Thanks Thanks:  11
Likes Likes:  232
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 257
Thread: # 1115 resurrection
  1. #121
    Sep 2022
    Huntington, IN
    And I'll add, that some wheels that look good with some colors just don't look right with other colors. It can be maddening when you get to the point of wheels & colors. That was the hardest part of my build was figuring out what color to go with. Then on my 55 F100 Build I'm wrapping up now, I knew the color I wanted but finding the right wheels to go with it was the biggest struggle. Ugh
    Jim
    You ain't kidding... choosing those wheels was an agonizing decision.. I drove my friends and family crazy with it. My plan for color is a Black Cherry pearl metallic
  2. Likes 33fromSD, Ltfracing liked this post
  3. #122
    Sep 2022
    Huntington, IN
    Dyno disappointment... Stopped by the engine shop and they were just finishing the dyno tune on the engine, final numbers 401hp / 437tq .. should make for a fun little cruiser but honestly, I wanted more.
  4. #123
    Quote Originally Posted by Just 1 More View Post
    Really? I have no idea what I have but I always assumed ~300.. which is still a lot of fun
  5. #124
    Sep 2022
    Huntington, IN
    Quote Originally Posted by RoadRacer View Post
    My 600hp/581tq 68 Camaro doesnt even feel like 600hp to me anymore.. but my passengers say it does, so what do I know.... lol
    I'm sure 400hp in these little gokarts should be plenty
  6. #125
    Jun 2020
    SoDak
    401HP is pretty good, I have 436 HP in my 08 Vette, and 485 in my 15 Challenger Scat Pack and both are much heavier then the 33 but are wicked fast, I'm not sure I'd want that muscle in the 33. My little 302 in the 33 is 235 HP (I think), and with the 33 only being 2400 lbs. it pretty fast / squirely. I think you'll find 401HP in the 33 will be more than you think it is.
    Keep in mind, these little 33s have next to nothing for weight in the rear.
    Jim
  7. Likes Just 1 More liked this post
  8. #126
    Jul 2020
    Spencer, MA
    My LS3 is 430 up and I'm not going to get crazy unless it's in a straight line. Power to weight ratio is high on these puppies!
  9. Likes Just 1 More liked this post
  10. #127
    Sep 2022
    Huntington, IN
    Got the kids out of detention yesterday so now to get them reattached and back in the chassis. Both were new rebuilt E-bay purchases by the previous owner and came with the car. Both needed rebuilt. Trans guy found a bad bearing, bad bushing, bad pump housing. Had him install a TCI constant pressure valve body while he was in there and I got a Boss Hog 3200-3500 converter for it. Engine had bad valve guides and bad valves, sloppy main caps and a lot of crud in the oil galleries. Almost $4500 later, it's all done and done right this time.
  11. #128
    Consummate Learner
    Kingsland, TX
    I like your trans stand... I have the same one!
    400 ponies should be fun! I'm aiming for 300-325 on my 302.
  12. Likes Just 1 More liked this post
  13. #129
    Jul 2020
    Spencer, MA
    I hope that big cap distributor will fit at the firewall. It's pretty tight back there.
  14. #130
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Mastertech5 View Post
    It cleared before I removed the engine for the rebuild
  15. #131
    Sep 2022
    Huntington, IN
    I always try to test fit things before getting in too deep, just like i'm sure a lot of you do. I previously mentioned "When cranking it sounds like the starter and flywheel and torque converter don't like each other." Well, it seems the flex plate and converter bolts don't exactly line up just right and he must have forced the bolts to go in creating a somewhat slight off center flex plate/torque converter alignment and it seems the flex plate is a little warped. I was really hoping to have all this back together and in the chassis this weekend but looks like i'll be waiting on a new flex plate.
  16. Likes Ltfracing liked this post
  17. #132
    Good catch. Always trust your gut!
  18. Likes Just 1 More liked this post
  19. #133
    Jul 2020
    Spencer, MA
    FYI. When you go to tighten up your torque converter bolts, usually two holes are slightly slotted and one is not. Start with the unslotted one and turn them in by hand but don't tighten. Get all of them started before tightening them. I've seen this before by guys that don't know about the slots and tighten one of the slotted hole bolts before getting all the bolts started first so the unslotted hole doesn't line up quite right. You have to turn the flywheel around twice.
  20. #134
    Sep 2022
    Huntington, IN
    Say what??? I'll go check that out and see if that's my issue. I had no idea.
