Thanks Thanks:  84
Likes Likes:  481
Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 601 to 640 of 685
Thread: 25th MKIV #9772 Build NOR*CAL: new vanity plate
  1. #601
    Folsom, CA
    Quote Originally Posted by Fman View Post
    Nice progress Todd! Also keep an eye on your ball on the handle, had one fall off and had to purchase a couple threaded balls from McMaster. Never a good day when you loose one of your balls
    https://thefactoryfiveforum.com/show...l=1#post471538
    awesome tip Travis - always good to keep the balls in check
    Todd
  2. #602
    Folsom, CA
    Got an update
    Todd
  3. Likes 460.465USMC liked this post
  4. #603
    Quote Originally Posted by toadster View Post
    Got an update
    Unfortunately my friend Ken is beyond frustrated. He has a whole building full of gray (primered) cars at his new shop and PG&E has him swinging in the wind because they say they can't do the power upgrade necessary so that he can use his paint booths until the end of May...at the earliest
    South Australia
    Get in a rental generator and bulk tank. It will hurt a bit, but cheaper than having a body shop crew standing around with little to do.
    If the supply upgrade work was adequately scheduled with the power company and they failed to meet the date, send them the rental bill.
    Thats has worked for me.
    Best of luck
    Nige
    Gen1 Coyote / TKO600 / IRS
  6. #605
    Quote Originally Posted by Nigel Allen View Post
    Best of luck
    Nige
    Ken and I chatted yesterday and that's exactly what he's had to resort to doing Nigel. Big generator and electrician are coming today. The service upgrade order was put in with the utility months ago but I'd say that it's still not likely that he'll be able to strongarm PG&E to cover any part of the costs.
  7. Likes toadster liked this post
  8. #606
    Folsom, CA
    I hear you guys, Ken is really frustrated but he's been really good to me storing the body for so long, and moving it between his old site and new one.
    I can't say enough, Ken is awesome and really glad he's really close by - we even ran into him and his wife a few weekends ago doing some wine tasting
    fortunately we found a few more projects to do prior to him spraying the car - bonus points if you see one of them in my update pic above
    Thanks guys for tracking with me - it's been a journey, can't wait to get this thing done!!
    Todd
  9. #607
    Folsom, CA
    one more thing to finalize and take up to Ken - he has a generator now and has been spraying some panels, etc to dial in the booth - very exciting!
    The defrosters are something I was on the fence about, but as usual - someone on the forums convinced me to pry open the wallet again, it's almost silly now - but I got the NorthRaceCars plenum for the defrosters since there's no space to mount the regular defrosters.
    from their website: https://northracecars.com/heat_ac.html
    One of the problems with FFR cars and the heater on the passenger side is getting defrost while getting heat to both sides of the passenger compartment. So, if you are tired of all the hoses behind your dash why not run only one hose for your defrost. With this set up run one hose from the defroster to the plenum to get both vents with one hose, then run the other defrost duct to the driver and if the passenger gets cold turn on the heat and have all three. Bond on or use the demist vent screws to hold in place. No holes pre cut, put the tubing where you want it and install one defrost duct. Custom curved to fit the FFR car and fit between the dash and the firewall. Plenum is great for Air Conditioned cars with too much tubing already behind the dash
    here's the 2" hole for the defroster feed, of course I went off center
    two more custom 3D parts needed to be printed, we will be setting the 2" hole in the center of the plenum and feed with a 2.5" tee
    I wasn't able to find any 90 degree tees with a reducer, at least not under $130, so these $2 3D printed PETG parts will have to do
    tee that will go on the main feed line to the driver side vents
    hard to see on this test print but my son made up for the off-center with the flush edge on the plenum
    final print for the plenum part - now to epoxy in place and find some time to get it up to Ken
    This is how it will all go together - pretty sure it will all fit once we trim the hoses to size
    of course with this setup, and laminar air flow, we will be dependent a bit on back-pressure in the system to blow up to those vents, I can close off the 4 cockpit vents to force air up to the defrosters, but IMHO there will be VERY rare cases where this will be needed - I just wanted a more complete system because it will be near impossible to do this later on
    so close now!
