I got the new fender brackets and put them on just now. WAY better. The adjustability makes it easy to space and clock the fenders the same on each side, and the small normal flex of the fenders is less too with the stainless steel. I added about 3/8" more space from the tire so I think that should stop the occasional touching I was having. I might pass the change suggestion back to McQueen for any future kits they sell.
I also don't have to remove the lower control arm ball joint nut anymore to remove the bracket since I can slide it up higher to clear the castle nut. Extra bonus...
