Hello everyone,
I recently began my build and this is my first question to the forum so thank you all for the “there are no stupid questions policy!”
I am in the process of fastening the spindles to the lower control arms and when I torque the castle nut to the appropriate force (80-90 lbs), the castle nut is not quite low enough to permit the cotter pin to get through the hole. It’s very close, perhaps 0.5-1 millimeter away.
Due to the location of the cotter hole versus the castle nut merlons (the top parts of the castle nut, had to look it up) i would need to torque a lot further to get to the next opening (or crenel, had to look that up too).
I have searched the forums and can see that this issue has been encountered by others but i have found no satisfactory responses. My solutions are:
1. Use a disc sander to take a tiny layer off of the spacer which will allow the castle nut to torque just a little lower and free up the cotter pin hole. I have included a photo of the spacer that came in the IFS component box, one side is flat and the other has a slight conically concave shape and i wonder if this is the right spacer in the first place.
2. Toss the spacer and build up to a workable height with washers. This was a proposed solution on various forum threads, but seems to me to be very unwise given what’s going on in this part of the car. I will not do this, but highlight it as a suggestion found elsewhere in the forums.
3. Question whether it’s the ball joint or boot (i bought an aftermarket boot for this ball joint, as these were missing from my inventory) causing the fractional variance.
4. Buy new spacers at different widths and go trial and error.
I appreciate any and all insights.
Thank you very much!
