Thanks Thanks:  76
Likes Likes:  189
Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 457
Thread: Project Deimos: An LS '65 Coupe Build: Engine no longer overheating!
  1. #121
    Hopefully the Weize is better than an Optima...but if not at least it was only half price
    Nov 2022
    Niles, MI
    Haha, my thoughts exactly. And if I ever get it down to you for paint, I'll be sure to bring the charger
    Gen 3 Coupe #576 - "Project Deimos"
    Blueprint LS3 427, T56, IRS
    Received: 5/24/2024
    First Start: 2/7/2026
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
  3. #123
    Nov 2022
    Niles, MI
    Been a while since my last update. I finished the stainless brake and fuel lines several weeks ago. Used 37 degree flares for AN fittings throughout.
    Never could figure out double flare with the Eastwood tool for the SS brake lines, so switched to AN which makes it a breeze.
    Made PTFE stainless flex fuel lines to the fuel tank. Screwed up and broke my first Pro-M hanger, so this is my second one. Note to others: DON'T OVERTIGHTEN or the AN fitting welds will break.
    Made a vent line for the differential
    Received: 5/24/2024
  4. Likes 460.465USMC liked this post
  5. #124
    Nov 2020
    Damascus OR USA
    Looks great. I like the little diff vent - can you please share where you got it?
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
  6. Thanks JimStone thanked for this post
  7. #125
    Mar 2021
    Ohio
    Nice work!
  8. Thanks JimStone thanked for this post
  9. #126
    Nov 2022
    Niles, MI
    I found making hard lines fun, so I decided to make hard lines to/from the power steering rack, power steering fluid cooler, and reservoir. The connections to the pump on the motor will be flex line.
    Using a Keyser brand power steering fluid reservoir, which I swear is the same as the Moroso and other brands, bust $80 less expensive.
    I powder coated it anyway.
    Also made hard lines to the fuel regulator
    But recently I took a little detour from working on the car itself. I really wanted to powder coat my own panels, and do it at my own pace. I also want to Cerakote my side pipes. So I decided to build a bigger powder coat oven.
    It will have 2 oven elements with 7000W total power. I'm going to wire it so I can add an element if the two elements are insufficient. Will have an air recirculating fan and it will be on casters so I can wheel it to/from my outside garage.
    Will show more details as I get it finished.
    Received: 5/24/2024
  10. Likes 460.465USMC, Higgybulin liked this post
  11. #127
    Nov 2022
    Niles, MI
    Quote Originally Posted by PNWTim View Post
    I actually went through several iterations that I weren't happy with before finding the following simple solution:
    Stainless 1/4" barbed to 1/4" NPT coupler
    https://www.amazon.com/dp/B07DVYC1XG...fed_asin_title
    And a little stainless exhaust muffler
    https://www.amazon.com/dp/B08MZ3L58G...sin_title&th=1
    Received: 5/24/2024
  12. #128
    Nov 2020
    Damascus OR USA
    Pretty clever combo, thanks for the info.
  13. #129
    Aug 2019
    Spokane, WA
    Congrats on your SS hard lines, Jim! They look great.
    Being able to PC your larger panels will be really handy. Looking forward to seeing your oven up and running.
    Do you happen to have the info on the boat latch and strut for your trunk box? I like your setup and considering something similar.
    Coupe complete kit. Index. Delivered: 4/22/24. Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  14. Thanks JimStone thanked for this post
  15. #130
    Nov 2022
    Niles, MI
    Quote Originally Posted by 460.465USMC View Post
    Thanks Chris
    Here's the latch I used
    https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
    And the strut
    https://www.amazon.com/gp/aw/d/B0CY2...b_b_asin_image
    Less than $20 combined
    Received: 5/24/2024
  16. #131
    Nov 2022
    Niles, MI
    I finished my powder coat oven, which ended up being a pretty fun side-project. And, shockingly, it all worked the first time I plugged it in.
    I based the design on this DIY tutorial: https://www.powdercoatguide.com/2014...ting-oven.html
    But I simplified a few things, because I'm not looking to make a business out of this or anything. I just wanted to have the ability to powder coat my own panels and Cerakote the exhaust at my own pace. It'll probably end up being a wash cost-wise for the Coupe, but I'll come out ahead if I do subsequent projects.
    My oven ended up being 4' x 3' x 6.5' outside dimensions. The interior oven is about 3.5' x 2.5' x 6', so about 90 cubic ft. Big enough to fit the largest aluminum panels and the side pipes.
