Thread: Brake balance bar
    Mar 2018
    Saint Johns, Florida
    Question Brake balance bar
    Hello all,
    Hope all is well. Would someone please direct me to the excellent post someone did about adjusting the Wilwood brake balance bar. I remember reading it but now I can't find it.
    Thank you,
    Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
    vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
    Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
    Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Jeff's First FFR View Post
    Hello all,
    Thank you,
    Joining so I can see this info also
    This is the one I always see.. from the manufacturer: https://www.wilwood.com/PDF/DataSheets/ds252.pdf
  4. Thanks Just 1 More thanked for this post
    Likes Just 1 More liked this post
    Jeff are looking for how to adjust the bias once car is on the road?
    Jul 2021
    Big Canoe, GA
    And while we're at it, thoughts on installing a remote balance adjuster? I can't imaging how brake balancing would change much or need to change much unless you're racing?
    Art Shand, Big Canoe GA
    BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
    I used a cockpit adjuster. It makes things really easy during initial setup. Not so much twisting a knob easier, but eliminating the need to find a safe place to pull off the road, adjust, get back on the road is very nice. It allows you to just drive a normal cruise, w/ an occassional hard stop when no one is behind you.
