BEAR-AvHistory
Been running 275X40X17 & 315X35X17 on FFR wheels for years. No fit issues. 275 are a bit heavy for some steering inputs without power steering. Nothing wierd
BTW best to use Tire Racks specs which are actual measurements. There are no standards in the listed sizes. Have seen over an inch in tire tread on the ground fron two tires with the same mm listing. Goodyear & Yokahama in that case.
Very nice build Kevin!
And thanks for the info.
Do you happen to know the ET/offset and backspacing of the wheels?