    Todd
  10. #608
    I've used that plenum before...well actually parts of it because the passenger side conflicted with the heater box and wouldn't let the body sit down fully so I had to cut it up and reshape the RH side. It should be test fitted with the body and chassis together before bonding it onto the body otherwise you're kind of playing Russian Roulette.
    Folsom, CA
    yep, Ken is going to do another fit with the plenum before bonding it together - I may have to move some bits on top of the A/C evaporator but hopefully will squeeze in there
    Todd
  12. #610
    Folsom, CA
    taking the plenum up to Ken this afternoon, just to show the finished setup epoxied into place - all hoses fit great! just needs ziptied to secure on the barbs
    Todd
  13. #611
    Folsom, CA
    it's been a magical week! here come the pics!
    to give some background - here's the details of the paint
    main color: San Marino Blau (B51) - BMW cars (and some Porsche)
    stripe color: Crystal Laurite Silver (977) - related car: Mercedes-Benz SLR McLaren
    pinstripe color: GM Cashmere (15U) - not so sexy a related car, but matches the bronze frame
    Todd
  14. #612
    Folsom, CA
    next up the silver gets laid down... yes, single broad stripe, not the usual double stripe look...
    Todd
  15. #613
    Folsom, CA
    this next part threw me a bit, Ken sprayed the bronze for pinstripes - and I wondered how they'd turn out, I shared these pics with several folks and they were like - I thought you said the car was going to be blue!?
    Todd
  16. #614
    Folsom, CA
    ok now the fun part, masking the stripes... I started to 'get it' on how he was doing this now! oh the mind of a painter!
    Todd
  17. #615
    Folsom, CA
    Ken in action - love that he sent this over!!
    https://youtube.com/shorts/Ca2oEFtrD...-ezTpM_DwPKiTS
    Todd
  18. #616
    Folsom, CA
    here's a shot of the blue, and how the pins came out! (before clear)
    Todd
  19. #617
    Folsom, CA
    now the awesome clear over it all... I'm still in awe
    Todd
  20. Likes Fman, ydousurf liked this post
  21. #618
    Folsom, CA
    a few pics sent to me today from one of the local guys who was visiting Ken...
    Todd
  22. Likes Fman liked this post
  23. #619
    Jan 2020
    State of Jefferson
    WOW! that turned out amazing, looking forward to seeing it soon! Ken Pike really does one fantastic job on these cars... a true master at his craft.
  24. Thanks toadster thanked for this post
  25. #620
    Congrats Todd! You've had quite the ride with the build. Can't wait to see it all together.
  26. Thanks toadster thanked for this post
  27. #621
    Dublin, OH
    Awesome combo!
  28. Thanks toadster thanked for this post
  29. #622
    Sep 2018
    SF Bay Area, CA
    Congratulations Todd! That looks amazing!
  30. Thanks toadster thanked for this post
  31. #623
    Aug 2019
    Spokane, WA
    Woohoo! That’s a sharp dressed Cobra! Congrats! Looking forward to seeing it all together. Thanks for posting the pics.
    Coupe complete kit. Index. Delivered: 4/22/24. Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  32. #624
    Folsom, CA
    more progress being made, hope to see it in person within a week or two
    ABSOLUTELY LOVE how the engine cover is turning out
    Todd
  33. #625
    Folsom, CA
    also - Ken sprays the underbody, did an awesome job!
    Todd
  34. Likes Nigel Allen liked this post
  35. #626
    Feb 2019
    Greality, Colorado
    Paint looks awesome, Todd! I dig the single stripe and bronze pinstripe highlight. That should compliment the wheels perfectly. I can’t wait to see it all back together and you being able to enjoy the driving aspect going forward. Enjoy the final assembly of your build.
    Doug
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
  36. Likes toadster liked this post
  37. #627
    Aug 2021
    El Dorado Hills, CA
    Looking amazing.... can't wait till you get her home so I can come see in realtime!
