So is bolt A not out? Is it still stuck in the spacer or what. You mentioned that you could turn it before. If it is out of the pump and just stuck in the spacer, heat the spacer and use something like a slide hammer vice grip to separate the spacer from the bolt or just cut the bolt since you're going to have to replace it anyway. Just try not to damage the pretty bracket.
