Results 1 to 4 of 4
Thread: backup camera ideas
    Folsom, CA
    backup camera ideas
    Hey guys - I'm trying to figure out a backup camera scenario... yeah, I know these didn't exist on a '65 Cobra
    but I do have a touchscreen setup and have the backup camera capability - also ran the wires as well.
    I found a design from Saul (RIP) that I think is pretty novel, and hides the camera quite well...
    if you look closely, there's a recessed camera in the license plate frame where the lights reside - the camera is where the usual nut/bolt combo go to hold the frame onto the rubber seal against the trunk
    it seems that he used a few rivets to hold the setup now...
    does anyone have any ideas on how he accomplished this? I may just have to noodle a bit on it to make it work.
    the original idea was to use a license plate frame with a camera, but if the frame has the camera on top - it blocks the lights
    and if the camera is on the bottom, it blocks the trunk handle from opening
    any other ideas?
    Todd
    Feb 2019
    Greality, Colorado
    Todd, I am planning on doing the same as Saul did. As you noted (RIP Saul! I hope you’re driving the celestial highways at full throttle!) Saul, had the most optimal and for that matter, most elegant idea and implementation of adding a rear camera. Perhaps there was an electronic “pop-up” trunk lock, similar to doors that open with a remote switch? I suspect this was the solution and it is no doubt slick! There are various options on Summit or Amazon. I’ll be following along as I will be doing the same. You can do it, just need to route additional wires to make it happen.
    Doug
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
    Dec 2021
    Flower Mound TX
    I eliminated the trunk handle and installed an electric latch from a 2001-2003 Ford Taurus I bought off eBay. It was really quite simple to install and is actuated with a button on the dash. There's also an emergency release cable hidden behind the license plate.
  4. Likes ydousurf liked this post
    Folsom, CA
    Quote Originally Posted by ydousurf View Post
    Doug
    yeah, I have the wires already run it's just drilling and setting up that license plate holder properly
    I already have the trunk handle setup, so another option is probably out of the design at this point
    Todd