    #10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
    • Order Date: September 11, 2021 - 20th Anniversary of 9/11
    • Delivery Day: April 1, 2022 - April Fool's Day
    • First Start and Go-Kart: January 20th, 2023
    • Graduation Date: July 4th, 2023 - Independence Day!!
    • Legal Registration Date: October 4, 2023 - My Birthday!!
    Visit my MKIV Build Thread (#10333)
  38. Likes toadster liked this post
  39. #628
    Folsom, CA
    Todd
  40. #629
    Folsom, CA
    another tickler photo from Ken
    some sanding and polishing going on, and the engine cover painted and placed on the coyote!
    pickup is scheduled for next Wednesday!!!!
    Todd
  41. #630
    Houston TX
    I happened to be in town last week visiting family and drove by the Garden Hwy location to sneak a peak of your car and anything else in Ken's shop but I couldn't find the shop. Did they relocate?
    MK4, 427LS3, IRS, T56 Magnum, Wilwoods
  42. #631
    Jul 2019
    Grand Rapids, MI
    Quote Originally Posted by Its Bruce View Post
    Yes. Shop is now in Marysville.
    MK4 Complete Kit #9673 | Ordered: 08/07/2019 | Pickup: 08/24/2019
    Gen 2 Coyote, TKO600, IRS, Power Steering, 18" Halibrands, Kirkey Vintage Race Seats, Gas-N Headers and Pipes
    Build Thread: https://thefactoryfiveforum.com/show...IRS-Build-9673
  43. #632
    Ken moved to Marysville at the first of the year.
    Folsom, CA
    yep - Ken has a new website too
    https://streetrodpainter.net/
    new address is:
    520 3rd Street
    Marysville, CA 95901
    https://maps.app.goo.gl/kkydZeasL9RKB9Rc8
    it's only about 3 miles from his old spot in Yuba City, but just over the border into Marysville
    Todd
  45. #634
    Folsom, CA
    yet another teaser, had a windshield issue with the passenger side arm, FFR is remedying the issue, but won't pick up until next friday now...
    btw - the headlights are JW Speaker 8700 EVO 2 Classic - wasn't sure how they'd turn out, but so far liking the pic, need to see it in person
    I wanted the bright LED output without the glare so these are focused lights, and wanted something different from the tri-bar look...
    Todd
  46. Likes Ted G liked this post
  47. #635
    Folsom, CA
    windshield goes on in the morning, picking it up tomorrow!!
    Todd
  48. Likes Ted G liked this post
  49. #636
    Sep 2021
    Puyallup, WA
    Like a little kid on the night before Christmas. Congrats.
    MK4 Complete Kit. Gen3 Coyote, TKX, IRS. Wilwoods, Forgeline. Paint Ken’s Custom, CA. Ordered 11/29/21. Received 8/18/22. First start 6/22/23. Final tune 10/22/25.
  50. Thanks toadster thanked for this post
  51. #637
    Folsom, CA
    what an awesome day!!! still lots to do, but HOLY COW this paint really POPS!!!
    Todd
  52. Likes JohnK, 460.465USMC liked this post
  53. #638
    Feb 2019
    Greality, Colorado
    Looks killer Todd! Awesome job! And here I thought the sirens were going to be a joke pulling you over already for the first time. Glad to see you are approaching the end of your dream build. Enjoy your new ride and never wipe that smile off your face. All the best and be safe out there too!
    Doug
  54. Thanks toadster thanked for this post
  55. #639
    Folsom, CA
    Thanks Doug! It's been a journey for sure!! going to sneak over to C&C tomorrow morning
    Todd
  56. Likes ydousurf liked this post
  57. #640
    Jan 2019
    Long Beach, CA
    Excellent Todd! Thanks for sharing your journey. Sent you a PM about build. Thanks!
    Ordered 9/24/2020, Delivered 1/18/2021 MK4 Roadster, 3 Link, 15" Halibrands, Blueprint Carb 347/TKX Installed 3/13/2022, first start 10/2022, go cart 11/2022, CA SB100 Reg Complete 12/2023, Paint by Ken Pike completed 4/2025
  58. Likes toadster liked this post
