Quote Originally Posted by mladen View Post
I just went through it today. Same setup. https://thefactoryfiveforum.com/show...-line-fittings
And this is the fitting I used to go from npt to an on the wilwood https://a.co/d/cqV9Idi
The braided line I linked to in the other thread is perfect length for routing it out the side of the ds footbox. Getting it bled is a bit of a pain though. They explain it here https://youtu.be/wgc7ApCMTGA Keep in mind you literally have to submerge that whole fitting assembly into the fluid. I made a giant mess in the garage
Perfect, thank you
JJ
