the frame member by 3/8".
    Scott Pregont
    My Albums
  52. Likes wedel456 liked this post
  53. #80
    Mar 2024
    Marvin, NC
    Quote Originally Posted by Namrups View Post
    You are what got me looking at drop base. Thanks for your build thread!
