Thanks Thanks:  4
Results 1 to 14 of 14
Thread: NRG Quick Release Steering Hub Jig
    Morgantown, WV
    Hello,
    I am looking to see if anyone has a Steering Hub Jig that I can borrow to drill my holes out on my NRG quick release steering wheel. (or other advice on drilling out without a jig) As I understand it, I will need to counter sink the existing 6 hub screws (shortening or buying shorter screws) then drill out the hub attached NRG piece and then finally the steering wheel attachment to the removable part of the NRG release. Also, just wondering how most people cut out the center of the hub attachment for the NRG. I know Paul (EdwardB) used a router and dremel but I am unfortunately without a router.
    Thanks in advance.
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Slow and Slightly Angry View Post
    Hello,
    Thanks in advance.
    If you have access to a 3d printer I can send you the 2 files for the jigs. If not PM me and we can work something out. I used a hack saw and a dremel. You can follow on my build thread at https://thefactoryfiveforum.com/show...l=1#post500156.
    Scott Pregont
    My Albums
  3. Thanks Slow and Slightly Angry thanked for this post
    Morgantown, WV
    Thanks Scott.
    I do often check in on your build but managed to miss that massive, super helpful, section.
    Ill see if I know anyone who has a printer and let you know.
    Thanks again
    Edmonton Alberta
    I did mine without a jig. Used a hack saw and file to cut the center out, marked the holes and drilled it with a drill press. There is a counter sink drill bit to make the counter sunk holes. The process takes a few hours but is not hard, the end result is worth the effort.
    David W
    Mkll 4874 built in 2004
  6. Thanks Slow and Slightly Angry thanked for this post
  7. #5
    Feb 2018
    Austin, TX
    I used a Dremel to cut away the NRG piece. Used a cutoff wheel and it slices through the aluminum pretty quickly. Cleaned it up with the sanding wheel, some files, and some sandpaper. I shipped my jigs off to another builder. Details on the install on Post #66 if the pictures help.
    Darryl [dbo_texas]
  8. Thanks Slow and Slightly Angry thanked for this post
  9. #6
    Jan 2019
    Richland, WA
    Or you could just buy the NRG double-d hub and not have to worry about any of that— https://www.amazon.com/gp/product/B00Y98AP1S. Mounts right to the steering shaft as is. Sure it costs a little extra, but seemed like a fair trade in terms of cost of time.
    --jim
    Build 1: Gen III Type 65 Coupe, Gen II Coyote
  10. #7
    Feb 2018
    Hello,
    Thanks in advance.
    I have a set of the jigs but the problem is they are in Florida and I am in Michigan until mid-October. If you still want them, sent me a pm.
    Mark III 347/435 hp TKO 3.55 axle
    Gen 3 Daytona Coyote Gen 3 T56 3.73 diff. (In build)
    Superlite SLC LS3 480 hp Graziano Transaxle
  11. Thanks Slow and Slightly Angry thanked for this post
  12. #8
    Morgantown, WV
    Quote Originally Posted by Alphamacaroon View Post
    Sorry I did not provide my full details. I have the RT turn signal setup, so I'm not sure that hub will work.
  13. #9
    Jan 2019
    Richland, WA
    Got it— then yes it's unclear if that would work. Although I still suspect it might— the hub is designed to work with an older production Ford Mustang vehicle with turn signals and such, so there is a possibility it could be nearly compatible. But who knows.
    --jim
  14. #10
    Morgantown, WV
    Got the jigs printed by an old colleague of mine.
  15. Likes Namrups liked this post
  16. #11
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Offer them up to the next guy when your done with them. Pay it forward!!!
    Scott Pregont
    My Albums
  17. #12
    Morgantown, WV
    Will do!
  18. #13
    Senior Member Mat1asBEV&ICE's Avatar
    May 2023
    Boston
    For future reference, if anyone is looking for a set of the 3D printed jigs, I have a pair courtesy of Namrups. DM me if you need them.
    Delivery October 2023, #10847, Gen 3, IRS
  19. #14
    May 2023
    Boston
    Hi, just an update. I mailed these to Jespinosa Jespinosa in July, 2024. Not sure if he still has them.