  21. #135
    Sep 2022
    Huntington, IN
    I received the ATI flex plate and had the same issue. Called the Torque converter company and their answer was to drill the flex plate holes slightly larger... called ATI and their answer was drill the flex plate holes a little larger.. Sooooooooo, 1/32" was all it took. Drilled each hole equally on a drill press in 1/64th increments keeping everything in alignment. The holes were exactly 29/64" and ended up 31/64"
  22. #136
    Sep 2022
    Huntington, IN
    Mine were not slotted, each hole was exactly 29/64"
  23. #137
    Jul 2020
    Spencer, MA
    Must be a OEM thing. Well at least the problem is solved!
  24. Likes Just 1 More liked this post
  25. #138
    Sep 2022
    Huntington, IN
    Found some ambition last night and it's back in.
  26. #139
    Sep 2022
    Huntington, IN
    A little more every day
  27. #140
    Jul 2020
    Spencer, MA
    Love the big block style valve covers!
  28. #141
    Sep 2022
    Huntington, IN
    Oh noooo... Those are just temporary so I don't scratch up the good ones.
  29. #142
    Sep 2022
    Huntington, IN
    I've been struggling with the trans cooler size and placement. 3rd one was the right one. Derale 13401 for the win.
  30. Likes Ltfracing, Mastertech5 liked this post
  31. #143
    Aug 2022
    I like it,did you drill the holes in your upper arms or did they come like that,thank you
    33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
  32. #144
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Ltfracing View Post
    That's the way they came as far as I know
  33. #145
    Sep 2022
    Huntington, IN
    Always a good feeling to hit the key and ... vroooom..
    https://youtu.be/azourTbqSeo
  34. Likes 33fromSD, Ltfracing, TxMike64, RoadRacer liked this post
  35. #146
    Jul 2020
    Spencer, MA
    That link doesn't work. They are usually highlighted in blue for working links.
  36. #147
    Las Vegas
    Jul 2020
    Spencer, MA
    Nice!
  38. #149
    Aug 2022
    Awesome
  39. #150
    Consummate Learner
    Kingsland, TX
    Congrats! Sounds awesome!
  40. #151
    Sep 2022
    Huntington, IN
    Not much progress, Doing one little thing at a time, chipping away at it. Today I securely bolted in the fuel tank, redid the fuel line, again. This time I ran it through the panel using a -6an bulkhead fitting then wired in the fuel sender and used one of the weatherpack connectors.
  41. #152
    Sep 2022
    Huntington, IN
    This sucks.. Seems I have a leak at the coolant passages, yes, both sides. I guess i'm looking at pulling the intake and silicone around the coolant passages
  42. #153
    Placitas, NM
    Do any of those intake manifold bolts require sealant on them?
  43. #154
    Sep 2022
    Huntington, IN
    I don't know
  44. #155
    Jul 2020
    Spencer, MA
    Your vent line won't work there. The body sits down just over the tube with a 1 1/2" foam seal there and your canister may interfere with the trunk hinge.
    As far as the intake bolts go, put liquid Teflon on the intake bolts. Just run it around the bottom 1/4" or so of the threads. It will coat everything as you run them in. Make sure there is no oil in the holes or on the bolts. Use grey sealant around the coolant passages on the heads and intake. Clean all surfaces with brake clean on a lint free rag. Smear the sealant around the port with your finger so you have just a light coating, standard practice in the repair business.
  45. #156
    Sep 2022
    Huntington, IN
    I ordered a new intake, Edelbrock Air Gap 7501-CP "Chrome Plasma Coated" and a set of Fel-Pro Intake Manifold Gaskets MS 90314-2, I'll match the gaskets to the heads and the intake to make sure they're a good fit and then the sealant on the head and intake at the water ports. I'll also do the sealant on the bolts like you mentioned. Won't know why it's leaking until I take it apart but, could very well be the wrong gasket or no sealant used at the ports.. stay tuned
  46. #157
    Aug 2022
    If the block was decked then the intake needs to be machined on the china rail half as much or it will leak there
  47. #158
    Sep 2022
    Huntington, IN
    I don't think the block was decked or the heads shaved but I will be looking at all possibilities when I disassemble and replace
  48. Likes Ltfracing, JimLev liked this post
  49. #159
    Sep 2022
    Huntington, IN
    I pulled the intake last night, gaskets were sealed good to the intake but didn't seem to be so good to the heads. A good sharp scraper made quick work of removing anything off the head side. One thing I noticed are these scratches in the head where someone must have forced a screwdriver between the head and intake. It would make sense that the coolant was weeping up out of those microgrooves. I'll dress them up a little, apply a coat of silicone and try again with new gaskets and the new intake.
  50. #160
    Sep 2022
    Huntington, IN
    Used some 1500 grit wet/dry and brakekleen and polished the grooved areas very lightly, it's all cleaned up and ready for the new stuff.
