Quote Originally Posted by cc2Arider View Post
Is the remedy to simply install the spherical bearing flange on the inside of the footbox frame reinforcement ?
Feedback appreciated!
Craig C
Hi Craig. Sounds like you're enjoying this part of the build--I did as well, one of my favorite parts. If you can't get the needed clearance with the bearing on the outside of the FB, I wouldn't hesitate to put it on the inside. You'll likely need to grind the top portion of the flange bearing to provide clearance for the lower right mounting hole of the pedal box rear bracket. I would hesitate, however, before cutting the steering shaft. That should not be needed.
