Results 1 to 11 of 11
Thread: Rear disc brakes
    Feb 2020
    Tucson, AZ
    Rear disc brakes
    I am using a donor 8.8 rear end from a 2002 mustang, however I had it narrowed to the fox body rear end width to fit wider rear tires and upgraded to 31 spline axles. This also resulted in the antilock sensor ring to be no longer present on the axle. As a result the 2002 disc brake caliper bracket no longer fits between the rotor and the axle mounting point. Can anyone point to the resolution to this? Do I need fox body brake rotors, caliper brackets or both? Other solutions? Thanks.
    Could you possibly go with Ford Explorer Rear Brakes instead?
    I'm running these on my 3-Link MK-4 (Explorer 1995-2001 / Rear Wheel Drive) standard brake assembly.
    The rotors are about the same size as the Mustang GT front assembly, but use single piston calipers and solid rotors.
    The kit on my car was I purchased from Moser Engineering which I've linked below:
    Link To Moser Engineering:
    https://www.moserengineering.com/630...brake-kit.item
    Brake Job Video:
    https://youtu.be/gvokNXdecss
    Hope This Helps & Good Luck!
    Feb 2020
    Tucson, AZ
    Brake Job Video:
    That’s an idea, I’ll have to look into. From the YouTube video, it was hard to tell if the caliper bracket was integrated with the axle or bolt on.
    The mounting/backer plate mounts to the axel and the calipers bolt to the mounting/backer plate.
    I went down this path because the Explorer Rear rotors are just a smidge larger in diameter than the standard Mustang GT front rotors. Basically they scale well when you look at the car from the side plus the E-Brake Cables were Easy-Peasy to route and mount.
    NOTE: ..The 5/8" rear MC works fine with the 3/4" front MC.
    Again, Hope This Helps & Good Luck!
    Quote Originally Posted by Jaguar Engineer View Post
    I have a rear axle from a 2003 mustang and was planning on going the same route. A couple questions for you:
    1. How much did it cost to have it narrowed?
    2. I assumed the tubes and axles would be cut down and the ends would remain the same (with sensor rings, brakes, etc) was that not possible?
    Thanks.
    Feb 2020
    Tucson, AZ
    Quote Originally Posted by cschwer View Post
    Thanks.
    Having it narrowed was a couple hundred bucks. However, if you are going to make other upgrades to the axle, that can increase the cost significantly. Typically only the tubes are cut down and rewelded, it is more practical to just replace the axles with the correct length instead of cutting them and rewelding. If you opt of upgrade to 31 spline axles, that will require a new differential unit which will drive up the costs significantly. In my case, I did upgrade to the 31 spline axle, but without the tone ring for abs. If you find the correct length axle length with abs, etc., then yes you can carryover the same brakes/hardware.
  7. Thanks cschwer thanked for this post
    Feb 2020
    Tucson, AZ
    Did you by chance run into the issue of the axle flange on the Mustang axle being smaller than the ford explorer bolt pattern?
    Feb 2020
    Tucson, AZ
    Quick follow up to anyone that faces this issue in the future. Breeze has a rear caliper bracket kit designed specifically for this purpose, and it worked out great for my situation. https://breezeautomotive.com/shop/ca...-length-axles/
  10. #9
    cschwer usually the axle housing is cut down to the Fox width and then Fox width axles are installed. Stock Fox axles are relatively inexpensive and there are plenty of upgraded axles available. I think going to a custom width other than Fox width is going to up your costs significantly.
  11. #10
    My hope was to narrow the entire assembly to fox width, so that means the housing would be narrower than fox width to allow for the abs tone rings. The axle faces would be the right width overall so that I could use the ff halibrand wheels. I should probably start calling places to get an idea of pricing. I've heard the stock axles can be cut down and resplined.
  12. #11
    May 2013
    OH,KY,WV tri-state area
    I am running these offset Caliper brackets on a Fox housing so I can run early fox axles https://www.ebay.com/itm/324449514582 These are for the 10.65"(Regular GT Mustang) non cobra brakes.
    Here is the kit for the 11.65" Cobra brakes https://www.ebay.com/itm/14391548672...4AAMXQIBBRDGPL
    here is the thread on my budget brake setup https://thefactoryfiveforum.com/show...kes-ona-budget
