I had issues with a leaking valve cover (cork gasket w/bolts), ended up switching to the blue fel pro gaskets with studs and nylock nuts. Has not leaked a drop or loosened up and that was over 4k miles ago. I ended up double nutting the stud to tighten into the head. Seems to be working well, I feel like it is a much better set up than using bolts.