    Materials List:
    Structure:
    3-5/8" galvanized steel framing studs (20 gauge, 10 ft) x 14-15
    Galvanized steel stud track, 10 ft, x 10
    9 sheets of 4x7' aluminum sheeting
    16 gauge steel sheet for floor
    1/8" and 3/16" steel rivets x 800+ (probably overdid it)
    Door:
    24 inch stainless piano hinges x 2
    Door clamps x 2
    Single gate caster wheel with spring
    Insulation/sealing:
    R-19 unfaced fiberglass insulation x 3 rolls
    Aluminum high temp sealing tape
    High temp RTV silicone
    Tadpole gasket for door
    Oven bake element x 3 (3500W apiece)
    High temperature spade connectors for bake elements
    Centrifugal blower fan for a wood furnace - 196 CFU
    Controller box / electrical:
    PID temperature controller
    40A solid state relays x 2
    10AWG THHN wire x 50 feet
    11AWG high temp wire
    Large electrical junction box
    Volt/amp meter
    240v rotary switches x 2
    Fan motor rheostat
    DIN rail components
    Cylindrical fuse holder x 2, with 0.5A and 5A cylindrical fuses (for PID controller and fan)
    40A circuit beaker (for oven elements)
    120v Extension cord - 20 ft
    50A, 240v appliance power cord - 10 ft
    1/2 and 3/4" EMT conduit, fittings, and 2x junction boxes
    Miscellaneous:
    Set of 4 casters with brakes
    Got pretty much everything from Amazon, except the framing supplies and sheet metal.
    I had never used steel framing studs and tracks before, but they're very easy to use
    Wool insulation is recommended, but would have been an extra $100 or more, so I went with fiberglass. Is good enough.
    This last pictures show the recirculating vent and where the fan will go. The vent helps redistribute the hot air at the top back to the bottom, because otherwise the top of the oven can be 50-75 degrees different and not good for the coating
    Received: 5/24/2024
  17. #132
    Nov 2022
    Niles, MI
    The major driver of cost for these ovens is the price of steel sheet to skin the thing. At least 20 gauge steel is recommended, but that was just way too expensive for me. I estimated $850+ for steel sheet alone. So I went a much cheaper route (and will have to deal with some inefficiency). I live near Elkhart, Indiana where there are numerous RV manufacturers. People sell slightly imperfect aluminum panels from the RV industry on Marketplace for cheap. I got all my aluminum sheet for the project for $100. It's 0.032 inch (20 gauge). Not nearly as good at heat retention, but it gets the job done along with R19 insulation, aluminum sealing tape and high temp RTV sealant.
    I originally planned for 2 heating elements, but decided to build in another. Easier to do it now than later.
    The wiring organization didn't turn out very pretty. I'll have to do better on the Coupe.
    It worked first try!
    My nifty amp/volt meter showed a problem though - the oven was drawing 43A, which is more than my garage's 240V circuit is wired for (wired for 40A).
    So I actually had to deactivate the 3rd heating element. Now drawing about 28A
    I'm working out calibration of the PID controller. And I learned quickly I need to run it through some heat cycles OUTSIDE because it was off-gassing some nasty fumes (probably from the backsides of the aluminum sheet, which have some sort of gray paint).
    Using an infrared thermometer, there is definitely some hot spots on the back (where the heating elements are closest to the skin) and near my recirculating fan. It gets up to at least 450 degrees inside (the highest I've tried so far).
    Most powder coating has temp range of 375-425 F. The high temp Cerakote for exhaust needs 500 F though.
    Received: 5/24/2024
  18. Likes 460.465USMC liked this post
  19. #133
    Dec 2017
    Southern Ontario/Cape Coral FL
    That turned out sweet! Keep us posted on how it works.
    Happy Holidays!
    Higgy
    MK4 #11354 picked up 10/06/25
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24 SOLD
  20. Thanks JimStone thanked for this post
  21. #134
    Mar 2021
    Ohio
    That turned out really nice! That will be super handy to have on site.
  22. Thanks JimStone thanked for this post
  23. #135
    Aug 2019
    Spokane, WA
    Nice work, Jim! Very cool project. Thanks for posting.
  24. Thanks JimStone thanked for this post
  25. #136
    Nov 2020
    Damascus OR USA
    Man, I love DIY stuff like this! Merry Christmas to you! I will enjoy watching how well it works and seeing the professional results.
  26. Thanks JimStone thanked for this post
  27. #137
    Nov 2022
    Niles, MI
    Thanks guys!
    I got it up to 550F, so it gets plenty hot.
    The aluminum panels inside expand in the heat (another reason not to use aluminum), causing some warping , but it still keeps temp.
    Received: 5/24/2024
  28. #138
    Nov 2022
    Niles, MI
    Well, progress really seemed to slow down for a while: The powder coat oven side project, the Holidays, nasty Flu bug, then vacation.
    But I've been chipping away. Mostly working on getting the dash and controls mocked up. Custom stuff sure does take forever.
    For the dash, I went with custom Speedhut gauges. GPS speedo, the typical gauges, but I also added a few extra gauges like oil temp, fuel pressure, manifold vacuum. I had an Air:Fuel gauge, but I realized I bought the wrong one (accidently bought the one that only works with AiM units, which I don't have) so that's on hold.
    Controls are all push buttons from Billet Automotive Buttons out of Australia, who make real nice stuff. What's cool is they're 16 amp switches so I won't have to use relays for most of them.
    The only kit supplied controls that I'll be using are the twist-knob controls for the AC (fan and temp control). I also have a twist-knob control for windshield wiper speed from the Specialty Power Windows kit. But, I got different knobs so they all match.
    First, a few pics of how it all turned out, then some of the details. This is still sort of a rough draft at this point:
    Putting the button switches directly on the trans cover panel ended up being a real PITA. First of all, there is a diagonal frame member under it, so you can't put buttons in the middle. Then the backside of the buttons and wires are exposed, so I had to make enclosures that would fit between the frame rails with extensions so the wires can make their ways up behind the dash. I modified the heck out of that panel.
    Looks so ridiculous underneath. But whatever, no one will see it. I'll have some work getting everything water tight.
    Received: 5/24/2024
  29. #139
    Nov 2022
    Niles, MI
    With all the issues getting a Russ Thompson turn signal unit, I looked elsewhere and decided to try out the Microflex Labs turn signal. It self-cancels by using gyroscopes and accelerometers to sense when the car turns. https://microflexlabs.com
    It seems like a nice quality unit and looks nice. Customer service has been great too.
    Did need to make a 2" shaft for the turn signal to attach to. Made out of stainless tube. Although first, I shifted the steering column to the left 1 inch to suit my seat location.
    MicroFlex Labs sent me out the black 3D printed bushing that fits into the end of the 2" tube and fits perfectly with the FFR steering hub.
    I'll be diving into wiring soon, so we'll see how this signal unit works, but they promise it simplifies wiring.
    Received: 5/24/2024
  30. #140
    Nov 2020
    Damascus OR USA
    Looks good Jim. Nothing wrong with a little Frankenaluminum if it works. I have looked at the Microflex as well since I think the RT unit is dead at this point (really a shame in my opinion). I may be mistaken but I thought during the FF Mark V reveal they spoke of producing a turn signal unit. I am curious if you happened to have reached out to them re: one of their units? Regardless, the Microflex is a really streamlined and good looking unit. I have also contemplated the Ididit shorty steering unit which incorporates everything but it requires quite a bit of fabrication and is expensive to boot. Carry on!
  31. #141
    Mar 2021
    Ohio
    Looking good Jim, you are making some serious headway. For what it's worth, I made some panels that mount under the transmission tunnel, below the switch area, to seal off from water and add some more room to stuff wires and ducts.
  32. Likes AaronR liked this post
  33. #142
    Apr 2024
    St. Charles, MO
    Quote Originally Posted by JimStone View Post
    Thanks guys!
    Very nice.
    I am thinking of doing the same, It's good to know it will hold 550F with only 2 elements.
    I would want mine on casters to make it mobile, although that would probably require a more substantial floor frame.
  34. #143
    Nov 2022
    Niles, MI
    Thanks Tim
    I didn't know FFR was making a turn signal unit. Frankly, it's about time they did that. Seems like a no-brainer option to offer.
    I'm pretty excited about the Microflex, but it is a bit of a risk since there's not a volume of experience out there with it. There's no moving parts, so I'm hoping it will have longevity.
    Received: 5/24/2024
  35. #144
    Nov 2022
    Niles, MI
    Quote Originally Posted by burchfieldb View Post
    Aww dang it!!! That's way better than what I did. Much sleeker and easier to waterproof.
    I'm probably going to add some panels now
    Received: 5/24/2024
  36. #145
    Nov 2022
    Niles, MI
    Quote Originally Posted by Smiley View Post
    Very nice.
    I put casters on mine. For the bottom of the oven, I used a 16 gauge steel plate, so it's more sturdy than the thin aluminum walls. But overall the structure is very rigid when all riveted together.
    https://www.amazon.com/WEIBIDA-Caste...t_ba_s_5_cp_sc
    Received: 5/24/2024
  37. Thanks Smiley thanked for this post
    Likes Smiley liked this post
  38. #146
    Apr 2024
    St. Charles, MO
    Good to know, thanks Jim.
  39. #147
    Jun 2019
    Gurnee, IL
    Very cool progress Jim. Love the powder coat oven!!! I want to cercoke my side pipes too. Open to a 2fer? I'm not that far from ya!
    The dash is coming out great. I too was going to do the white background so thanks for sharing cause it looks great! I'll use the speedhut gauges tho.
    I'll DM you my personal info-
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Graduated
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55
  40. #148
    Nov 2022
    Niles, MI
    Quote Originally Posted by nuhale View Post
    I would be happy to ruin, I mean Cerakote your side pipes! All seriousness, if mine turn out okay I'd be happy to have you over and we can knock it out in a few hours
    I'll be doing mine in "Cobra Black", which is the darkest black of the 1800 F capable Cerakote coatings
    Received: 5/24/2024
  41. #149
    Aug 2019
    Spokane, WA
    Thanks Tim
    FYI: I recently contacted F5 and Dan G. said the turn signal is only available with the MK5 kit, but they are considering adapting it to others (i.e. Coupe). I'm a ways out, but going to keep a close eye on this option.
  42. Likes JimStone, PNWTim liked this post
  43. #150
    Mar 2021
    Ohio
    Jim,
    If you have never sprayed Cerakote, do lots of practice pieces. It took me a while to get the hang of it. Measurement for the mix ratios are also really important, as they can really effect the finish.
    Brent
  44. #151
    Nov 2022
    Niles, MI
    Jim,
    Brent
    I have not done any Cerkote before, so thanks for the heads up Brent. I'll make sure to do a bunch of practice pieces. I'd be pretty upset to ruin my pipes
    Received: 5/24/2024
  45. #152
    Nov 2022
    Niles, MI
    Making some progress.
    Entered the realm of wiring, which I've been dreading. Mostly because I'm very inexperienced and the thought of it all overwhelmed me. But I've been taking it wire-by-wire and circuit-by-circuit, which has helped.
    I actually started with the rear harness, because it's fairly simple.
    I ended up unwrapping and rewrapping the whole thing, which I think I'll probably be doing for all the harnesses. I added wires for backup lights and my rear view camera. I also changed the fuel pump wire to an 8 AWG wire. Probably overkill, but easy to do now and I'd like my 350 LPH Walbro pump to get the full voltage.
    I made a charcoal canister out of the kit-provided coolant overflow tank, which I won't be using for that purpose. I put it in the rear. QUESTION: does anyone know if it's going to contact the body? I haven't had the body on for months and I didn't take pictures/measurements
    Received: 5/24/2024
  46. #153
    Nov 2022
    Niles, MI
    Mounted my AutoVox V5 Pro rear view mirror camera to the roll bar. It displays fulltime rear view video - there is no actual mirror function. I ran the wire through the roll bar tube. It displays in 1080p, so it's a pretty good picture.
    My son helping with running battery cables
    Mounted the horns up in front of the battery. It seemed like the natural place
    Started a bit behind the dash
    I also ended up getting a Flex-a-Lite fan to replace the kit one. Just have heard too many stories of the kit fan failing. And it is quite loud. I'll swap it out when I take apart the front end to powder coat panels.
    Speaking of powder coating. A bigger oven needed a companion powder coat booth
    Received: 5/24/2024
  47. Likes 460.465USMC liked this post
  48. #154
    Shouldn't conflict with the body in that location.
  49. Thanks JimStone thanked for this post
  50. #155
    Nov 2022
    Niles, MI
    Thank goodness!! Appreciate it Jeff
    Received: 5/24/2024
  51. #156
    Mar 2021
    Ohio
    Jim,
    How did you attach the mirror?
    Brent
  52. #157
    Jan 2025
    Chicago IL.
    Total respect for your effort. Sounds exciting for all involved. Please let us know if you need help with your wiring Doc.
    www.infinitybox.com
    Regards, and good luck!
    Anthony
  53. Thanks JimStone thanked for this post
  54. #158
    Nov 2022
    Niles, MI
    Jim,
    Brent
    Hi Brent, I used this tube flag mount: https://www.amazon.com/BRCOVAN-Alumi..._rpt_ba_s_1_sc
    Works perfectly and is very solid. I didn't need to modify the mirror at all, just took off the little windshield mounting thingy from the mirror and used the included screw with a washer (can sort of see below - 2nd picture)
    My only concern is it does stick up a bit over the roll bar about 7/8". Will there be enough room or will it contact the body?
    Edit: I looked at old pics with the body on - there's tons of room
    Received: 5/24/2024
  55. Thanks 460.465USMC thanked for this post
  56. #159
    Mar 2021
    Ohio
    Thanks for the photos. I was planning on using that mirror and that mount looks like it a great solution.
  57. #160
    Aug 2019
    Spokane, WA
    Thanks, Jim! I also have the Auto Vox camera. This looks like a solid mounting solution. Also, nice work on the powder coat booth!
    P.S. Sorry if I missed it, but what are the holes in your hatch rear wall aluminum? Are they access panels?
